i like to change this script so that the input data can be a selected dim level and then do the same trick by retrieving the data.
In this case there has to be a range check for the corresponding data.
Another issue is that the script must handle strings and numbers and detect how to handle the input variable, string (is value matching), number is range matching.
I made a first test script, and like to have feedback if this is the way to go...
local volume_states = {
{'uit','Low',0,'Off',0,0,0}, -- p1 = waarde tekst, p2 bel/sirene volume, p3=nodered volume, p4=volumeduur_alarm Off=uit, p5=volumeduur_deurbel 0= uit, p6= range lowondergrens, p7 range volume bovengrens
{'fluister', 'Low',10,'30 second',1,1,20},
{'zacht','Middle',30,'30 second',1,21,40},
{'medium','Middle',50,'30 second',1, 41,60},
{'hard','High',70,'30 second',1,61,80},
{'extra', 'High', 90,'30 second',1,81,100}
local function xxx(aa)
for _, record in ipairs(volume_states) do
if isInteger(aa) then
if volume >= record[6] and volume <= record[7] then -- figure out aa in which range it is and then use those values
return record[1],record[2],record[3],record[4],record[5]
if record[1] == volume then
a=10 --of
a="10" --of
a="medium"
if isInteger(a) then
aa= tonumber(a)
aa=a
test1,test2,test3,test4,test5 = XXX(aa)
