Timer function  [Solved]
jacobsentertainment
Domoticz version: 2021-1
Timer function
Post by jacobsentertainment »
How can i use seconds in an script, I mean I have an switch that toggles an other switch for 3 seconds.
I'm totally new to this dzvents script so go easy please ;)
Re: Timer function
jacobsentertainment wrote: Friday 19 March 2021 12:54 How can i use seconds in an script, I mean I have an switch that toggles an other switch for 3 seconds.
something like
return
    on =
        devices =
            'activatingSwitch', -- name of the switch that triggers the next one
    execute = function(dz)
        follower = dz.devices('name of follower switch')
        follower.switchOn().checkFirst()
        follower.switchOff().afterSec(3)
jacobsentertainment
Re: Timer function
waaren wrote: Friday 19 March 2021 14:00 something like
return
    on =
        devices =
Look good, ill give it a try tonight. Thanks!
Checked and works just fine, slowly getting somewhere :lol:
jacobsentertainment
Re: Timer function
Hi again,
I'm trying to expand this little script with an lux sensor, so the light will only be switched by the motion sensors when the amount of light outside is below a specific value.
What's going wrong here?
		devices = {
			'PIR3 overloop', 'PIR1 gang',
	    local Device1 = domoticz.devices(95)
    	    if (Device1 <= 180 ) then
	        follower = domoticz.devices(262)
            follower.switchOff().afterSec(185)
The log is returning; lua:11: attempt to compare table with number
I'm lost here.
Re: Timer function
jacobsentertainment wrote: Sunday 28 March 2021 17:51 What's going wrong here?
I'm lost here.
Your script tries to compare a device object (a table) with the value 180.
You probably want to compare the value of the lux attribute of that device with that number.
Please see the wiki for all available attributes in dzVents for all devicetypes.
The script could look like.
        devices = {
        local lux = domoticz.devices(95).lux
        local follower = domoticz.devices(262)
        if lux <= 180 and follower.state ~= 'On' then
            follower.switchOn()
jacobsentertainment
Re: Timer function
Thaks you're a star.
So for my info, I was only calling the device here
Where I should call teh value of the device
local Device1 = domoticz.devices(95).lux
I should do more reading in the wiki, but all this has to be done in the small moments I do have t home :D Time is precious..
Re: Timer function
jacobsentertainment wrote: Sunday 28 March 2021 21:58 So for my info, I was only calling the device here
Where I should call the value of the device
Almost. A device object has many attributes. Some generic and some specific for the devicetype. You were looking for the value of the attribute lux
to list some of the available attributes for a type lux sensor:
 hardwareName: Xiaomi
 unit: 43
 lux: 3
 inActive: true
 idx: 2676
 deviceSubType: Lux
 nValue: 0
 icon: lux
 customImage: 0
 deviceId: 000002B
 active: false
 _adapters:
       1: Lux device adapter
 description:
 hardwareType: Xiaomi Gateway
 baseType: device
 protected: false
 hardwareId: 33
 lastUpdate: 2021-03-28 21:41:47
 timedOut: false
 batteryLevel: 81
 deviceType: Lux
 isDevice: true
 signalLevel: 12
 state: 3
 sValue: 3
jacobsentertainment
Re: Timer function  [Solved]
Aha now I'm slowly getting it, Thanks!
jacobsentertainment
Re: Timer function
I tried to add an second device and so far the script ain't returning any errors but the second device isn't switching on.
What am I doing wrong here?
	active = true,
		timer = {
			'every 1 minutes'
	execute = function(domoticz)
		local myDevice1 = domoticz.devices('Lux')
		local myDevice2 = domoticz.devices(219)
		local myDevice3 = domoticz.devices(350)
                local LUX = myDevice1.lux
        domoticz.log(myDevice1.name .. ' ' .. LUX, domoticz.LOG_INFO)
        domoticz.log(myDevice2.name .. ' ' .. myDevice2.state, domoticz.LOG_INFO)
        domoticz.log(myDevice3.name .. ' ' .. myDevice3.state, domoticz.LOG_INFO)
		if (LUX <= 15 ) then
			myDevice2.switchOn()
			domoticz.log('Light info, The light ' .. myDevice2.name .. ' will be switched on due to low LUX', domoticz.LOG_INFO)
		elseif (LUX <= 15 ) then
			myDevice3.switchOn()
			domoticz.log('Light info, The light ' .. myDevice3.name .. ' will be switched on due to low LUX', domoticz.LOG_INFO)
			myDevices.switchOff()
Re: Timer function
jacobsentertainment wrote: Friday 07 May 2021 23:25 I tried to add an second device and so far the script ain't returning any errors but the second device isn't switching on.
The second condition is equal to the first condition so if the first is true the elseif will not be evaluated. If the first condition is false the condition after the elseif also evaluates to false
try
	active = true,
		timer = {
			'every 1 minutes'
jacobsentertainment
Re: Timer function
Thanks again! :P
