hi,
i use a timer like this :
timer = {
'30 minutes after sunset',
but it doesnt start script, I think it hasn't worked for 1 week.
timer [SOLVED]
djalexnl
Re: timer
I also have the same problem...
After upgrading to 13080 this weekend all DZVENT scripts that have a trigger with ...after or before sunset or sunrise stopped working...
For example..
I noticed that the last 2 days my lights did not turn on after sunset... so i started testing with some test scripts...
For example..
active = true,
logging = {
level = domoticz.LOG_DEBUG, -- Select one of LOG_DEBUG, LOG_INFO, LOG_ERROR, LOG_FORCE to override system log level
marker = "TEST"
timer = {'10 minutes after sunset'},
local ErkerLampLinks = domoticz.devices(2692)
ErkerLampLinks.switchOn().checkFirst()
}- waaren
Re: timer
Thx for reporting. Will be fixed in next build.Alcloud wrote: Monday 15 March 2021 22:07Same problem hereafter or before sunset or sunrise stopped working..
- waaren
Re: timer
Should be fixed in build 13081. If you need it now you can already test by replacing <domoticz dir>/dzVents/runtime/Time.lua with below code but only if you are using a version with the described bug.
local utils = require('Utils')
local _MS -- kind of a cache so we don't have to extract ms every time
local gTimes --
local isEmpty = function(v)
return (v == nil or v == '')
local function getTimezone()
local diff = os.difftime(os.time(), os.time(os.date("!*t")))
return ( os.date('!*t').isdst and ( diff + 3600 ) ) or diff
local function getSMs(s)
local ms = 0
local parts = utils.stringSplit(s, '.') -- do string splitting instead of math stuff.. can't seem to get the floating points right
s = tonumber(parts[1])
if (parts[2] ~= nil) then
-- should always be three digits!!
ms = tonumber(parts[2])
return s, ms
local function parseDate(sDate)
return string.match(sDate, "(%d+)%-(%d+)%-(%d+)[%sT]+(%d+):(%d+):([0-9%.]+)")
local function _getMS()
if (_MS == nil) then
local dzCurrentTime = _G.globalvariables.currentTime
local y, mon, d, h, min, s = parseDate(dzCurrentTime)
local ms
s, ms = getSMs(s)
_MS = ms
return _MS
local getDiffParts = function(secDiff, ms, offsetMS)
-- ms is the ms part that should be added to secDiff to get 'sss.ms'
if (ms == nil) then
ms = 0
if (offsetMS == nil) then
offsetMS = 0
local secs = secDiff
local msDiff
msDiff = (secs * 1000) - ms + offsetMS
if (math.abs(msDiff) < 1000) then
secs = 0
local minDiff = math.floor(math.abs((secs / 60)))
local hourDiff = math.floor(math.abs((secs / 3600)))
local dayDiff = math.floor(math.abs((secs / 86400)))
local cmp
if (msDiff == 0) then
cmp = 0
elseif (msDiff > 0) then
cmp = -1
cmp = 1
return
math.abs(msDiff),
math.abs(secs),
minDiff,
hourDiff,
dayDiff,
cmp
-- week functions as taken from http://lua-users.org/wiki/WeekNumberInYear
-- Get day of a week at year beginning
--(tm can be any date and will be forced to 1st of january same year)
-- return 1=mon 7=sun
local function getYearBeginDayOfWeek(tm)
local yearBegin = os.time{year=os.date("*t",tm).year,month=1,day=1}
local yearBeginDayOfWeek = tonumber(os.date("%w",yearBegin))
-- sunday correct from 0 -> 7
if(yearBeginDayOfWeek == 0) then
yearBeginDayOfWeek = 7
return yearBeginDayOfWeek
-- tm: date (as returned from os.time)
-- returns basic correction to be add for counting number of week
-- weekNum = math.floor((dayOfYear + returnedNumber) / 7) + 1
-- (does not consider correction at begin and end of year)
local function getDayAdd(tm)
local yearBeginDayOfWeek = getYearBeginDayOfWeek(tm)
local dayAdd
if(yearBeginDayOfWeek < 5 ) then
-- first day is week 1
dayAdd = (yearBeginDayOfWeek - 2)
-- first day is week 52 or 53
dayAdd = (yearBeginDayOfWeek - 9)
return dayAdd
-- tm is date as returned from os.time()
-- return week number in year based on ISO8601
-- (week with 1st thursday since Jan 1st (including) is considered as Week 1)
-- (if Jan 1st is Fri,Sat,Sun then it is part of week number from last year -> 52 or 53)
local function getWeekNumberOfYear(tm)
local dayOfYear = os.date("%j",tm)
local dayAdd = getDayAdd(tm)
local dayOfYearCorrected = dayOfYear + dayAdd
if(dayOfYearCorrected < 0) then
-- week of last year - decide if 52 or 53
local lastYearBegin = os.time{year=os.date("*t",tm).year-1,month=1,day=1}
local lastYearEnd = os.time{year=os.date("*t",tm).year-1,month=12,day=31}
dayAdd = getDayAdd(lastYearBegin)
dayOfYear = dayOfYear + os.date("%j",lastYearEnd)
local weekNum = math.floor((dayOfYearCorrected) / 7) + 1
if( (dayOfYearCorrected > 0) and weekNum == 53) then -- check if it is not considered as part of week 1 of next year
local nextYearBegin = os.time{year=os.date("*t",tm).year+1,month=1,day=1}
local yearBeginDayOfWeek = getYearBeginDayOfWeek(nextYearBegin)
weekNum = 1
return weekNum
local function Time(sDate, isUTC, _testMS)
local LOOKUPDAYABBROFWEEK = { 'sun', 'mon', 'tue', 'wed', 'thu', 'fri', 'sat' }
local LOOKUPDAYNAME = { 'Sunday', 'Monday', 'Tuesday', 'WednesDay', 'Thursday', 'Friday', 'Saturday' }
local LOOKUPMONTHABBR = { 'jan', 'feb', 'mar', 'apr', 'may', 'jun', 'jul', 'aug', 'sep', 'oct', 'nov', 'dec' }
local LOOKUPMONTH = { 'January', 'February', 'March', 'April', 'May', 'June', 'July', 'August', 'September', 'October', 'November', 'December' }
local ms
local now
local time = {}
local localTime = {} -- nonUTC
local self
local getMS = function()
if (_testMS ~= nil) then
return _testMS
return _getMS()
if isUTC and isUTC == true then
now = os.date('!*t')
now = os.date('*t')
isUTC = false
local function makesDate()
local now
if (isUTC) then
now = os.date('*t')
local ms = _testMS == nil and getMS() or _testMS
return ( now.year .. '-' .. now.month ..'-' .. now.day .. ' ' .. now.hour .. ':' .. now.min .. ':' .. now.sec .. '.' .. tostring(ms) )
if sDate == nil or sDate == '' then
sDate = makesDate()
local y, mon, d, h, min, s = parseDate(sDate)
if not(y and mon and d and h and min and s) then
sDate = makesDate()
utils.log('sDate was invalid. Reset to ' .. sDate , utils.LOG_ERROR)
-- extract s and ms
s, ms = getSMs(s)
local dDate = os.time{year=y,month=mon,day=d,hour=h,min=min,sec=s }
time = os.date('*t', dDate)
local tToday = os.time{
day= now.day,
year= now.year,
month= now.month,
hour= now.hour,
min= now.min,
sec= now.sec
-- calculate how many minutes that was from now
local msDiff, secDiff, minDiff, hourDiff, dayDiff, cmp = getDiffParts(os.difftime(tToday, dDate), ms, getMS())
if (cmp > 0) then -- time is in the future so the xxAgo items should be negative
msDiff = -msDiff
secDiff = -secDiff
minDiff = -minDiff
hourDiff = -hourDiff
dayDiff = -dayDiff
if (isUTC) then
localTime = os.date('*t', os.time(time) + getTimezone())
self = localTime
self.utcSystemTime = now
self.utcTime = time
self.utcTime.minutes = time.min
self.utcTime.seconds = time.sec
self = time
self.rawDate = self.year .. '-' .. string.format("%02d", self.month) .. '-' .. string.format("%02d", self.day)
self.time = string.format("%02d", self.hour) .. ':' .. string.format("%02d", self.min)
self.minutesnow = self.hour * 60 + self.min
self.rawTime = self.time .. ':' .. string.format("%02d", self.sec)
self.rawDateTime = self.rawDate .. ' ' .. self.rawTime
self.milliSeconds = ms
self.milliseconds = ms
self.dayAbbrOfWeek = LOOKUPDAYABBROFWEEK[self.wday]
self.dayName = LOOKUPDAYNAME[self.wday]
self.monthAbbrName = LOOKUPMONTHABBR[self.month]
self.monthName = LOOKUPMONTH[self.month]
-- Note: %V doesn't work on Windows so we have to use a custom function here
-- doesn't work: self.week = tonumber(os.date('%V', dDate))
self.week = getWeekNumberOfYear(dDate)
self.raw = sDate
self.isToday = (now.year == time.year and now.month == time.month and now.day == time.day)
self.msAgo = math.floor(msDiff)
self.millisecondsAgo = self.msAgo
self.minutesAgo = minDiff
self.secondsAgo = math.floor(secDiff)
self.hoursAgo = hourDiff
self.daysAgo = dayDiff
self.minutes = self.min
self.seconds = self.sec
self.minutesSinceMidnight = self.hour * 60 + self.min
self.secondsSinceMidnight = self.minutesSinceMidnight * 60 + self.sec
self.utils = utils
self.isUTC = isUTC
self.dDate = dDate
self.isdst = time.isdst
if (_G.TESTMODE) then
_G = _G or {} -- Only used when testing testTime.lua
_G.timeofday = _G.timeofday or {} -- Only used when testing testTime.lua
function self._getUtilsInstance()
return utils
self.current = os.date('*t')
-- compares to self against the provided Time object (t)
function self.compare(t)
if (t.raw ~= nil) then
getDiffParts(os.difftime(dDate, t.dDate), t.milliseconds, ms) -- offset is 'our' ms value
mins = minDiff,
hours = hourDiff,
secs = math.floor(secDiff),
seconds = math.floor(secDiff),
minutes = minDiff,
days = dayDiff,
ms = math.floor(msDiff),
milliseconds = math.floor(msDiff),
compare = cmp -- 0 == equal, -1==(t earlier than self), 1=(t later than self)
utils.log('Invalid time format passed to diff. Should a Time object', utils.LOG_ERROR)
function self.localeMonths()
local months =
january = 1, february = 2, march = 3, april = 4, may = 5, june = 6, july = 7, august = 8,
september = 9, october = 10, november = 11, december = 12, jan = 1, feb = 2, mar = 3, apr = 4,
jun = 6, jul = 7, aug = 8, sep = 9, oct = 10, nov = 11, dec = 12
local monthSeconds = 2678400 -- accurate enough for this purpose
local startSeconds = 1577833200 -- 2020-1-1 00:00
for monthNumber = 1, 12 do
months[os.date('%B', startSeconds + ( monthNumber - 1 ) * monthSeconds ):sub(1,3):lower()] = monthNumber
months[os.date('%b', startSeconds + ( monthNumber - 1 ) * monthSeconds ):lower()] = monthNumber
return months
function self.dateToTimestamp(dateString, control)
local tm, dateTable, format = {}, {}, {}
local pattern
if control and control:find('%%') then
pattern = control
elseif control ~= nil then -- control = format
local index = 1
for word in control:gmatch("%w+") do table.insert(format, word) end
for value in dateString:gmatch("%w+") do
dateTable[format[index]] = value
index = index + 1
tm.year = dateTable.yyyy or ( dateTable.yy and ( dateTable.yy + 2000 )) or os.date('%Y')
tm.month = dateTable.mm or
( dateTable.mmm and self.localeMonths()[dateTable.mmm:lower()]) or
( dateTable.mmmm and self.localeMonths()[dateTable.mmmm:lower()]) or 1
tm.day = dateTable.dd or 1
tm.hour = dateTable.hh or 0
tm.min = dateTable.MM or 0
tm.sec = dateTable.ss or 0
return os.time(tm)
pattern = pattern or '(%d+)%D+(%d+)%D+(%d+)%D+(%d+)%D+(%d+)' -- yyyy-mm--dd hh:mm
tm.year, tm.month, tm.day, tm.hour, tm.min, tm.sec = dateString:match(pattern)
return os.time(tm)
function self.timestampToDate(timestamp, humanizedPattern, offSet)
local function convertMnemomic2FmtCode(humanizedPattern)
local humanizedPattern = humanizedPattern or 'yyyy-mm-dd hh:MM:ss'
mnemomics =
{'dddd' , '%A'}, -- full weekdayname(e.g. Wednesday) language depends on locale
{'ddd' , '%a'}, -- abbreviated weekdayname(e.g. Wed) language depends on locale
{'dd' , '%d'}, -- day of the month(16){[01-31]
{'mmmm' , '%B'}, -- full monthname(e.g September) language depends on locale
{'mmm' , '%b'}, -- abbreviated monthname(e.g. Sep) language depends on locale
{'mm' , '%m'}, -- month[01-12]
{'yyyy' , '%Y'}, -- 4-digit year
{'yy' , '%y'}, -- two-digityear(98){[00-99]
{'hh' , '%H'}, -- hour 24-hour clock){[00-23]
{'ii' , '%I'}, -- hour 12-hour clock[01-12]
{'MM' , '%M'}, -- minute{[00-59]
{'ss' , '%S'}, -- second [00-60]
{'W' , '%W'}, -- weeknumber [01-53]
{'w' , '%w'}, -- weekday{[0-6] Sunday-Saturday
{'datm' , '%c'}, -- date and time (e.g. 09/16/98 23:48:10) format depends on locale
{'mer' , '%p'}, -- either "am" or "pm" locale
{'date' , '%x'}, -- date(e.g. 09/16/98) format depends on locale
{'time' , '%X'}, -- time(e.g. 23:48:10)
for _, conversion in ipairs(mnemomics) do
humanizedPattern = string.gsub(humanizedPattern, conversion[1], '%' .. conversion[2])
return humanizedPattern
local timestamp = ( timestamp or os.time() ) + ( offSet or 0 )
local dateTimeString = os.date( convertMnemomic2FmtCode(humanizedPattern) , timestamp )
if dateTimeString:find('nZero') then -- remove leading zero's
return dateTimeString:gsub('nZero',''):gsub(' 0',' '):gsub('^0',''):gsub('%s*$','')
return dateTimeString:gsub('%s*$','')
function self.dateToDate(date, sourceFormat, targetFormat, offSet )
return self.timestampToDate(self.dateToTimestamp(date,sourceFormat), targetFormat, offSet)
function self.addSeconds(seconds, factor)
if type(seconds) ~= 'number' then
self.utils.log(tostring(seconds) .. ' is not a valid parameter to this function. Please change to use a number value!', utils.LOG_ERROR)
factor = factor or 1
return Time( os.date("%Y-%m-%d %X", self.dDate + factor * math.floor(seconds) ))
function self.addDays(days)
return self.addSeconds(days, 24 * 3600)
function self.addHours(hours)
return self.addSeconds(hours, 3600)
function self.addMinutes(minutes)
return self.addSeconds(minutes, 60)
function self.makeTime(oDate, isUTC)
local sDate = ( type(oDate) == 'table' and os.date("%Y-%m-%d %H:%M:%S", os.time(oDate)) ) or
( tonumber(oDate) and self.timestampToDate(oDate) ) or oDate
return Time(sDate, isUTC)
function self.toUTC(oDate, offset)
local sDate = ( type(oDate) == 'table' and os.date("%Y-%m-%d %H:%M:%S", os.time(oDate)) ) or oDate
local offset = offset or 0
return Time(sDate).addSeconds(-1 * getTimezone() + offset).raw
-- return ISO format
function self.getISO()
return os.date("!%Y-%m-%dT%TZ", os.time(time))
-- returns hours part and minutes part of the passed-in minutes amount
function minutesToTime(minutes)
local hh = math.floor(minutes / 60)
local mm = minutes - (hh * 60)
return hh, mm
-- returns true if the current time is within a time range: startH:startM and stopH:stopM
local function timeIsInRange(startH, startM, stopH, stopM)
local function getMinutes(hours, minutes)
return (hours * 60) + minutes
local currentMinutes = getMinutes(self.hour, self.min)
local startMinutes = getMinutes(startH, startM)
local stopMinutes = getMinutes(stopH, stopM)
if stopMinutes < startMinutes then -- add 24 hours (1440 minutes ) if endTime < startTime
if currentMinutes < stopMinutes then currentMinutes = currentMinutes + 1440 end
stopMinutes = stopMinutes + 1440
return ( currentMinutes >= startMinutes and currentMinutes <= stopMinutes )
-- returns true if self.day is on the rule: on day1,day2...
function self.ruleIsOnDay(rule)
local days = string.match(rule, '%s+on%s+(.+)$') or string.match(rule, '^%s*on%s+(.+)$')
if (isEmpty(days)) then
return nil
local isDayRule = false
for i,day in pairs({'mon', 'tue', 'wed', 'thu', 'fri', 'sat', 'sun'}) do
if (string.find(days, day) ~= nil) then
isDayRule = true
break
if (not isDayRule) then
return nil
if (days ~= nil) then -- on <day>' was specified
local hasDayMatch = string.find(days, self.dayAbbrOfWeek)
if (hasDayMatch) then
return true
return false
return nil
-- returns true if self.week matches rule in week 1,3,4 / every odd-week, every even-week, in week 5-12,23,44
function self.ruleIsInWeek(rule)
if (string.find(rule, 'every odd week') and not ((self.week % 2) == 0)) then
return true
elseif (string.find(rule, 'every even week') and ((self.week % 2) == 0)) then
return true
elseif string.find(rule, 'every even week') or string.find(rule, 'every odd week') then
return false
local weeks = string.match(rule, 'in week% ([0-9%-%,% ]*)')
if (weeks == nil) then
return nil
-- from here on, if there is a match we return true otherwise false
-- remove spaces and add a comma
weeks = string.gsub(weeks, ' ', '') .. ',' -- remove spaces and add a ',' so we can do simple search for the number
-- do a quick scan first to see if we already have a match without needing to search for ranges
if (string.find(weeks, tostring(self.week) .. ',')) then
return true
-- now get the ranges
for set, from, to in string.gmatch(weeks, '(([0-9]*)-([0-9]*))') do
to = tonumber(to)
from = tonumber(from)
if (isEmpty(from) and not isEmpty(to) and self.week <= to ) then
return true
if (not isEmpty(from) and isEmpty(to) and self.week >= from ) then
return true
if (not isEmpty(from) and not isEmpty(to) and to ~= nil) then
if (self.week >= from and self.week <= to) then
return true
return false
function self.ruleIsOnDate(rule)
local dates = string.match(rule, 'on% ([0-9%*%/%,% %-]*)')
if (isEmpty(dates)) then
return nil
local _ = require('lodash')
local dateTable = utils.stringSplit(dates,',') -- get all date(ranges)
dates = string.gsub(dates, ' ', '') .. ',' --remove spaces and add a , so we can do simple search for the number
-- do a quick scan first to see if we already have a match without needing to search for ranges and wildcards
for index, value in ipairs(dateTable) do
if tonumber(value:match('%d+')) == self.day and tonumber(value:match('/(%d+)')) == self.month then
return true
-- wildcards
for set, day, month in string.gmatch(dates, '(([0-9%*]*)/([0-9%*]*))') do
if (day == '*' and month ~= '*') then
if (self.month == tonumber(month)) then
return true
if (day ~= '*' and month == '*') then
if (self.day == tonumber(day)) then
return true
local getParts = function(set)
local day, month = string.match(set, '([0-9%*]+)/([0-9%*]+)')
return day and tonumber( day ), month and tonumber( month )
--now get the ranges
for fromSet, toSet in string.gmatch(dates, '([0-9%/%*]*)-([0-9%/%*]*)') do
local fromDay, toDay, fromMonth, toMonth
if (isEmpty(fromSet) and not isEmpty(toSet)) then
toDay, toMonth = getParts(toSet)
if ((self.month < toMonth) or (self.month == toMonth and self.day <= toDay)) then
return true
elseif (not isEmpty(fromSet) and isEmpty(toSet)) then
fromDay, fromMonth = getParts(fromSet)
if ((self.month > fromMonth) or (self.month == fromMonth and self.day >= fromDay)) then
return true
if
( self.month > fromMonth and self.month < toMonth ) or
( fromMonth == toMonth and self.month == fromMonth and self.day >= fromDay and self.day <= toDay ) or
( self.month == fromMonth and toMonth < fromMonth and self.day >= fromDay ) or
( self.month == fromMonth and toMonth > fromMonth and self.day >= fromDay ) or
( self.month == toMonth and toMonth < fromMonth and self.day <= toDay ) or
( self.month == toMonth and toMonth > fromMonth and self.day <= toDay )
) then
return true
return false
function self.ruleIsBeforeAstrologicalMoment(rule)
local minutes = tonumber(string.match(rule, '%.*(%d+)%s+minutes%s+before%.*'))
local astronomicalString = rule:match('minutes%s+before%s+(%a+)') or ''
local moment = tonumber(gTimes[astronomicalString .. 'inminutes']) or ''
if minutes ~= nil and moment ~= '' then
return ( self.minutesnow + minutes ) == moment
return nil
function self.ruleIsAfterAstrologicalMoment(rule)
local minutes = tonumber(string.match(rule, '%.*(%d+)%s+minutes%s+after%.*'))
local astronomicalString = rule:match('minutes%s+after%s+(%a+)') or ''
return ( self.minutesnow - minutes ) == moment
return nil
-- returns true if self.time is at a astronomical moment
-- sunset, sunrise, CivilTwilightEnd, NautTwilightStart, etc
function self.ruleIsAtAstronomicalMoment(rule)
local astronomicalString = rule:match('at%s+(%a+)') or ''
local moment = tonumber(gTimes[astronomicalString .. 'inminutes']) or -1
return moment == self.minutesnow or nil
-- returns true if self.time is at a astronomical range
-- daytime, nightime, etc
function self.ruleIsAtAstronomicalRange(rule)
if type(gTimes[astronomicalString]) == 'boolean' then
return gTimes[astronomicalString] or nil
-- returns true if self.min fits in the every xx minute /every other minute/every minute rule
function self.ruleMatchesMinuteSpecification(rule)
local function fitsMinuteRule(m)
return (self.min / m == math.floor(self.min / m))
if (string.find(rule, 'every minute')) then
return true
if (string.find(rule, 'every other minute')) then
return fitsMinuteRule(2)
local minutes = tonumber(string.match(rule, 'every (%d+) minutes'))
if (minutes ~= nil) then
if ((60 / minutes) ~= math.floor(60 / minutes) or minutes >= 60) then
self.utils.log(rule .. ' is not a valid timer definition. Can only run every 1, 2, 3, 4, 5, 6, 10, 12, 15, 20 and 30 minutes.', utils.LOG_ERROR)
return false
return fitsMinuteRule(minutes)
return nil -- nothing specified for this rule
-- return true if self.hour fits the every hour/every other hour/every xx hours rule
function self.ruleMatchesHourSpecification(rule)
local function fitsHourRule(h)
-- always fit every whole hour (hence the self.min == 0)
return (self.hour / h == math.floor(self.hour / h) and self.min == 0)
if (string.find(rule, 'every hour')) then
return fitsHourRule(1)
if (string.find(rule, 'every other hour')) then
return fitsHourRule(2)
local hours = tonumber(string.match(rule, 'every% (%d+)% hours'))
if (hours ~= nil) then
if ((24 / hours) ~= math.floor(24 / hours) or hours >= 24) then
self.utils.log(rule .. ' is not a valid timer definition. Can only run every 1, 2, 3, 4, 6, 8, 12 hours.', utils.LOG_ERROR)
return false
return fitsHourRule(hours)
-- return true if self.time is at hh:mm / *:mm/ hh:*
function self.ruleMatchesTime(rule)
local hh, mm
local timePattern = 'at% ([0-9%*]+):([0-9%*]+)'
hh, mm = string.match(rule, timePattern .. '% ')
if (hh == nil or mm == nil) then
-- check for end-of string
hh, mm = string.match(rule, timePattern .. '$')
if (hh ~= nil) then
if (mm == '*') then
return (self.hour == tonumber(hh))
elseif (hh == '*') then
return (self.min == tonumber(mm))
--elseif (hh ~= '*' and hh ~= '*') then
hh = tonumber(hh)
mm = tonumber(mm)
if (hh ~= nil and mm ~= nil) then
return (mm == self.min and hh == self.hour)
-- invalid
return false
return nil -- no at hh:mm found in rule
-- returns true if self.time is in time range: at hh:mm-hh:mm
function self.ruleMatchesTimeRange(rule)
local fromH, fromM, toH, toM = string.match(rule, 'at% ([0-9%*]+):([0-9%*]+)-([0-9%*]+):([0-9%*]+)')
if (fromH ~= nil) then
-- all will be nil if fromH is nil
fromH = tonumber(fromH)
fromM = tonumber(fromM)
toH = tonumber(toH)
toM = tonumber(toM)
if (fromH == nil or fromM == nil or toH == nil or toM == nil) then -- invalid format
return false
return timeIsInRange(fromH, fromM, toH, toM)
return nil
-- returns true if 'moment' matches with any of the moment-like time rules
function getMoment(moment)
local minutes, astrologicalMoment
-- first check if it in the form of hh:mm
hh, mm = string.match(moment, '([0-9]+):([0-9]+)')
return tonumber(hh), tonumber(mm)
-- check if it is before astroMoment
minutes, astrologicalMoment = string.match(moment, '%.*(%d+)%s+minutes%s+before%s+(%a+)')
if minutes and astrologicalMoment then
return minutesToTime(gTimes[astrologicalMoment .. 'inminutes'] - tonumber(minutes))
-- check if it is after astroMoment
minutes, astrologicalMoment = string.match(moment, '%.*(%d+)%s+minutes%s+after%s+(%a+)')
return minutesToTime(gTimes[astrologicalMoment .. 'inminutes'] + tonumber(minutes))
-- check at astroMoment
if (gTimes[moment .. 'inminutes']) then
return minutesToTime(gTimes[moment .. 'inminutes'])
return nil
-- returns true if self.time is in a between xx and yy range
function self.ruleMatchesBetweenRange(rule)
local from, to = string.match(rule, 'between% (.+)% and% (.+)')
if (from == nil or to == nil) then
return nil
local fromHH, fromMM, toHH, toMM
fromHH, fromMM = getMoment(from)
toHH, toMM = getMoment(to)
if (fromHH == nil or fromMM == nil or toHH == nil or toMM == nil) then
return nil
return timeIsInRange(fromHH, fromMM, toHH, toMM)
-- remove seconds from timeStrings 'at 12:23:56-23:45:00 ==>> 'at 12:23-23:45'
-- to allow use of rawTime in matchesRule
local function sanitize(rule)
if not rule:match("(%w+%:%w+:%w+)") then return rule end
for strippedTime in rule:gmatch("(%w+%:%w+)") do
if strippedTime:match("(%w+%:%w+:%w+)") then rule = rule:gsub(rule:match("(%w+%:%w+:%w+)"),rule:match(strippedTime)) end
return rule
local function populateAstrotimes()
local LOOKUPASTRO =
CivTwilightEndInMinutes = 'civiltwilightendinminutes',
AstrTwilightStartInMinutes = 'astronomicaltwilightstartinminutes',
AstrTwilightEndInMinutes = 'astronomicaltwilightendinminutes',
SunAtSouthInMinutes = 'solarnooninminutes',
NautTwilightEndInMinutes = 'nauticaltwilightendinminutes',
NautTwilightStartInMinutes = 'nauticaltwilightstartinminutes',
CivTwilightStartInMinutes = 'civiltwilightstartinminutes',
Daytime = 'daytime',
SunsetInMinutes = 'sunsetinminutes',
Civildaytime = 'civildaytime',
Civilnighttime = 'civilnighttime',
SunriseInMinutes = 'sunriseinminutes',
Nighttime = 'nighttime',
gTimes = {}
for originalName, dzVentsName in pairs(LOOKUPASTRO) do
gTimes[dzVentsName] = _G.timeofday[originalName]
gTimes.sunatsouthinMinutes = gTimes.solarnooninminutes
gTimes.astronomicaldaytime = ( self.minutesnow <= (gTimes.astronomicaltwilightendinminutes or 0) and self.minutesnow >= (gTimes.astronomicaltwilightstartinminutes or 9999))
gTimes.nauticaldaytime = (self.minutesnow <= (gTimes.nauticaltwilightendinminutes or 0) and self.minutesnow >= (gTimes.nauticaltwilightstartinminutes or 9999))
gTimes.nauticalnighttime = not(gTimes.nauticaldaytime)
gTimes.astronomicalnighttime = not(gTimes.astronomicaldaytime)
return true
-- returns true if self.time matches the rule
function self.matchesRule(rule, processed)
if type(rule) == 'string' and ( string.len(rule == nil and "" or rule) == 0) then
return false
-- split into atomic time rules to simplify and speedup processing
elseif type(rule) == 'string' and not(processed) then
local rule = rule:lower()
local validPositiveRules = true
local negativeKeyword = 'except'
local function ruleSplit(rawRule)
local ruleKeywords = 'on, between, every, in'
local allRules = {}
local aRule = ''
for ruleWord in string.gmatch(rawRule, "[%S]+") do -- all "words" separated by spaces
if ruleKeywords:find(ruleWord) and aRule ~= '' then
table.insert(allRules, aRule)
aRule = ''
aRule = ( aRule == '' and ruleWord ) or ( aRule .. ' ' .. ruleWord )
if aRule ~= '' then table.insert(allRules, aRule) end
return allRules or {}
local positiveRules, negativeRules
local exceptPosition = rule:find(negativeKeyword)
if exceptPosition then
positiveRules = ruleSplit(rule:sub(1, exceptPosition - 1))
negativeRules = ruleSplit(rule:sub(exceptPosition + #negativeKeyword, #rule))
negativeRules = nil
positiveRules = ruleSplit(rule)
for _, aRule in ipairs(positiveRules) do
validPositiveRules = validPositiveRules and self.matchesRule(aRule, true)
if validPositiveRules == false then return false end
for _, aRule in ipairs( negativeRules) do
if self.matchesRule(aRule, true) then return false end
return validPositiveRules
local res
local total = false
local function updateTotal(res)
total = res ~= nil and (total or res) or total
res = self.ruleIsInWeek(rule)
if (res == false) then --in week <weeks> was specified but 'now' is not on any of the specified weeks
return false
updateTotal(res)
res = self.ruleIsOnDay(rule) -- range
if (res == false) then -- on <days> was specified but 'now' is not on any of the specified days
return false
updateTotal(res)
res = self.ruleIsOnDate(rule)
if (res == false) then -- on date <dates> was specified but 'now' is not on any of the specified dates
return false
updateTotal(res)
local _between = self.ruleMatchesBetweenRange(rule) -- range
if (_between == false) then -- rule had between xxx and yyy is not in that range now
return false
res = _between
updateTotal(res)
if (_between == nil) then -- there was not a between rule.
-- A between-range can have before/after sunrise/set rules so it cannot be combined with these here
res = self.ruleIsBeforeAstrologicalMoment(rule) -- moment
if (res == false) then -- (sub)rule has before xxstart, xxend, sunset, sunrise or solarnoon
return false
updateTotal(res)
res = self.ruleIsAfterAstrologicalMoment(rule) -- moment
if (res == false) then -- (sub)rule has after xxstart, xxend, sunset, sunrise or solarnoon
return false
updateTotal(res)
res = self.ruleIsAtAstronomicalMoment(rule)
if (res == false) then -- rule has at xxstart, xxend, sunset, sunrise or solarnoon
return false
updateTotal(res)
res = self.ruleIsAtAstronomicalRange(rule)
if (res == false) then -- rule has at xxdaytime or xx nighttime
return false
updateTotal(res)
res = self.ruleMatchesHourSpecification(rule) -- moment
if (res == false) then -- rule has every xx hour but its not the right time
return false
updateTotal(res)
res = self.ruleMatchesMinuteSpecification(rule) -- moment
if (res == false) then -- rule has every xx minute but its not the right time
return false
updateTotal(res)
rule = sanitize(rule)
res = self.ruleMatchesTime(rule) -- moment / range
if (res == false) then -- rule has at hh:mm part but didn't match (or was invalid)
return false
updateTotal(res)
res = self.ruleMatchesTimeRange(sanitize(rule)) -- range
if (res == false) then -- rule has at hh:mm-hh:mm but time is not in that range now
return false
updateTotal(res)
return total
return self
return Time
djalexnl
Re: timer
Just updated, lets see what happends tonight
Ill let you know
Thanks again for the fast fix etc...
Ill let you know
waaren wrote: Monday 15 March 2021 23:52Should be fixed in build 13081. If you need it now you can already test by replacing <domoticz dir>/dzVents/runtime/Time.lua with below code but only if you are using a version with the described bug.
local utils = require('Utils') local _MS -- kind of a cache so we don't have to extract ms every time local gTimes -- local isEmpty = function(v) return (v == nil or v == '') end local function getTimezone() local diff = os.difftime(os.time(), os.time(os.date("!*t"))) return ( os.date('!*t').isdst and ( diff + 3600 ) ) or diff end local function getSMs(s) local ms = 0 local parts = utils.stringSplit(s, '.') -- do string splitting instead of math stuff.. can't seem to get the floating points right s = tonumber(parts[1]) if (parts[2] ~= nil) then -- should always be three digits!! ms = tonumber(parts[2]) end return s, ms end local function parseDate(sDate) return string.match(sDate, "(%d+)%-(%d+)%-(%d+)[%sT]+(%d+):(%d+):([0-9%.]+)") end local function _getMS() if (_MS == nil) then local dzCurrentTime = _G.globalvariables.currentTime local y, mon, d, h, min, s = parseDate(dzCurrentTime) local ms s, ms = getSMs(s) _MS = ms end return _MS end local getDiffParts = function(secDiff, ms, offsetMS) -- ms is the ms part that should be added to secDiff to get 'sss.ms' if (ms == nil) then ms = 0 end if (offsetMS == nil) then offsetMS = 0 end local secs = secDiff local msDiff msDiff = (secs * 1000) - ms + offsetMS if (math.abs(msDiff) < 1000) then secs = 0 end local minDiff = math.floor(math.abs((secs / 60))) local hourDiff = math.floor(math.abs((secs / 3600))) local dayDiff = math.floor(math.abs((secs / 86400))) local cmp if (msDiff == 0) then cmp = 0 elseif (msDiff > 0) then cmp = -1 else cmp = 1 end return math.abs(msDiff), math.abs(secs), minDiff, hourDiff, dayDiff, cmp end -- week functions as taken from http://lua-users.org/wiki/WeekNumberInYear -- Get day of a week at year beginning --(tm can be any date and will be forced to 1st of january same year) -- return 1=mon 7=sun local function getYearBeginDayOfWeek(tm) local yearBegin = os.time{year=os.date("*t",tm).year,month=1,day=1} local yearBeginDayOfWeek = tonumber(os.date("%w",yearBegin)) -- sunday correct from 0 -> 7 if(yearBeginDayOfWeek == 0) then yearBeginDayOfWeek = 7 end return yearBeginDayOfWeek end -- tm: date (as returned from os.time) -- returns basic correction to be add for counting number of week -- weekNum = math.floor((dayOfYear + returnedNumber) / 7) + 1 -- (does not consider correction at begin and end of year) local function getDayAdd(tm) local yearBeginDayOfWeek = getYearBeginDayOfWeek(tm) local dayAdd if(yearBeginDayOfWeek < 5 ) then -- first day is week 1 dayAdd = (yearBeginDayOfWeek - 2) else -- first day is week 52 or 53 dayAdd = (yearBeginDayOfWeek - 9) end return dayAdd end -- tm is date as returned from os.time() -- return week number in year based on ISO8601 -- (week with 1st thursday since Jan 1st (including) is considered as Week 1) -- (if Jan 1st is Fri,Sat,Sun then it is part of week number from last year -> 52 or 53) local function getWeekNumberOfYear(tm) local dayOfYear = os.date("%j",tm) local dayAdd = getDayAdd(tm) local dayOfYearCorrected = dayOfYear + dayAdd if(dayOfYearCorrected < 0) then -- week of last year - decide if 52 or 53 local lastYearBegin = os.time{year=os.date("*t",tm).year-1,month=1,day=1} local lastYearEnd = os.time{year=os.date("*t",tm).year-1,month=12,day=31} dayAdd = getDayAdd(lastYearBegin) dayOfYear = dayOfYear + os.date("%j",lastYearEnd) dayOfYearCorrected = dayOfYear + dayAdd end local weekNum = math.floor((dayOfYearCorrected) / 7) + 1 if( (dayOfYearCorrected > 0) and weekNum == 53) then -- check if it is not considered as part of week 1 of next year local nextYearBegin = os.time{year=os.date("*t",tm).year+1,month=1,day=1} local yearBeginDayOfWeek = getYearBeginDayOfWeek(nextYearBegin) if(yearBeginDayOfWeek < 5 ) then weekNum = 1 end end return weekNum end local function Time(sDate, isUTC, _testMS) local LOOKUPDAYABBROFWEEK = { 'sun', 'mon', 'tue', 'wed', 'thu', 'fri', 'sat' } local LOOKUPDAYNAME = { 'Sunday', 'Monday', 'Tuesday', 'WednesDay', 'Thursday', 'Friday', 'Saturday' } local LOOKUPMONTHABBR = { 'jan', 'feb', 'mar', 'apr', 'may', 'jun', 'jul', 'aug', 'sep', 'oct', 'nov', 'dec' } local LOOKUPMONTH = { 'January', 'February', 'March', 'April', 'May', 'June', 'July', 'August', 'September', 'October', 'November', 'December' } local ms local now local time = {} local localTime = {} -- nonUTC local self local getMS = function() if (_testMS ~= nil) then return _testMS else return _getMS() end end if isUTC and isUTC == true then now = os.date('!*t') else now = os.date('*t') isUTC = false end local function makesDate() local now if (isUTC) then now = os.date('!*t') else now = os.date('*t') end local ms = _testMS == nil and getMS() or _testMS return ( now.year .. '-' .. now.month ..'-' .. now.day .. ' ' .. now.hour .. ':' .. now.min .. ':' .. now.sec .. '.' .. tostring(ms) ) end if sDate == nil or sDate == '' then sDate = makesDate() end local y, mon, d, h, min, s = parseDate(sDate) if not(y and mon and d and h and min and s) then sDate = makesDate() y, mon, d, h, min, s = parseDate(sDate) utils.log('sDate was invalid. Reset to ' .. sDate , utils.LOG_ERROR) end -- extract s and ms s, ms = getSMs(s) local dDate = os.time{year=y,month=mon,day=d,hour=h,min=min,sec=s } time = os.date('*t', dDate) local tToday = os.time{ day= now.day, year= now.year, month= now.month, hour= now.hour, min= now.min, sec= now.sec } -- calculate how many minutes that was from now local msDiff, secDiff, minDiff, hourDiff, dayDiff, cmp = getDiffParts(os.difftime(tToday, dDate), ms, getMS()) if (cmp > 0) then -- time is in the future so the xxAgo items should be negative msDiff = -msDiff secDiff = -secDiff minDiff = -minDiff hourDiff = -hourDiff dayDiff = -dayDiff end if (isUTC) then localTime = os.date('*t', os.time(time) + getTimezone()) self = localTime self.utcSystemTime = now self.utcTime = time self.utcTime.minutes = time.min self.utcTime.seconds = time.sec else self = time end self.rawDate = self.year .. '-' .. string.format("%02d", self.month) .. '-' .. string.format("%02d", self.day) self.time = string.format("%02d", self.hour) .. ':' .. string.format("%02d", self.min) self.minutesnow = self.hour * 60 + self.min self.rawTime = self.time .. ':' .. string.format("%02d", self.sec) self.rawDateTime = self.rawDate .. ' ' .. self.rawTime self.milliSeconds = ms self.milliseconds = ms self.dayAbbrOfWeek = LOOKUPDAYABBROFWEEK[self.wday] self.dayName = LOOKUPDAYNAME[self.wday] self.monthAbbrName = LOOKUPMONTHABBR[self.month] self.monthName = LOOKUPMONTH[self.month] -- Note: %V doesn't work on Windows so we have to use a custom function here -- doesn't work: self.week = tonumber(os.date('%V', dDate)) self.week = getWeekNumberOfYear(dDate) self.raw = sDate self.isToday = (now.year == time.year and now.month == time.month and now.day == time.day) self.msAgo = math.floor(msDiff) self.millisecondsAgo = self.msAgo self.minutesAgo = minDiff self.secondsAgo = math.floor(secDiff) self.hoursAgo = hourDiff self.daysAgo = dayDiff self.minutes = self.min self.seconds = self.sec self.minutesSinceMidnight = self.hour * 60 + self.min self.secondsSinceMidnight = self.minutesSinceMidnight * 60 + self.sec self.utils = utils self.isUTC = isUTC self.dDate = dDate self.isdst = time.isdst if (_G.TESTMODE) then _G = _G or {} -- Only used when testing testTime.lua _G.timeofday = _G.timeofday or {} -- Only used when testing testTime.lua function self._getUtilsInstance() return utils end end self.current = os.date('*t') -- compares to self against the provided Time object (t) function self.compare(t) if (t.raw ~= nil) then local msDiff, secDiff, minDiff, hourDiff, dayDiff, cmp = getDiffParts(os.difftime(dDate, t.dDate), t.milliseconds, ms) -- offset is 'our' ms value return { mins = minDiff, hours = hourDiff, secs = math.floor(secDiff), seconds = math.floor(secDiff), minutes = minDiff, days = dayDiff, ms = math.floor(msDiff), milliseconds = math.floor(msDiff), compare = cmp -- 0 == equal, -1==(t earlier than self), 1=(t later than self) } else utils.log('Invalid time format passed to diff. Should a Time object', utils.LOG_ERROR) end end function self.localeMonths() local months = { january = 1, february = 2, march = 3, april = 4, may = 5, june = 6, july = 7, august = 8, september = 9, october = 10, november = 11, december = 12, jan = 1, feb = 2, mar = 3, apr = 4, jun = 6, jul = 7, aug = 8, sep = 9, oct = 10, nov = 11, dec = 12 } local monthSeconds = 2678400 -- accurate enough for this purpose local startSeconds = 1577833200 -- 2020-1-1 00:00 for monthNumber = 1, 12 do months[os.date('%B', startSeconds + ( monthNumber - 1 ) * monthSeconds ):sub(1,3):lower()] = monthNumber months[os.date('%b', startSeconds + ( monthNumber - 1 ) * monthSeconds ):lower()] = monthNumber end return months end function self.dateToTimestamp(dateString, control) local tm, dateTable, format = {}, {}, {} local pattern if control and control:find('%%') then pattern = control elseif control ~= nil then -- control = format local index = 1 for word in control:gmatch("%w+") do table.insert(format, word) end for value in dateString:gmatch("%w+") do dateTable[format[index]] = value index = index + 1 end tm.year = dateTable.yyyy or ( dateTable.yy and ( dateTable.yy + 2000 )) or os.date('%Y') tm.month = dateTable.mm or ( dateTable.mmm and self.localeMonths()[dateTable.mmm:lower()]) or ( dateTable.mmmm and self.localeMonths()[dateTable.mmmm:lower()]) or 1 tm.day = dateTable.dd or 1 tm.hour = dateTable.hh or 0 tm.min = dateTable.MM or 0 tm.sec = dateTable.ss or 0 return os.time(tm) end pattern = pattern or '(%d+)%D+(%d+)%D+(%d+)%D+(%d+)%D+(%d+)' -- yyyy-mm--dd hh:mm tm.year, tm.month, tm.day, tm.hour, tm.min, tm.sec = dateString:match(pattern) return os.time(tm) end function self.timestampToDate(timestamp, humanizedPattern, offSet) local function convertMnemomic2FmtCode(humanizedPattern) local humanizedPattern = humanizedPattern or 'yyyy-mm-dd hh:MM:ss' mnemomics = { {'dddd' , '%A'}, -- full weekdayname(e.g. Wednesday) language depends on locale {'ddd' , '%a'}, -- abbreviated weekdayname(e.g. Wed) language depends on locale {'dd' , '%d'}, -- day of the month(16){[01-31] {'mmmm' , '%B'}, -- full monthname(e.g September) language depends on locale {'mmm' , '%b'}, -- abbreviated monthname(e.g. Sep) language depends on locale {'mm' , '%m'}, -- month[01-12] {'yyyy' , '%Y'}, -- 4-digit year {'yy' , '%y'}, -- two-digityear(98){[00-99] {'hh' , '%H'}, -- hour 24-hour clock){[00-23] {'ii' , '%I'}, -- hour 12-hour clock[01-12] {'MM' , '%M'}, -- minute{[00-59] {'ss' , '%S'}, -- second [00-60] {'W' , '%W'}, -- weeknumber [01-53] {'w' , '%w'}, -- weekday{[0-6] Sunday-Saturday {'datm' , '%c'}, -- date and time (e.g. 09/16/98 23:48:10) format depends on locale {'mer' , '%p'}, -- either "am" or "pm" locale {'date' , '%x'}, -- date(e.g. 09/16/98) format depends on locale {'time' , '%X'}, -- time(e.g. 23:48:10) } for _, conversion in ipairs(mnemomics) do humanizedPattern = string.gsub(humanizedPattern, conversion[1], '%' .. conversion[2]) end return humanizedPattern end local timestamp = ( timestamp or os.time() ) + ( offSet or 0 ) local dateTimeString = os.date( convertMnemomic2FmtCode(humanizedPattern) , timestamp ) if dateTimeString:find('nZero') then -- remove leading zero's return dateTimeString:gsub('nZero',''):gsub(' 0',' '):gsub('^0',''):gsub('%s*$','') end return dateTimeString:gsub('%s*$','') end function self.dateToDate(date, sourceFormat, targetFormat, offSet ) return self.timestampToDate(self.dateToTimestamp(date,sourceFormat), targetFormat, offSet) end function self.addSeconds(seconds, factor) if type(seconds) ~= 'number' then self.utils.log(tostring(seconds) .. ' is not a valid parameter to this function. Please change to use a number value!', utils.LOG_ERROR) else factor = factor or 1 return Time( os.date("%Y-%m-%d %X", self.dDate + factor * math.floor(seconds) )) end end function self.addDays(days) return self.addSeconds(days, 24 * 3600) end function self.addHours(hours) return self.addSeconds(hours, 3600) end function self.addMinutes(minutes) return self.addSeconds(minutes, 60) end function self.makeTime(oDate, isUTC) local sDate = ( type(oDate) == 'table' and os.date("%Y-%m-%d %H:%M:%S", os.time(oDate)) ) or ( tonumber(oDate) and self.timestampToDate(oDate) ) or oDate return Time(sDate, isUTC) end function self.toUTC(oDate, offset) local sDate = ( type(oDate) == 'table' and os.date("%Y-%m-%d %H:%M:%S", os.time(oDate)) ) or oDate local offset = offset or 0 return Time(sDate).addSeconds(-1 * getTimezone() + offset).raw end -- return ISO format function self.getISO() return os.date("!%Y-%m-%dT%TZ", os.time(time)) end -- returns hours part and minutes part of the passed-in minutes amount function minutesToTime(minutes) local hh = math.floor(minutes / 60) local mm = minutes - (hh * 60) return hh, mm end -- returns true if the current time is within a time range: startH:startM and stopH:stopM local function timeIsInRange(startH, startM, stopH, stopM) local function getMinutes(hours, minutes) return (hours * 60) + minutes end local currentMinutes = getMinutes(self.hour, self.min) local startMinutes = getMinutes(startH, startM) local stopMinutes = getMinutes(stopH, stopM) if stopMinutes < startMinutes then -- add 24 hours (1440 minutes ) if endTime < startTime if currentMinutes < stopMinutes then currentMinutes = currentMinutes + 1440 end stopMinutes = stopMinutes + 1440 end return ( currentMinutes >= startMinutes and currentMinutes <= stopMinutes ) end -- returns true if self.day is on the rule: on day1,day2... function self.ruleIsOnDay(rule) local days = string.match(rule, '%s+on%s+(.+)$') or string.match(rule, '^%s*on%s+(.+)$') if (isEmpty(days)) then return nil end local isDayRule = false for i,day in pairs({'mon', 'tue', 'wed', 'thu', 'fri', 'sat', 'sun'}) do if (string.find(days, day) ~= nil) then isDayRule = true break end end if (not isDayRule) then return nil end local days = string.match(rule, '%s+on%s+(.+)$') or string.match(rule, '^%s*on%s+(.+)$') if (days ~= nil) then -- on <day>' was specified local hasDayMatch = string.find(days, self.dayAbbrOfWeek) if (hasDayMatch) then return true else return false end end return nil end -- returns true if self.week matches rule in week 1,3,4 / every odd-week, every even-week, in week 5-12,23,44 function self.ruleIsInWeek(rule) if (string.find(rule, 'every odd week') and not ((self.week % 2) == 0)) then return true elseif (string.find(rule, 'every even week') and ((self.week % 2) == 0)) then return true elseif string.find(rule, 'every even week') or string.find(rule, 'every odd week') then return false end local weeks = string.match(rule, 'in week% ([0-9%-%,% ]*)') if (weeks == nil) then return nil end -- from here on, if there is a match we return true otherwise false -- remove spaces and add a comma weeks = string.gsub(weeks, ' ', '') .. ',' -- remove spaces and add a ',' so we can do simple search for the number -- do a quick scan first to see if we already have a match without needing to search for ranges if (string.find(weeks, tostring(self.week) .. ',')) then return true end -- now get the ranges for set, from, to in string.gmatch(weeks, '(([0-9]*)-([0-9]*))') do to = tonumber(to) from = tonumber(from) if (isEmpty(from) and not isEmpty(to) and self.week <= to ) then return true end if (not isEmpty(from) and isEmpty(to) and self.week >= from ) then return true end if (not isEmpty(from) and not isEmpty(to) and to ~= nil) then if (self.week >= from and self.week <= to) then return true end end end return false end function self.ruleIsOnDate(rule) local dates = string.match(rule, 'on% ([0-9%*%/%,% %-]*)') if (isEmpty(dates)) then return nil end local _ = require('lodash') local dateTable = utils.stringSplit(dates,',') -- get all date(ranges) -- remove spaces and add a comma dates = string.gsub(dates, ' ', '') .. ',' --remove spaces and add a , so we can do simple search for the number -- do a quick scan first to see if we already have a match without needing to search for ranges and wildcards for index, value in ipairs(dateTable) do if tonumber(value:match('%d+')) == self.day and tonumber(value:match('/(%d+)')) == self.month then return true end end -- wildcards for set, day, month in string.gmatch(dates, '(([0-9%*]*)/([0-9%*]*))') do if (day == '*' and month ~= '*') then if (self.month == tonumber(month)) then return true end end if (day ~= '*' and month == '*') then if (self.day == tonumber(day)) then return true end end end local getParts = function(set) local day, month = string.match(set, '([0-9%*]+)/([0-9%*]+)') return day and tonumber( day ), month and tonumber( month ) end --now get the ranges for fromSet, toSet in string.gmatch(dates, '([0-9%/%*]*)-([0-9%/%*]*)') do local fromDay, toDay, fromMonth, toMonth if (isEmpty(fromSet) and not isEmpty(toSet)) then toDay, toMonth = getParts(toSet) if ((self.month < toMonth) or (self.month == toMonth and self.day <= toDay)) then return true end elseif (not isEmpty(fromSet) and isEmpty(toSet)) then fromDay, fromMonth = getParts(fromSet) if ((self.month > fromMonth) or (self.month == fromMonth and self.day >= fromDay)) then return true end else toDay, toMonth = getParts(toSet) fromDay, fromMonth = getParts(fromSet) if ( ( self.month > fromMonth and self.month < toMonth ) or ( fromMonth == toMonth and self.month == fromMonth and self.day >= fromDay and self.day <= toDay ) or ( self.month == fromMonth and toMonth < fromMonth and self.day >= fromDay ) or ( self.month == fromMonth and toMonth > fromMonth and self.day >= fromDay ) or ( self.month == toMonth and toMonth < fromMonth and self.day <= toDay ) or ( self.month == toMonth and toMonth > fromMonth and self.day <= toDay ) ) then return true end end end return false end function self.ruleIsBeforeAstrologicalMoment(rule) local minutes = tonumber(string.match(rule, '%.*(%d+)%s+minutes%s+before%.*')) local astronomicalString = rule:match('minutes%s+before%s+(%a+)') or '' local moment = tonumber(gTimes[astronomicalString .. 'inminutes']) or '' if minutes ~= nil and moment ~= '' then return ( self.minutesnow + minutes ) == moment end return nil end function self.ruleIsAfterAstrologicalMoment(rule) local minutes = tonumber(string.match(rule, '%.*(%d+)%s+minutes%s+after%.*')) local astronomicalString = rule:match('minutes%s+after%s+(%a+)') or '' local moment = tonumber(gTimes[astronomicalString .. 'inminutes']) or '' if minutes ~= nil and moment ~= '' then return ( self.minutesnow - minutes ) == moment end return nil end -- returns true if self.time is at a astronomical moment -- sunset, sunrise, CivilTwilightEnd, NautTwilightStart, etc function self.ruleIsAtAstronomicalMoment(rule) local astronomicalString = rule:match('at%s+(%a+)') or '' local moment = tonumber(gTimes[astronomicalString .. 'inminutes']) or -1 return moment == self.minutesnow or nil end -- returns true if self.time is at a astronomical range -- daytime, nightime, etc function self.ruleIsAtAstronomicalRange(rule) local astronomicalString = rule:match('at%s+(%a+)') or '' if type(gTimes[astronomicalString]) == 'boolean' then return gTimes[astronomicalString] or nil end end -- returns true if self.min fits in the every xx minute /every other minute/every minute rule function self.ruleMatchesMinuteSpecification(rule) local function fitsMinuteRule(m) return (self.min / m == math.floor(self.min / m)) end if (string.find(rule, 'every minute')) then return true end if (string.find(rule, 'every other minute')) then return fitsMinuteRule(2) end local minutes = tonumber(string.match(rule, 'every (%d+) minutes')) if (minutes ~= nil) then if ((60 / minutes) ~= math.floor(60 / minutes) or minutes >= 60) then self.utils.log(rule .. ' is not a valid timer definition. Can only run every 1, 2, 3, 4, 5, 6, 10, 12, 15, 20 and 30 minutes.', utils.LOG_ERROR) return false end return fitsMinuteRule(minutes) end return nil -- nothing specified for this rule end -- return true if self.hour fits the every hour/every other hour/every xx hours rule function self.ruleMatchesHourSpecification(rule) local function fitsHourRule(h) -- always fit every whole hour (hence the self.min == 0) return (self.hour / h == math.floor(self.hour / h) and self.min == 0) end if (string.find(rule, 'every hour')) then return fitsHourRule(1) end if (string.find(rule, 'every other hour')) then return fitsHourRule(2) end local hours = tonumber(string.match(rule, 'every% (%d+)% hours')) if (hours ~= nil) then if ((24 / hours) ~= math.floor(24 / hours) or hours >= 24) then self.utils.log(rule .. ' is not a valid timer definition. Can only run every 1, 2, 3, 4, 6, 8, 12 hours.', utils.LOG_ERROR) return false end return fitsHourRule(hours) end return nil -- nothing specified for this rule end -- return true if self.time is at hh:mm / *:mm/ hh:* function self.ruleMatchesTime(rule) local hh, mm local timePattern = 'at% ([0-9%*]+):([0-9%*]+)' hh, mm = string.match(rule, timePattern .. '% ') if (hh == nil or mm == nil) then -- check for end-of string hh, mm = string.match(rule, timePattern .. '$') end if (hh ~= nil) then if (mm == '*') then return (self.hour == tonumber(hh)) elseif (hh == '*') then return (self.min == tonumber(mm)) --elseif (hh ~= '*' and hh ~= '*') then else hh = tonumber(hh) mm = tonumber(mm) if (hh ~= nil and mm ~= nil) then return (mm == self.min and hh == self.hour) else -- invalid return false end end end return nil -- no at hh:mm found in rule end -- returns true if self.time is in time range: at hh:mm-hh:mm function self.ruleMatchesTimeRange(rule) local fromH, fromM, toH, toM = string.match(rule, 'at% ([0-9%*]+):([0-9%*]+)-([0-9%*]+):([0-9%*]+)') if (fromH ~= nil) then -- all will be nil if fromH is nil fromH = tonumber(fromH) fromM = tonumber(fromM) toH = tonumber(toH) toM = tonumber(toM) if (fromH == nil or fromM == nil or toH == nil or toM == nil) then -- invalid format return false else return timeIsInRange(fromH, fromM, toH, toM) end end return nil end -- returns true if 'moment' matches with any of the moment-like time rules function getMoment(moment) local minutes, astrologicalMoment -- first check if it in the form of hh:mm hh, mm = string.match(moment, '([0-9]+):([0-9]+)') if (hh ~= nil and mm ~= nil) then return tonumber(hh), tonumber(mm) end -- check if it is before astroMoment minutes, astrologicalMoment = string.match(moment, '%.*(%d+)%s+minutes%s+before%s+(%a+)') if minutes and astrologicalMoment then return minutesToTime(gTimes[astrologicalMoment .. 'inminutes'] - tonumber(minutes)) end -- check if it is after astroMoment minutes, astrologicalMoment = string.match(moment, '%.*(%d+)%s+minutes%s+after%s+(%a+)') if minutes and astrologicalMoment then return minutesToTime(gTimes[astrologicalMoment .. 'inminutes'] + tonumber(minutes)) end -- check at astroMoment if (gTimes[moment .. 'inminutes']) then return minutesToTime(gTimes[moment .. 'inminutes']) end return nil end -- returns true if self.time is in a between xx and yy range function self.ruleMatchesBetweenRange(rule) local from, to = string.match(rule, 'between% (.+)% and% (.+)') if (from == nil or to == nil) then return nil end local fromHH, fromMM, toHH, toMM fromHH, fromMM = getMoment(from) toHH, toMM = getMoment(to) if (fromHH == nil or fromMM == nil or toHH == nil or toMM == nil) then return nil end return timeIsInRange(fromHH, fromMM, toHH, toMM) end -- remove seconds from timeStrings 'at 12:23:56-23:45:00 ==>> 'at 12:23-23:45' -- to allow use of rawTime in matchesRule local function sanitize(rule) if not rule:match("(%w+%:%w+:%w+)") then return rule end for strippedTime in rule:gmatch("(%w+%:%w+)") do if strippedTime:match("(%w+%:%w+:%w+)") then rule = rule:gsub(rule:match("(%w+%:%w+:%w+)"),rule:match(strippedTime)) end end return rule end local function populateAstrotimes() local LOOKUPASTRO = { CivTwilightEndInMinutes = 'civiltwilightendinminutes', AstrTwilightStartInMinutes = 'astronomicaltwilightstartinminutes', AstrTwilightEndInMinutes = 'astronomicaltwilightendinminutes', SunAtSouthInMinutes = 'solarnooninminutes', NautTwilightEndInMinutes = 'nauticaltwilightendinminutes', NautTwilightStartInMinutes = 'nauticaltwilightstartinminutes', CivTwilightStartInMinutes = 'civiltwilightstartinminutes', Daytime = 'daytime', SunsetInMinutes = 'sunsetinminutes', Civildaytime = 'civildaytime', Civilnighttime = 'civilnighttime', SunriseInMinutes = 'sunriseinminutes', Nighttime = 'nighttime', } gTimes = {} for originalName, dzVentsName in pairs(LOOKUPASTRO) do gTimes[dzVentsName] = _G.timeofday[originalName] end gTimes.sunatsouthinMinutes = gTimes.solarnooninminutes gTimes.astronomicaldaytime = ( self.minutesnow <= (gTimes.astronomicaltwilightendinminutes or 0) and self.minutesnow >= (gTimes.astronomicaltwilightstartinminutes or 9999)) gTimes.nauticaldaytime = (self.minutesnow <= (gTimes.nauticaltwilightendinminutes or 0) and self.minutesnow >= (gTimes.nauticaltwilightstartinminutes or 9999)) gTimes.nauticalnighttime = not(gTimes.nauticaldaytime) gTimes.astronomicalnighttime = not(gTimes.astronomicaldaytime) return true end -- returns true if self.time matches the rule function self.matchesRule(rule, processed) if type(rule) == 'string' and ( string.len(rule == nil and "" or rule) == 0) then return false -- split into atomic time rules to simplify and speedup processing elseif type(rule) == 'string' and not(processed) then populateAstrotimes() local rule = rule:lower() local validPositiveRules = true local negativeKeyword = 'except' local function ruleSplit(rawRule) local ruleKeywords = 'on, between, every, in' local allRules = {} local aRule = '' for ruleWord in string.gmatch(rawRule, "[%S]+") do -- all "words" separated by spaces if ruleKeywords:find(ruleWord) and aRule ~= '' then table.insert(allRules, aRule) aRule = '' end aRule = ( aRule == '' and ruleWord ) or ( aRule .. ' ' .. ruleWord ) end if aRule ~= '' then table.insert(allRules, aRule) end return allRules or {} end local positiveRules, negativeRules local exceptPosition = rule:find(negativeKeyword) if exceptPosition then positiveRules = ruleSplit(rule:sub(1, exceptPosition - 1)) negativeRules = ruleSplit(rule:sub(exceptPosition + #negativeKeyword, #rule)) else negativeRules = nil positiveRules = ruleSplit(rule) end for _, aRule in ipairs(positiveRules) do validPositiveRules = validPositiveRules and self.matchesRule(aRule, true) if validPositiveRules == false then return false end end if exceptPosition then for _, aRule in ipairs( negativeRules) do if self.matchesRule(aRule, true) then return false end end end return validPositiveRules end local res local total = false local function updateTotal(res) total = res ~= nil and (total or res) or total end res = self.ruleIsInWeek(rule) if (res == false) then --in week <weeks> was specified but 'now' is not on any of the specified weeks return false end updateTotal(res) res = self.ruleIsOnDay(rule) -- range if (res == false) then -- on <days> was specified but 'now' is not on any of the specified days return false end updateTotal(res) res = self.ruleIsOnDate(rule) if (res == false) then -- on date <dates> was specified but 'now' is not on any of the specified dates return false end updateTotal(res) local _between = self.ruleMatchesBetweenRange(rule) -- range if (_between == false) then -- rule had between xxx and yyy is not in that range now return false end res = _between updateTotal(res) if (_between == nil) then -- there was not a between rule. -- A between-range can have before/after sunrise/set rules so it cannot be combined with these here res = self.ruleIsBeforeAstrologicalMoment(rule) -- moment if (res == false) then -- (sub)rule has before xxstart, xxend, sunset, sunrise or solarnoon return false end updateTotal(res) res = self.ruleIsAfterAstrologicalMoment(rule) -- moment if (res == false) then -- (sub)rule has after xxstart, xxend, sunset, sunrise or solarnoon return false end updateTotal(res) end res = self.ruleIsAtAstronomicalMoment(rule) if (res == false) then -- rule has at xxstart, xxend, sunset, sunrise or solarnoon return false end updateTotal(res) res = self.ruleIsAtAstronomicalRange(rule) if (res == false) then -- rule has at xxdaytime or xx nighttime return false end updateTotal(res) res = self.ruleMatchesHourSpecification(rule) -- moment if (res == false) then -- rule has every xx hour but its not the right time return false end updateTotal(res) res = self.ruleMatchesMinuteSpecification(rule) -- moment if (res == false) then -- rule has every xx minute but its not the right time return false end updateTotal(res) rule = sanitize(rule) res = self.ruleMatchesTime(rule) -- moment / range if (res == false) then -- rule has at hh:mm part but didn't match (or was invalid) return false end updateTotal(res) res = self.ruleMatchesTimeRange(sanitize(rule)) -- range if (res == false) then -- rule has at hh:mm-hh:mm but time is not in that range now return false end updateTotal(res) return total end return self end return Time
djalexnl
Re: timer [SOLVED]
Problem has been solved! Case can be closed
Thanks again for the fast fix!
