local _ = require('lodash')
local GLOBAL_DATA_MODULE = 'global_data'
local utils = require('Utils')
local persistence = require('persistence')
local HTTPResponse = require('HTTPResponse')
local Timer = require('Timer')
local Security = require('Security')
local SystemEvent = require('SystemEvent')
local CustomEvent = require('CustomEvent')
local HistoricalStorage = require('HistoricalStorage')
local function EventHelpers(domoticz, mainMethod)
local globalsDefinition
local currentPath = globalvariables['script_path']
if (_G.TESTMODE) then
-- make sure you run the tests from the tests folder !!!!
_G.scriptsFolderPath = currentPath .. 'scripts'
package.path =
currentPath .. 'scripts/?.lua;' ..
currentPath .. 'data/?.lua;' ..
currentPath .. '/../?.lua;' ..
package.path
local webRoot = globalvariables['domoticz_webroot']
local _url = 'http://127.0.0.1:' .. (tostring(globalvariables['domoticz_listening_port']) or "8080")
local settings = {
['Log level'] = tonumber(globalvariables['dzVents_log_level']) or 1,
['Domoticz url'] = _url,
url = url,
webRoot = tostring(webRoot),
serverPort = globalvariables['domoticz_listening_port'] or '8080',
dzVentsVersion = globalvariables.dzVents_version,
domoticzVersion = globalvariables.domoticz_version,
location = {
name = utils.urlDecode(globalvariables['domoticz_title'] or "Domoticz"),
latitude = globalvariables.latitude or 0,
longitude = globalvariables.longitude or 0,
if (webRoot ~= '' and webRoot ~= nil) then
settings['Domoticz url'] = settings['Domoticz url'] .. '/' .. tostring(webRoot)
_G.logLevel = settings['Log level']
if (domoticz == nil) then
local Domoticz = require('Domoticz')
domoticz = Domoticz(settings)
local self = {
['utils'] = utils, -- convenient for testing and stubbing
['domoticz'] = domoticz,
['settings'] = settings,
self.scriptsFolderPath = scriptsFolderPath
self.dataFolderPath = _G.dataFolderPath
function self._getUtilsInstance()
return utils
function self.getStorageContext(storageDef, module)
local storageContext = {}
local fileStorage, value, ok
--require('lodash').print(1, storageDef)
if (storageDef ~= nil) then
-- load the datafile for this module
ok, fileStorage = pcall(require, module)
if type(fileStorage) == boolean then
utils.log('Problem with module: ' .. module, utils.LOG_ERROR)
package.loaded[module] = nil -- no caching
if (ok) then
-- only transfer data as defined in storageDef
for _var, _def in pairs(storageDef) do
local var, def
if (type(_var) == 'number' and type(_def) == 'string') then
var = _def
def = {}
var = _var
def = _def
if (def.history ~= nil and def.history == true) then
storageContext[var] = HistoricalStorage(fileStorage[var], def.maxItems, def.maxHours, def.maxMinutes, def.getValue)
if (fileStorage[var] == nil) then
-- obviously this is a var that was added later
-- initialize it
storageContext[var] = def.initial
storageContext[var] = fileStorage[var]
local var, def
var = _def
def = {}
var = _var
def = _def
--require('lodash').print('>', var, def, '<')
-- no initial value, just an empty history
if (def.initial ~= nil) then
storageContext[var] = nil
storageContext.initialize = function(varName)
if (storageContext[varName] ~= nil and storageDef[varName].history == nil ) then
storageContext[varName] = storageDef[varName].initial
fileStorage = nil
return storageContext
function self.writeStorageContext(storageDef, dataFilePath, dataFileModuleName, storageContext)
local data = {}
-- transfer only stuf as described in storageDef
for var, def in pairs(storageDef) do
if (type(var) == 'number' and type(def) == 'string') then
data[def] = storageContext[def]
data[var] = storageContext[var]._getForStorage()
local ok, err = pcall(persistence.store, dataFilePath, data)
-- make sure there is no cache for this 'data' module
package.loaded[dataFileModuleName] = nil
if (not ok) then
utils.log('There was a problem writing the storage values', utils.LOG_ERROR)
utils.log(err, utils.LOG_ERROR)
local function getEventInfo(eventHandler, mode)
local res = {}
res.type = mode
res.scriptName = eventHandler.name
if (eventHandler.trigger ~= nil) then
res.trigger = eventHandler.trigger
return res
local function deprecationWarning(moduleName, key, value, quoted)
local msg
if quoted then
msg = 'dzVents deprecation warning: please use "on = { [\'' .. key .. '\'] = { \'' .. tostring(value) .. '\' } }". Module: ' .. moduleName
msg = 'dzVents deprecation warning: please use "on = { [\'' .. key .. '\'] = { ' .. tostring(value) .. ' } }". Module: ' .. moduleName
utils.log(msg, utils.LOG_ERROR)
function self.callEventHandler(eventHandler, subject)
local useStorage = false
if (eventHandler['execute'] ~= nil) then
-- Prepare storage
if (eventHandler.data ~= nil) then
useStorage = true
local localStorageContext = self.getStorageContext(eventHandler.data, eventHandler.dataFileName)
if (localStorageContext) then
self.domoticz.data = localStorageContext
self.domoticz.data = {}
if (globalsDefinition) then
local globalStorageContext = self.getStorageContext(globalsDefinition, '__data_global_data')
self.domoticz.globalData = globalStorageContext
self.domoticz.globalData = {}
-- Run script
local ok, res, info
local baseType = subject and subject.baseType or ''
if (baseType == domoticz.BASETYPE_DEVICE) then
info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_DEVICE)
ok, res = pcall(eventHandler['execute'], self.domoticz, subject, info)
elseif (baseType == domoticz.BASETYPE_VARIABLE) then
info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_VARIABLE)
elseif (baseType == domoticz.BASETYPE_SECURITY) then
info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_SECURITY)
local security = Security(self.domoticz, info.trigger)
ok, res = pcall(eventHandler['execute'], self.domoticz, security, info)
elseif (baseType == domoticz.BASETYPE_SCENE or baseType == domoticz.BASETYPE_GROUP) then
if (baseType == domoticz.BASETYPE_SCENE) then
info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_SCENE)
info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_GROUP)
elseif (baseType == domoticz.BASETYPE_HTTP_RESPONSE) then
info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_HTTPRESPONSE)
info.trigger = subject.callback
local response = HTTPResponse(self.domoticz, subject)
ok, res = pcall(eventHandler['execute'], self.domoticz, response, info)
elseif (baseType == domoticz.BASETYPE_SYSTEM_EVENT) then
info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_DOMOTICZ)
info.trigger = subject.type
local dze = SystemEvent(self.domoticz, subject)
ok, res = pcall(eventHandler['execute'], self.domoticz, dze, info)
elseif (baseType == domoticz.BASETYPE_CUSTOM_EVENT) then
info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_CUSTOM)
local custom = CustomEvent(self.domoticz, subject)
ok, res = pcall(eventHandler['execute'], self.domoticz, custom, info)
-- timer
info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_TIMER)
local timer = Timer(self.domoticz, info.trigger)
ok, res = pcall(eventHandler['execute'], self.domoticz, timer, info)
if (ok) then
-- Persist storage
if (useStorage) then
self.writeStorageContext(eventHandler.data,
eventHandler.dataFilePath,
eventHandler.dataFileName,
self.domoticz.data)
self.writeStorageContext(globalsDefinition,
_G.dataFolderPath .. '/__data_global_data.lua',
_G.dataFolderPath .. '/__data_global_data',
self.domoticz.globalData)
self.domoticz.data = nil
self.domoticz.globalData = nil
return res
utils.log('An error occurred when calling event handler ' .. eventHandler.name, utils.LOG_ERROR)
utils.log(res, utils.LOG_ERROR) -- error info
utils.log('No "execute" function found in event handler ' .. eventHandler, utils.LOG_ERROR)
function self.scandir(directory, type)
local pos, len
local i, t, popen = 0, {}, io.popen
local sep = string.sub(package.config, 1, 1)
local cmd
local namesLookup = {}
if (directory == nil) then
return {}
if (sep == '/') then
cmd = 'ls -a "' .. directory .. '"'
-- assume windows for now
cmd = 'dir "' .. directory .. '" /B'
t = {}
local pfile = popen(cmd)
for filename in pfile:lines() do
pos, len = string.find(filename, '.lua', 1, true)
if (pos and pos > 0 and filename:sub(1, 1) ~= '.' and len == string.len(filename)) then
local name = string.sub(filename, 1, pos - 1)
table.insert(t, {
['type'] = type,
['name'] = name
namesLookup[name] = true -- for quick lookup for filename
--utils.log('Found module in ' .. directory .. ' folder: ' .. t[#t].name, utils.LOG_DEBUG)
pfile:close()
return t, namesLookup
function self.processTimeRuleFunction(fn)
local ok, res = pcall(fn, self.domoticz)
if (not ok) then
utils.log('Error executing custom timer function.', utils.LOG_ERROR)
print(res)
return false
return res
function self.handleEvents(events, subject)
local originalLogLevel = _G.logLevel -- a script can override the level
local function restoreLogging()
_G.logLevel = originalLogLevel
_G.logMarker = nil
if (type(events) ~= 'table') then
restoreLogging()
return
for eventIdx, eventHandler in pairs(events) do
if (eventHandler.logging) then
if (eventHandler.logging.level ~= nil) then
_G.logLevel = eventHandler.logging.level
if (eventHandler.logging.marker ~= nil) then
_G.logMarker = eventHandler.logging.marker
local moduleLabel
local moduleLabelInfo = ''
local triggerInfo
local scriptType = eventHandler.type == 'external' and 'external script: ' or 'internal script: '
if (eventHandler.type == 'external') then
moduleLabel = eventHandler.name .. '.lua'
moduleLabel = eventHandler.name .. ''
domoticz.moduleLabel = eventHandler.name:gsub('%.lua','') -- used in dynamic logmarker
moduleLabelInfo = ' Device: "' .. subject.name .. ' (' .. subject.hardwareName .. ')", Index: ' .. tostring(subject.id)
moduleLabelInfo = ' Variable: "' .. subject.name .. '" Index: ' .. tostring(subject.id)
moduleLabelInfo = ' Security: "' .. subject.name .. '"'
moduleLabelInfo = (subject.baseType == 'scene' and ' Scene' or ' Group') .. ': "' .. subject.name .. '", Index: ' .. tostring(subject.id)
moduleLabelInfo = ' HTTPResponse: "' .. subject.callback .. '"'
moduleLabelInfo = ' Domoticz event: "' .. subject.name .. '"'
moduleLabelInfo = ' Custom event: "' .. subject.name .. '"'
triggerInfo = eventHandler.trigger and ( ', trigger: "' .. eventHandler.trigger .. '"' ) or ''
local clockTimeStampAtStart = os.clock()
local timeStampAtStart = os.time()
utils.log('------ Start ' .. scriptType .. moduleLabel ..':' .. moduleLabelInfo .. triggerInfo, utils.LOG_MODULE_EXEC_INFO)
local clockTimeSpend = os.clock() - clockTimeStampAtStart
local realTimeSpend = os.time() - timeStampAtStart
if realTimeSpend > 9 or clockTimeSpend > 7 then
utils.log('------ Finished ' .. moduleLabel .. ' after >' .. realTimeSpend .. ' seconds. (using '.. tostring(clockTimeSpend):sub(1,5) .. ' seconds CPU time !)' , utils.LOG_ERROR)
elseif realTimeSpend > 6 or clockTimeSpend > 5 then
utils.log('------ Finished ' .. moduleLabel .. ' after >' .. realTimeSpend .. ' seconds. (using '.. tostring(clockTimeSpend):sub(1,5) .. ' seconds CPU time !)' , utils.LOG_FORCE)
utils.log('------ Finished ' .. moduleLabel , utils.LOG_MODULE_EXEC_INFO)
restoreLogging()
function self.processTimeRules(timeRules, testTime)
-- accepts a table of timeDefs, if one of them matches with the
-- current time, then it returns true
-- otherwise it returns false
local now
if (testTime == nil) then
now = self.domoticz.time
now = testTime
for i, _rule in pairs(timeRules) do
if (type(_rule) == 'function') then
return self.processTimeRuleFunction(_rule), 'function'
local rule = string.lower(_rule)
if (now.matchesRule(rule)) then
return true, rule
return false
function self.checkSecurity(securityDefs, security)
for i, def in pairs(securityDefs) do
if (def == security) then
return true, def
return false
local function addBindingEvent(bindings, event, module)
if (bindings[event] == nil) then
bindings[event] = {}
table.insert(bindings[event], module)
local function loadEventScripts()
local scripts = {}
local errModules = {}
local internalScripts
local requireTimeout, ok, diskScripts, externalNames, moduleName, i, event, j, err
local modules = {}
local scripts = {}
ok, diskScripts, externalNames = pcall(self.scandir, _G.scriptsFolderPath, 'external')
if (not ok) then
utils.log(diskScripts, utils.LOG_ERROR)
modules = diskScripts
ok = true
ok, internalScripts = pcall(self.scandir, _G.generatedScriptsFolderPath, 'internal')
if (not ok) then
utils.log(internalScripts, utils.LOG_ERROR)
for i, internal in pairs(internalScripts) do
if (externalNames[internal.name]) then
-- oops already there, skipping
utils.log('There is already an external script with the name "' .. internal.name .. '.lua". Please rename in the internal script.', utils.LOG_ERROR)
table.insert(modules, internal)
-- extract global_data module and make sure it is the first in the list
-- because then peeps can create some globals available everywhere before the other modules load
local globalIx
for i, moduleInfo in pairs(modules) do
if (moduleInfo.name == GLOBAL_DATA_MODULE) then
globalIx = i
break
if (globalIx ~= nil and globalIx > 1) then
local globalModule = modules[globalIx]
table.remove(modules, globalIx)
table.insert(modules, 1, globalModule)
function self.wait(time)
local isWindows = string.sub(package.config, 1, 1) ~= '/'
local delayCommand = ( isWindows and 'timeout /T 1' ) or 'sleep 1'
local duration = os.time() + ( time or 1 )
while os.time() < duration do os.execute(delayCommand) end
function self.tryRequire(moduleName, requireTimeout, location)
local ok = true
ok, module = pcall(require, moduleName)
if ( ok and module ) or requireTimeout < 1 or not(tostring(module):match('^module')) then
return ok, module, requireTimeout
elseif not(ok) then
while not(ok) and requireTimeout > 0 do
utils.log('Loading of ' .. location .. ' script "'.. moduleName .. '.lua" failed. Retrying in a second.', utils.LOG_FORCE)
if not(_G.TESTMODE) then self.wait(1) end
if not(ok) then
requireTimeout = requireTimeout - 1
for i, moduleInfo in ipairs(modules) do
local module, skip
local moduleName = moduleInfo.name
local logScript = (moduleInfo.type == 'external' and 'Script ' or 'Internal script ')
_G.domoticz = {
['LOG_INFO'] = utils.LOG_INFO,
['LOG_MODULE_EXEC_INFO'] = utils.LOG_MODULE_EXEC_INFO,
['LOG_DEBUG'] = utils.LOG_DEBUG,
['LOG_ERROR'] = utils.LOG_ERROR,
['SECURITY_DISARMED'] = self.domoticz.SECURITY_DISARMED,
['SECURITY_ARMEDAWAY'] = self.domoticz.SECURITY_ARMEDAWAY,
['SECURITY_ARMEDHOME'] = self.domoticz.SECURITY_ARMEDHOME,
ok = true
ok, module, requireTimeout = self.tryRequire(moduleName, ( requireTimeout or 3 ), moduleInfo.type )
_G.domoticz = nil
if (ok) then
if (moduleName == GLOBAL_DATA_MODULE) then
if (module.data ~= nil) then
globalsDefinition = module.data
self.globalsDefinition = globalsDefinition
if (module.helpers ~= nil) then
self.domoticz.helpers = module.helpers
if (type(module) == 'table') then
skip = false
if (module.active ~= nil) then
local active = false
if (type(module.active) == 'function') then
active = module.active(self.domoticz)
if (not active) then
skip = true
if (not skip) then
if (module.on ~= nil and module['execute'] ~= nil) then
module.name = moduleName
module.type = moduleInfo.type
module.dataFileName = '__data_' .. moduleName
module.dataFilePath = _G.dataFolderPath .. '/__data_' .. moduleName .. '.lua'
table.insert(scripts, module)
utils.log(logScript .. moduleName .. '.lua has no "on" and/or "execute" section, not a dzVents module. Skipping', utils.LOG_DEBUG)
--table.insert(errModules, moduleName)
utils.log(logScript .. moduleName .. '.lua is not a dzVents module. Skipping', utils.LOG_DEBUG)
utils.log(module, utils.LOG_ERROR)
return scripts, errModules
function self.getEventBindings(mode, testTime)
local bindings = {}
local ok, i, event, j, device, err
local modules = {}
if not self.scripts then
self.scripts, self.errModules = loadEventScripts()
if (mode == nil) then mode = 'device' end
for i, module in pairs(self.scripts) do
local logScript = (module.type == 'external' and 'Script ' or 'Internal script ')
for j, event in pairs(module.on) do
if (not (type(j) == 'string' or type(event) == 'table')) then
utils.log(logScript .. module.name .. '.lua has a malformed on-section. Check the documentation. Skipping', utils.LOG_DEBUG)
if (mode == 'timer' and j == 'timer') then
-- { ['timer'] = { 'every minute ', 'every hour' } }
local triggered, def = self.processTimeRules(event)
if (triggered) then
-- this one can be executed
module.trigger = def
event.type = 'timer'
table.insert(bindings, module)
elseif (mode == 'device' and j == 'devices') then
-- { ['devices'] = { 'devA', ['devB'] = { ..timedefs }, .. }
for devIdx, devName in pairs(event) do
-- detect if devName is of the form ['devB'] = { 'every hour' }
if (type(devName) == 'table') then
local triggered, def = self.processTimeRules(devName, testTime)
if (triggered) then
addBindingEvent(bindings, devIdx, module)
-- a single device name (or id)
addBindingEvent(bindings, devName, module)
elseif (mode == 'scenegroups' and (j == 'scenes' or j == 'groups')) then
-- { ['scenes'] = { 'scA', ['scB'] = { ..timedefs }, .. }
for devIdx, scgrpName in pairs(event) do
-- detect if scgrpName is of the form ['devB'] = { 'every hour' }
if (type(scgrpName) == 'table') then
local triggered, def = self.processTimeRules(scgrpName, testTime)
if (triggered) then
-- a single scene or group name (or id)
addBindingEvent(bindings, scgrpName, module)
elseif (mode == 'variable' and j == 'variables') then
-- { ['variables'] = { 'varA', 'varB' }
for varIdx, varName in pairs(event) do
addBindingEvent(bindings, varName, module)
elseif (mode == 'security' and j == 'security') then
local triggered, def = self.checkSecurity(event, self.domoticz.security)
if (triggered) then
elseif (mode == 'httpResponse' and j == 'httpResponses') then
-- { ['httpResponses'] = { 'callbackA', 'callbackB' }
for i, callbackName in pairs(event) do
addBindingEvent(bindings, callbackName, module)
elseif (mode == 'system' and j == 'system') then
-- { ['system'] = { 'start', 'end' }
for evtIdx, systemEvent in pairs(event) do
-- detect if system is of the form ['start'] = { 'every hour' }
if (type(systemEvent) == 'table') then
local triggered, def = self.processTimeRules(systemEvent, testTime)
if (triggered) then
addBindingEvent(bindings, evtIdx, module)
-- a single system event
addBindingEvent(bindings, systemEvent, module)
elseif (mode == 'customEvents' and j == 'customEvents') then
-- { customEvents = { 'myEvent', ['anotherEvent'] = { ... timeDefs ... } }
for evtIdx, customEventName in pairs(event) do
-- detect if customEvent is of the form ['myEvent'] = { 'every hour' }
if (type(customEventName) == 'table') then
local triggered, def = self.processTimeRules(customEventName, testTime)
if (triggered) then
-- a single custom event
addBindingEvent(bindings, customEventName, module)
return bindings, self.errModules
function self.dumpCommandArray(commandArray, fromIndex, force)
local printed = false
local level = utils.LOG_DEBUG
if (fromIndex == nil) then
fromIndex = 1
if (force == true and force ~= nil or globalvariables['testmode'] == true) then
level = utils.LOG_INFO
for k, v in pairs(commandArray) do
if ((fromIndex ~= nil and k >= fromIndex) or fromIndex == nil) then
if (not printed) then
utils.log('Commands sent to Domoticz: ', level)
if (type(v) == 'table') then
for kk, vv in pairs(v) do
utils.log('- ' .. kk .. ' = ' .. _.str(vv), level)
utils.log(k .. ' = ' .. v, level)
printed = true
if (printed) then utils.log('=====================================================', level) end
function self.findScriptForTarget(target, allEventScripts)
local modules
-- only search for named and wildcard triggers,
-- id is done later
for scriptTrigger, scripts in pairs(allEventScripts) do
if (string.find(scriptTrigger, '*')) then -- a wild-card was used
scriptTrigger = ('^' .. scriptTrigger:gsub("[%^$]","."):gsub("*", ".*") .. '$')
local function sMatch(text, match) -- specialized sanitized match function to allow combination of Lua magic chars in wildcards
local sanitizedMatch = match:gsub("([%%%(%)%[%]%+%-%?])", "%%%1") -- escaping all 'magic' chars except *, ., ^ and $
return text:match(sanitizedMatch)
if sMatch(target, scriptTrigger) then
if modules == nil then modules = {} end
for i, mod in pairs(scripts) do
table.insert(modules, mod)
if (scriptTrigger == target) then
-- there is trigger for this target
return modules
function self.dispatchDeviceEventsToScripts(domoticz)
if (domoticz == nil) then -- you can pass a domoticz object for testing purposes
domoticz = self.domoticz
local allEventScripts = self.getEventBindings()
domoticz.changedDevices().forEach( function(device)
local scriptsToExecute = self.findScriptForTarget(device.name, allEventScripts)
local idScripts = allEventScripts[device.id]
local caSize = _.size(self.domoticz.commandArray)
if (idScripts ~= nil) then
-- merge id scripts with name scripts
if (scriptsToExecute == nil) then
scriptsToExecute = {}
for i, mod in pairs(idScripts) do
table.insert(scriptsToExecute, mod)
if (scriptsToExecute ~= nil) then
utils.log('Handling events for: "' .. device.name .. '", value: "' .. tostring(device.state) .. '"', utils.LOG_MODULE_EXEC_INFO)
self.handleEvents(scriptsToExecute, device)
self.dumpCommandArray(self.domoticz.commandArray, caSize + 1)
end)
return self.domoticz.commandArray
function self.dispatchSceneGroupEventsToScripts(domoticz)
local allEventScripts = self.getEventBindings('scenegroups')
local processItem = function(item, loglabel)
utils.log(loglabel .. '-event for: ' .. item.name .. ' value: ' .. tostring(item.state), utils.LOG_DEBUG)
local scriptsToExecute = self.findScriptForTarget(item.name, allEventScripts)
local idScripts = allEventScripts[item.id]
utils.log('Handling events for: "' .. item.name .. '", value: "' .. tostring(item.state) .. '"', utils.LOG_MODULE_EXEC_INFO)
self.handleEvents(scriptsToExecute, item)
domoticz.changedScenes().forEach(function(scene)
processItem(scene, 'Scene')
end)
domoticz.changedGroups().forEach(function(group)
processItem(group, 'Group')
end)
function self.dispatchTimerEventsToScripts()
local scriptsToExecute = self.getEventBindings('timer')
self.handleEvents(scriptsToExecute)
self.dumpCommandArray(self.domoticz.commandArray)
function self.dispatchSecurityEventsToScripts()
local updates =_G.securityupdates
if (updates ~= nil) then
for i, securityState in pairs(updates) do
local security = {
baseType = domoticz.BASETYPE_SECURITY,
name = securityState
self.domoticz.security = securityState
local scriptsToExecute = self.getEventBindings('security', nil)
self.handleEvents(scriptsToExecute, security)
function self.dispatchVariableEventsToScripts(domoticz)
local allEventScripts = self.getEventBindings('variable')
domoticz.changedVariables().forEach(function(variable)
-- first search by name
local scriptsToExecute = self.findScriptForTarget(variable.name, allEventScripts)
-- search by id
scriptsToExecute = allEventScripts[variable.id]
utils.log('Handling variable-events for: "' .. variable.name .. '", value: "' .. tostring(variable.value) .. '"', utils.LOG_MODULE_EXEC_INFO)
self.handleEvents(scriptsToExecute, variable)
end)
function self.dispatchHTTPResponseEventsToScripts(domoticz)
local httpResponseScripts = self.getEventBindings('httpResponse')
local responses =_G.httpresponse
if (responses ~= nil) then
for i, response in pairs(responses) do
response.baseType = domoticz.BASETYPE_HTTP_RESPONSE
local callback = response.callback
local scriptsToExecute = self.findScriptForTarget(callback, httpResponseScripts)
utils.log('Handling httpResponse-events for: "' .. callback .. '"', utils.LOG_MODULE_EXEC_INFO)
self.handleEvents(scriptsToExecute, response)
function self.dispatchSystemEventsToScripts(domoticz)
if (_G.notification == nil) then
return
local systemEventScripts = self.getEventBindings('system', nil)
local systemEvents =_G.notification.domoticz
if (systemEvents ~= nil) then
for i, event in pairs(systemEvents) do
event.name = SystemEvent(self.domoticz, event)["type"]
if event.name == nil then
utils.log('System event "' .. event.type .. '" is not supported yet.', utils.LOG_ERROR)
event.baseType = domoticz.BASETYPE_SYSTEM_EVENT
local scriptsToExecute = self.findScriptForTarget(event.name, systemEventScripts)
utils.log('Handling system event for: "' .. event.name .. '"', utils.LOG_MODULE_EXEC_INFO)
self.handleEvents(scriptsToExecute, event)
function self.dispatchCustomEventsToScripts(domoticz)
return
local customEventScripts = self.getEventBindings('customEvents', nil)
local customEvents = _G.notification.customevent
if (customEvents ~= nil) then
for i, customEvent in pairs(customEvents) do
customEvent.name = customEvent.data.name
customEvent.baseType = domoticz.BASETYPE_CUSTOM_EVENT
local scriptsToExecute = self.findScriptForTarget(customEvent.name, customEventScripts)
utils.log('Handling Domoticz custom event for: "' .. customEvent.name .. '"', utils.LOG_MODULE_EXEC_INFO)
self.handleEvents(scriptsToExecute, customEvent)
function self.getEventSummary(domoticz)
local items = {}
local length = 0
table.insert(items, '- Device: ' .. device.name)
length = length + 1
end)
table.insert(items, '- Variable: ' .. variable.name)
length = length + 1
end)
local securityUpdates =_G.securityupdates
if (securityUpdates ~= nil) then
for i, securityState in pairs(securityUpdates) do
table.insert(items, '- Security: ' .. securityState)
length = length + 1
table.insert(items, '- Scene: ' .. scene.name)
length = length + 1
end)
table.insert(items, '- Group: ' .. group.name)
length = length + 1
end)
table.insert(items, '- HTTPResponse: ' .. response.callback)
length = length + 1
local domoticzEvents = _G.notification and _G.notification.domoticz or nil
if (domoticzEvents ~= nil) then
for i, domoticzEvent in pairs(domoticzEvents) do
table.insert(items, '- Domoticz: ' .. domoticzEvent.type) -- .. ' - ' .. domoticzEvent.status)
length = length + 1
local customEvents = _G.notification and _G.notification.customEvents or nil
if (dcustomEvents ~= nil) then
table.insert(items, '- Custom: ' .. customEvent.type) -- .. ' - ' .. customEvent.status)
length = length + 1
return items, length;
return self
return EventHelpers
