copy a api/telegram into a local text file [Solved]
fonger
Hi There
I have a P1 dongle into my smart meter. I want to capture the values and use them into Domoticz.
The values I got from the P1 dongle is in a telegram style. on a local ip 192.168.178.16/api/v1/telegram, and it looks like this:
/ISK5\2M550T-1013
1-3:0.2.8(50)
0-0:1.0.0(210309202253W)
0-0:96.1.1(4530303534303037363733333231333230)
1-0:1.8.1(000733.488*kWh)
1-0:1.8.2(000839.845*kWh)
1-0:2.8.1(000061.240*kWh)
1-0:2.8.2(000145.582*kWh)
0-0:96.14.0(0002)
1-0:1.7.0(02.441*kW)
1-0:2.7.0(00.000*kW)
0-0:96.7.21(00004)
0-0:96.7.9(00004)
1-0:99.97.0(2)(0-0:96.7.19)(200529212626S)(0000000228*s)(201025114028W)(0000000776*s)
1-0:32.32.0(00000)
1-0:52.32.0(00000)
1-0:72.32.0(00000)
1-0:32.36.0(00001)
1-0:52.36.0(00001)
1-0:72.36.0(00001)
0-0:96.13.0()
1-0:32.7.0(226.4*V)
1-0:52.7.0(224.7*V)
1-0:72.7.0(225.9*V)
1-0:31.7.0(001*A)
1-0:51.7.0(009*A)
1-0:71.7.0(000*A)
1-0:21.7.0(00.212*kW)
1-0:41.7.0(02.221*kW)
1-0:61.7.0(00.004*kW)
1-0:22.7.0(00.000*kW)
1-0:42.7.0(00.000*kW)
1-0:62.7.0(00.000*kW)
0-1:24.1.0(003)
0-1:96.1.0(4730303634303032303130373737393230)
0-1:24.2.1(210309202003W)(00865.754*m3)
I found a topic (Domoticz + P1 monitor share device) about this and the solution was a script that writes the values to the devices, but that script was based on a file who got filled bij a p1 monitor.
My question is: is there a possibility to copy the telegram (frequently) from the site and write it down to a local text file on my raspberry?
So I can use the script wrote for the p1 monitor.
Grtz Fonger
/ISK5\2M550T-1013
1-3:0.2.8(50)
0-0:96.14.0(0002)
0-0:96.7.21(00004)
0-0:96.7.9(00004)
1-0:32.32.0(00000)
1-0:52.32.0(00000)
1-0:72.32.0(00000)
1-0:32.36.0(00001)
1-0:52.36.0(00001)
1-0:72.36.0(00001)
0-0:96.13.0()
1-0:32.7.0(226.4*V)
1-0:52.7.0(224.7*V)
1-0:72.7.0(225.9*V)
1-0:31.7.0(001*A)
1-0:51.7.0(009*A)
1-0:71.7.0(000*A)
0-1:24.1.0(003)
Grtz Fonger
- FireWizard
Re: copy a api/telegram into a local text file
Hi, @fonger
The published telegram is a correct telegram of a Smart Meter, except that it doesn't contain a CRC.
So disable the CRC check.
Why not use the native hardware in Domoticz? (P1 Smart Meter with LAN interface)?
See: https://www.domoticz.com/wiki/Dutch_DSM ... th_P1_port
fonger
The way that you describe isn't working, I don't get the information from the p1 meter, Domoticz doesn't recognize the meter.
Thats why I want to do it the way I describe above.
But I don't know how to copy the telegram and write it down to a local .txt file
Grtz Fonger
Grtz Fonger
- waaren
Happy to help but to determine the best approach I would like to know your domoticz / dzVents Version.fonger wrote: Thursday 11 March 2021 16:52 The way that you describe isn't working, I don't get the information from the p1 meter, Domoticz doesn't recognize the meter.
What devices (type/subtype/idx ) do you want to use for this data? Maybe the data can be directly used by dzVents to update these devices.
fonger
I copied your last script from the topic:
viewtopic.php?p=255949#p255949
That works fine, if I manually make a copy of the telegram, and write it to the text file.
"/tmp/p1Data/p1msg.txt" (change from the original script)
Al the devices are in Domoticz, and get that values from that file.
So I think I need a script that makes a copy from the telegram on the local IP (timebased) and and write it down to the p1msg.txt file.
log:
2021-03-11 17:37:20.329 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2021-03-11 17:37:30.296 Status: dzVents: Info: Handling Domoticz custom event for: "readTelegram"
2021-03-11 17:37:30.296 Status: dzVents: Info: readTelegram: ------ Start internal script: p1msg-file: Custom event: "readTelegram"
2021-03-11 17:37:30.308 Status: dzVents: Debug: readTelegram: Processing device-adapter for Power: P1 smart meter energy device adapter
2021-03-11 17:37:30.309 Status: dzVents: Debug: readTelegram: Processing device-adapter for Gas: Gas device adapter
2021-03-11 17:37:30.309 Status: dzVents: Debug: readTelegram: Processing device-adapter for Input Voltage: Voltage device adapter
2021-03-11 17:37:30.310 Status: dzVents: Debug: readTelegram: Processing device-adapter for Usage l1: Electric usage device adapter
2021-03-11 17:37:30.310 Status: dzVents: Debug: readTelegram: Processing device-adapter for Usage l2: Electric usage device adapter
2021-03-11 17:37:30.310 Status: dzVents: Debug: readTelegram: Processing device-adapter for Usage l3: Electric usage device adapter
2021-03-11 17:37:30.311 Status: dzVents: Debug: readTelegram: Processing device-adapter for amperageTotal: 1-phase Ampere device adapter
2021-03-11 17:37:30.311 Status: dzVents: Debug: readTelegram: Processing device-adapter for amperageCombined: 3-phase Ampere device adapter
2021-03-11 17:37:30.312 Status: dzVents: > usage1: 737630
2021-03-11 17:37:30.312 Status: dzVents: > powerUsageL2: 220
2021-03-11 17:37:30.312 Status: dzVents: > tariff: 2000
2021-03-11 17:37:30.312 Status: dzVents: > voltageL3: 230200
2021-03-11 17:37:30.312 Status: dzVents: > usage2: 848595
2021-03-11 17:37:30.312 Status: dzVents: > l1Power: 0
2021-03-11 17:37:30.312 Status: dzVents: > powerReceived: 1684
2021-03-11 17:37:30.312 Status: dzVents: > amperageL1: 1000
2021-03-11 17:37:30.312 Status: dzVents: > voltageL1: 230200
2021-03-11 17:37:30.312 Status: dzVents: > returned1: 61240
2021-03-11 17:37:30.312 Status: dzVents: > powerDelivery: 0
2021-03-11 17:37:30.312 Status: dzVents: > powerUsageL3: 0
2021-03-11 17:37:30.312 Status: dzVents: > gas: 875933
2021-03-11 17:37:30.312 Status: dzVents: > amperageL3: 9000
2021-03-11 17:37:30.312 Status: dzVents: > powerUsageL1: 242
2021-03-11 17:37:30.312 Status: dzVents: > voltageL2: 229800
2021-03-11 17:37:30.312 Status: dzVents: > returned2: 149959
2021-03-11 17:37:30.312 Status: dzVents: > amperageL2: 1000
Grtz Fonger
log:
Grtz Fonger
- waaren
And the other question was to tell which domoticz / dzVents version you use.fonger wrote: Thursday 11 March 2021 17:48 So I think I need a script that makes a copy from the telegram on the local IP (timebased) and and write it down to the p1msg.txt file.
That will influence the approach to take with the scripts
fonger
Over Domoticz
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Version: 2020.2
- waaren
Can you try below script?
if the combination of the two scripts works a next step should be to combine these scripts. It does not make much sense to me to get data from an (for domoticz) external source, write it to a file with script A and use script B to read the same file and process the data.
A more common approach would be to collect the data with a script and use the same script to process it. It should not be needed to use an OS file to store the temp data if dzVents can get the data directly by itself.
local scriptVar = 'readTelegram'
return
on =
timer =
'every minute',
httpResponses =
scriptVar,
logging =
level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when all OK
marker = scriptVar,
execute = function(dz, item)
local smartFile = '/tmp/p1Data/p1msg.txt' -- full qualified file name
local function openURL(delay)
dz.openURL(
url = 'http://192.168.178.16/api/v1/telegram',
callback = scriptVar,
}).afterSec(delay or 0)
local function writeFile(fn, str)
local f = io.open(fn, 'w' )
f:write(str)
f:close()
-- main code
if item.isTimer then
openURL()
elseif item.isHTTPResponse and item.ok then
writeFile(smartFile, item.data)
dz.log('Problem reading the telegram', dz.LOG_ERROR)
dz.log(tostring(item.data), dz.LOG_DEBUG)
- Domoticz version: 2025.1
Would it be something to use the standard http poller for this?
So with http poller get the telegram and with a Lua telegram parser put the data in domotica devices?
- waaren
You can tackle this in many different ways. To name a few.waltervl wrote: Thursday 11 March 2021 21:51 Would it be something to use the standard http poller for this?
node-red + MQTT
Classic Lua scripting
Python event script
Python plugin
Extend current P1 hardware
Bash scripting
HTTP poller + Lua parser
dzVents
My personal preference is dzVents because I know my way around with it but a large part of the fun in domoticz is that you can choose what best suits you.
fonger
Yes! it works properly.
- waaren
OK.
can you also try below version? It does the job without temp. OS files. (And using only this script. So no separate read and write scripts)
return
on =
timer =
'every minute',
httpResponses =
scriptVar,
logging =
marker = scriptVar,
local debug = _G.logLevel == dz.LOG_DEBUG
local power = dz.devices('Power') -- change to name of your virtual smart meter (P1 smart Meter (Electric))
local gas = dz.devices('Gas') -- change to name of your virtual smart meter (Gas)
local volt = dz.devices('Input Voltage') -- change to name of your virtual voltage device
local l1 = dz.devices('Usage l1') -- change to name of your virtual Usage L1 (Usage Electric)
local l2 = dz.devices('Usage l2') -- change to name of your virtual Usage L1 (Usage Electric)
local l3 = dz.devices('Usage l3') -- change to name of your virtual Usage L1 (Usage Electric)
local ampere1Phase = dz.devices('amperageTotal') -- change to name of your virtual amperage device (1 phase)
local ampere3Phases = dz.devices('amperageCombined') -- change to name of your virtual amperage device (3 phases)
local amperage1, amperage2, amperage3 = 0, 0, 0
local delivered = dz.devices('Delivered') -- change to name of your virtual counter
local received = dz.devices('Received') -- change to name of your virtual counter
local frequency = 6 -- every 60 / frequency seconds
local P1Reference =
l1Power = '22.7.0',
tariff = '96.14.0',
usage2 = '1.8.2',
usage1 = '1.8.1',
returned1 = '2.8.1',
returned2 = '2.8.2',
powerReceived = '2.7.0',
gas = '24.2.1',
powerUsageL1 = '21.7.0',
powerUsageL2 = '41.7.0',
powerUsageL3 = '61.7.0',
powerDelivery = '1.7.0',
amperageL1 = '31.7.0',
amperageL2 = '51.7.0',
amperageL3 = '71.7.0',
voltageL1 = '32.7.0',
voltageL2 = '52.7.0',
voltageL3 = '72.7.0',
dz.openURL(
function table.invert(t)
local it = {}
for k,v in pairs(t) do
it[v]=k
return it
local function readResult( telegram, it )
local function crLines(s)
return s:gsub('\r\n?', '\n'):gmatch('(.-)\n') -- Normalize CR/LF
local lines = {}
for line in crLines(telegram) do
if line:find(':') then
key = it[line:match(':(%d+.%d+.%d+)')]
if key then
lines[key] = math.floor((line:match('%b()%s*%c*$'):match('%d+%.*%d*') or -1) * 1000)
if debug then dz.utils.dumpTable(lines) end
return lines
local function updateDevices(t)
power.updateP1 (
t.usage1 or 0,
t.usage2 or 0,
t.returned1 or 0,
t.returned2 or 0,
t.powerUsageL1 + t.powerUsageL2 + t.powerUsageL3,
t.powerDelivery or 0
if t.gas then gas.updateGas(t.gas) end
if t.powerUsageL1 then
l1.updateEnergy(t.powerUsageL1)
amperage1 = dz.utils.round( t.powerUsageL1 / t.voltageL1 , 2)
if t.powerUsageL2 then
l2.updateEnergy(t.powerUsageL2)
amperage2 = dz.utils.round( t.powerUsageL2 / t.voltageL2 , 2)
if t.powerUsageL3 then
l3.updateEnergy(t.powerUsageL3 )
amperage3 = dz.utils.round( t.powerUsageL3 / t.voltageL3 , 2)
ampere1Phase.updateCurrent( dz.utils.round( amperage1 + amperage2 + amperage3 , 2 ) )
ampere3Phases.updateCurrent( amperage1, amperage2, amperage3 )
volt.updateVoltage( dz.utils.round( t.voltageL1 / 1000 ,1 ) )
delivered.updateCounter(t.powerDelivery or 0)
received.updateCounter(t.powerReceived or 0)
local function showResults(t, it)
if not(debug) then return end
for code, value in pairs(t) do
if it[code] then
dz.log(it[code] .. ' ==>> ' .. value, dz.LOG_DEBUG)
-- main code
openURL()
local interval = math.floor(60/frequency)
for secondsDelay = interval, (60 - interval), interval do
openURL(secondsDelay)
local invertedTable = table.invert(P1Reference)
local actual = readResult(item.data, invertedTable)
showResults(actual, invertedTable)
updateDevices(actual, invertedTable)
fonger
Sorry it take a while, I had a crash because of a corrupted sd card, I had to make a complete reinstall and lost everything.
But I'am on air again...
I get an error
LOG info:
I get an error
LOG info:
- Spoiler: show
- waaren
Sorry, was a left behind from my tests. I updated the script I posted.fonger wrote: Saturday 13 March 2021 15:30 Sorry it take a while, I had a crash because of a corrupted sd card, I had to make a complete reinstall and lost everything.
I get an error
Can you try again after removing line
url = "dz:8084/json.htm?type=command¶m=getversion" Debian buster, bullseye on RPI-4, Intel NUC.
fonger
Yes the devices getting their values, only the amperageTotal and amperageCombined getting a NAN value.
Log:
2021-03-14 09:45:00.543 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 57, sValue: 'nan', sUsage: '0', dType: 243, sType: 23)
How I add the 1.7.0 ( powerDelivery) and the 2.7.0 (powerRecieved) to the devices?
Log:
- waaren
For the amperages please try again using the updated posted version.fonger wrote: Sunday 14 March 2021 10:03 Yes the devices getting their values, only the amperageTotal and amperageCombined getting a NAN value.
Log:
The powerDelivery is already send to the virtual smart meter but can also be split out to another device.
Do you want type counter devices for delivery and received (= used and produced) or should these values be send to other type devices?
fonger
I would like to get the actual (used and proceed) values in different devices.
Now I have noticed that the input Voltage doesn't update.
- waaren
The voltage device is in this script for input into it but because your meter already supplies the voltage it's no longer needed for input.fonger wrote: Sunday 14 March 2021 13:58 I would like to get the actual (used and proceed) values in different devices.
Should the script send the voltage of L1 to this device or the average of voltageL1, voltageL2 and voltageL3 ?
fonger
Voltage L1 is fine thanks.
- waaren
I updated the posted version.
