Access to a file from outside with http ......
sombretjc
Post by sombretjc »
I need to have access to a file contained in my domoticz server from outside in the form:
http: // mydomain / accesspath / file
I manage to access my server by doing http: // mydomain but as soon as I add the path to the file I have a 404 not found return
I specify that port 80 is open and redirected to my server.
Does anyone have an idea?
With many thanks
erem
Domoticz version: 2021.1
Re: Access to a file from outside with http ......
Post by erem »
check that the user running the http server has rights to the dir/file you are trying to access.
having said that, it is a BAD idea to open your server to the world using http.
at a minimum use https, failtoban, firewall rules etc.
and keep an offline backup.
Regards,
Rob
