No idea?vwtune wrote: ↑Friday 30 October 2020 17:47 Since i updated to version 2020.2 of Domoticz
Domoticz is crashing almost once a day. Before it crashes, i can see in the log:After this, domoticz crashedCode: Select all
2020-10-30 17:41:15.764 Error: (WLED Hal Nodemcu ) Exception detail: 'Unterminated string starting at: line 5 column 49 (char 1236)' 2020-10-30 17:41:15.764 Error: (WLED Hal Nodemcu ) 'onMessage' failed 'ValueError'. 2020-10-30 17:41:15.764 Error: Domoticz(pid:771, tid:775('PluginMgr')) received fatal signal 11 (Segmentation fault) 2020-10-30 17:41:15.764 Error: siginfo address=0x303, address=(nil)
It has something to do with wled plugin i think....
I already did a git pull and restart to get the latest wled plugin, but still get the crashes on WLED.
Can you please take a look at this?
Python Plugin: WLED
Re: Python Plugin: WLED
Any updates???
Would be nice if there will be segment selector
Problem with WLED with google home.
I have WLED on an esp-01, this works well, added to domoticz, that also works, with the WLED app I can set everything and with domoticz too.
Only WLED - Color & Brightness Added to google home and I can now turn the strip on and off, also I can choose colors.
Only if I choose the white tones then the strip goes out, and that only in the google home app. domoticz and the WLED app are fine.
if I look in the domoticz log, this will be displayed.
2021-01-22 14:16:32.085 (WLED) Color:{"b":0,"cw":51,"g":0,"m":2,"r":0,"t":204,"ww":204}
2021-01-22 14:16:32.404 (WLED) Updating Domoticz from UDP
2021-01-22 14:16:32.078 Status: setkelvinlevel: t: 80.000000, color: '{m: 2, RGB: 000000, CWWW: 33cc, CT: 204}'
Other colors are fine. This is b,v almost white and a blue tint
2021-01-22 14:17:56.460 (WLED) Color:{"b":255,"cw":0,"g":247,"m":1,"r":239,"t":0,"ww":0}
2021-01-22 14:17:56.736 (WLED) Updating Domoticz from UDP
2021-01-22 14:17:56.428 Status: setcolbrightnessvalue: ID: 88, bri: 100, color: '{m: 1, RGB: eff7ff, CWWW: 0000, CT: 0}'
Strange thing is that it worked fine a few days ago, and I haven't changed anything.
Anyone have any idea what could be causing this?
Would be nice if there is some support or update here?
Domoticz still crashes with WLED plugin. When i do not use the pluging, domoticz is stable.
the moment domoticz crashes:
2021-01-31 11:43:15.540 Error: CConnection_disconnect, disconnection request from 'WLED Bed' ignored. Transport does not exist.
2021-01-31 11:43:15.541 Error: (WLED Bed) Exception detail: 'Unterminated string starting at: line 4 column 111 (char 1244)'
2021-01-31 11:43:15.541 Error: (WLED Bed) 'onMessage' failed 'ValueError'.
2021-01-31 11:43:15.541 Error: Domoticz(pid:1381, tid:1384('PluginMgr')) received fatal signal 11 (Segmentation fault)
2021-01-31 11:43:15.541 Error: siginfo address=0x565, address=(nil)
2021-02-01 10:13:12.656 Error: Python Plugin System: (WLED Wemos Alarm) Exception detail: 'Unterminated string starting at: line 4 column 111 (char 1248)'
2021-02-01 10:13:12.657 Error: Python Plugin System: (WLED Wemos Alarm) 'onMessage' failed 'ValueError'.
2021-02-01 10:13:12.657 Error: Domoticz(pid:17042, tid:17045('PluginMgr')) received fatal signal 11 (Segmentation fault)
2021-02-01 10:13:12.657 Error: siginfo address=0x4292, address=(nil)
Can you please take a look at this and update the plugin?
it's getting anyoing.
i have to disable wled plugin because it crashes domoticz a couple of times in a day.
2021-02-01 11:11:25.949 Error: CConnection_disconnect, disconnection request from 'WLED Hal Nodemcu ' ignored. Transport is not connecting or connected.
2021-02-01 11:11:25.950 Error: Python Plugin System: (WLED Hal Nodemcu ) Exception detail: 'Unterminated string starting at: line 18 column 53 (char 2702)'
2021-02-01 11:11:25.950 Error: Python Plugin System: (WLED Hal Nodemcu ) 'onMessage' failed 'ValueError'.
2021-02-01 11:11:25.950 Error: Domoticz(pid:31150, tid:31153('PluginMgr')) received fatal signal 11 (Segmentation fault)
2021-02-01 11:11:25.950 Error: siginfo address=0x79ae, address=(nil)
hi VWtune,
It might help if you post the version of wled you are using. the onmessage errors looks like it gets an update from domoticz but there is something with the data that it don't understand. is this with the debug log on all?
Today install plugin, but Palettes - undefined, Effects - undefined
Drop-down menu not worked.
Domoticz displays an error:
Error: (Wled) Transport is not connected, write directive to 'JSONConn' ignored.
or
Error: (Wled) No transport, write directive to 'JSONConn' ignored.
Can help me?
PS: after las update beta Domoticz to Version: 2021.1 (build 13746) all is OK
or
Can help me?
@Creo2005
I had the same issue:
Happy that it works for you, but not here using the latest beta....
So, I've just posted a Pull Request that fixes this, here:
https://github.com/frustreermeneer/domo ... in/pull/15
Until merged, the changed file is at
https://github.com/soif/domoticz-wled-p ... /plugin.py
enjoy
enjoy
Developer of phpMyDomo, a Web Interface for Domoticz
Hi everyone,
first of all. Thanks for this Plugin.
I actually use one wled device in domoticz.
At beginning nothings works because of "no transport" issue.
Therefore I use the fixed version from wxop (Thanks for that).
Now it works. But I still get the mentioned issue every 5 minutes:
You see it here
Any idea?
I have got also the problem that Effects, FX Intensity and FX Speed are can not be controlled by domoticz.
I don't know why.
I use wled version 0.12. Could this be the problem?
Last but not least one question. I read in this posts that I can add only one wled device to domoticz. It is right?
Thank you for your help.
You see it here
2022-01-02 00:00:19.103 Error: WLED: (WLED) Transport is not connected, write directive to 'JSONConn' ignored.
2022-01-02 00:05:19.145 Error: WLED: (WLED) Transport is not connected, write directive to 'JSONConn' ignored.
2022-01-02 00:10:19.154 Error: WLED: (WLED) No transport, write directive to 'JSONConn' ignored.
2022-01-02 00:15:19.130 Error: WLED: (WLED) Transport is not connected, write directive to 'JSONConn' ignored.
I don't know why.
After new plugin:
Error: WLED: No transport, write directive to 'JSONConn' ignored.
- Domoticz version: 2021.1
I have the same problem with the pluginvwtune wrote: ↑Saturday 26 December 2020 11:42No idea?vwtune wrote: ↑Friday 30 October 2020 17:47 Since i updated to version 2020.2 of Domoticz
Is there a way to get it work?
- Domoticz version: 2024.7
There is a known issue with failing Python plugins and RPi on Bullseye. Is that the case?
- budman1758
- Domoticz version: 2022.2
I have the latest version of Domoticz installed. Installed this plugin. No Wled option appears in the hardware dropdown. Anybody know if this plugin works lately?
Followed install instructions to the letter.
"The Glass is twice as big as it needs to be".
Did you also follow the basic plugin instructions on wiki https://www.domoticz.com/wiki/Using_Python_pluginsbudman1758 wrote: ↑Thursday 22 December 2022 19:26 I have the latest version of Domoticz installed. Installed this plugin. No Wled option appears in the hardware dropdown. Anybody know if this plugin works lately?
- budman1758
Of course not! Why would I do a silly thing like that??
I just assumed python was pre-installed on Raspberry OS. Silly me.....
Is this update rolled out yet? I created multiple segments before installing the plugin but only the master devices show up.
frustreerMeneer wrote: ↑Sunday 18 October 2020 20:53I'm still working things out. But as soon as you have more than 1 segment you will get a master color and brigtness slider (the one that you already have) and 1 color and brightness slider per extra segment. I think it is the same way Home Assistant does it.
I still have to look into effects, presets and palletes.
Let me know your ideas.
