Split measured value  [Solved]
Knibor
Domoticz version: Stable
Post by Knibor »
I have a device called "Electric (Instant+Counter)". I want to create a new device that only shows the counter value. Can someone give me an example of how to do this in dzVents?
Thank you very much
Re: Split measured value
Knibor wrote: Friday 05 March 2021 17:32 I want to create a new device that only shows the counter value. Can someone give me an example of how to do this in dzVents?
What kind of device should the target be? A text device or a counter or a custom sensor or something else?
Knibor
Post by Knibor »
I currently have a device of the type "General, kWh".
This device gives me two values. The first is the current solar energy and the second is the value of today's total solar energy in kWh. I would like a separate device that only displays the kWh generated by the solar panels today. The device I would like to use is of the Text device.
Re: Split measured value  [Solved]
Knibor wrote: Saturday 06 March 2021 11:12 I currently have a device of the type "General, kWh".
Could look like script below
return
    on =
        devices =
            2515, -- change to idx of your solar device
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all is ok
        marker = 'solar to text',
    execute = function(dz, item)
        local solar = dz.devices('solar energy today') -- change to name of your text device
        local currentText = solar.text
        local newtext = item.counterToday .. ' kWh'
        if currentText ~= newtext then
            solar.updateText(newtext)
Knibor
Post by Knibor »
Thanks a lot for the script. It works now.
