P1 smart meter log sending a day
kozzen
How can i get a log detail every day from the day before automaticly on mail in a file ?
(so from 00.00 to 23:59 and 59 seconds ( so from the hole day) off the power (usage 1/2 and return 1/2) and the gas )
- Domoticz version: 2025.1
Re: P1 smart meter log sending a day
As a file needs some extra work but the log as text in an email be similar as example DzVents script in viewtopic.php?t=27982
Why would you need something like this? You can make reports from the report function of Domoticz.
If you want to use these files to make your own database you could also use the DataPush options like https://www.domoticz.com/wiki/HttpLink
- waaren
below dzVents script will send yesterdays log detail of the P1 energy meter as attached file in JSON format.kozzen wrote: Wednesday 03 March 2021 20:13 How can i get a log detail every day from the day before automaticly on mail in a file ?
__________________________________________________________________________________________________________________________
When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
___________________________________________________________________________________________________________________________
Script to send history data as mail attachment
requires:
dzVents >= 3.1.0 (domoticz V2020.2 build >= 12771 )
installed mail on os level (linux only)
History:
20210303 initial release
local scriptVar = 'mailHistory'
return
on =
timer =
'at 00:02', -- shortly after midnight to ensure shortlog contains 24 hours of yesterdays data.
shellCommandResponses =
scriptVar,
httpResponses =
scriptVar,
data =
'tempFile',
logging =
level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all ok
marker = scriptVar,
execute = function(dz, item)
--- Your settings below this line
local powerIDX = 35 -- change to idx of your P1 energy device
local emailTo = '[email protected]'
local subject = 'power log'
--- No changes required below this line
local function getDeviceLog(idx)
dz.openURL(
url = dz.settings['Domoticz url'] .. '/json.htm?type=graph&sensor=counter&range=day&idx=' .. powerIDX,
callback = scriptVar,
local function selectRecords(t)
local yesterday = os.date("%Y-%m-%d",os.time()-24*60*60)
local res = {}
for index, record in ipairs(t) do
if record.d:find(yesterday, 1, true) then
table.insert(res, record)
return dz.utils.toJSON(res)
local function makeFile(t)
dz.data.tempFile = os.tmpname()
file = io.open(dz.data.tempFile, 'w')
file:write( selectRecords(t))
file:close()
local function mailFile(f)
dz.executeShellCommand(
command = 'mail -A ' .. f .. ' -s "' .. subject .. '" ' .. emailTo .. ' < /dev/null 2> /dev/null ',
timeout = 20,
-- main
if item.isTimer then
getDeviceLog(powerIDX)
elseif item.isHTTPResponse then
if item.json then
makeFile(item.json.result)
mailFile(dz.data.tempFile)
dz.log('Problem retrieving data ' , dz.LOG_ERROR)
dz.log(item, dz.LOG_DEBUG)
elseif item.isShellCommandResponse then
if not(item.ok) then
dz.log('Problem with shellCommand ' , dz.LOG_ERROR)
os.execute('rm ' .. dz.data.tempFile)
kozzen
i'm getting the folowing errorwaaren wrote: Thursday 04 March 2021 1:19
timeout = 20,
2021-03-04 20:43:00.683 Error: dzVents: Error: (3.0.2) mailHistory: An error occurred when calling event handler Script #1
2021-03-04 20:43:00.683 Error: dzVents: Error: (3.0.2) mailHistory: ...domoticz/scripts/dzVents/generated_scripts/Script #1.lua:84: attempt to call a nil value (field 'executeShellCommand')
emailto is changed into my email adresses
POWERidx is changed to 1
- waaren
In the comments...kozzen wrote: Thursday 04 March 2021 20:51 i'm getting the folowing error
requires:
kozzen
How can i update to this 3.1.0, already used check for update or ./updaterelease
- waaren
After making a backup of your domoticz directory (without the backup sub directory) you can do from within the domoticz directorykozzen wrote: Thursday 04 March 2021 21:44 How can i update to this 3.1.0, already used check for update or ./updaterelease
sudo ./updatebetaDebian buster, bullseye on RPI-4, Intel NUC.
kozzen
thanks, did the update bubt now getting the following error in my mailbox or in the logwaaren wrote: Thursday 04 March 2021 21:48After making a backup of your domoticz directory (without the backup sub directory) you can do from within the domoticz directorykozzen wrote: Thursday 04 March 2021 21:44 How can i update to this 3.1.0, already used check for update or ./updatereleaseThis will bring your version to the latest build including the latest dzVents version.Code: Select all
sudo ./updatebeta
2021-03-04 21:56:00.947 Error: dzVents: Error: (3.1.5) mailHistory: Problem with shellCommand
- waaren
Can you show all log lines from the start of the script until this error and the debug lines after it ?kozzen wrote: Thursday 04 March 2021 22:032021-03-04 21:56:00.947 Error: dzVents: Error: (3.1.5) mailHistory: Problem with shellCommand
The domoticz log will show what mail command is send from domoticz to the shell. If you have that command working from the CLI, domoticz should also work.
It should look like below (with a different file name in /tmp and a different Email address).
mail -A /tmp/lua_Ob8JBf -s "power log" [email protected] < /dev/null 2> /dev/null
kozzen
2021-03-04 21:56:00.417 Status: dzVents: Info: mailHistory: ------ Start internal script: Script #1:, trigger: "at 21:56"
2021-03-04 21:56:00.418 Status: dzVents: Debug: mailHistory: OpenURL: url = http://127.0.0.1:8080/json.htm?type=gra ... =day&idx=1
2021-03-04 21:56:00.418 Status: dzVents: Debug: mailHistory: OpenURL: method = GET
2021-03-04 21:56:00.418 Status: dzVents: Debug: mailHistory: OpenURL: post data = nil
2021-03-04 21:56:00.418 Status: dzVents: Debug: mailHistory: OpenURL: headers = nil
2021-03-04 21:56:00.418 Status: dzVents: Debug: mailHistory: OpenURL: callback = mailHistory
2021-03-04 21:56:00.418 Status: dzVents: Info: mailHistory: ------ Finished Script #1
2021-03-04 21:56:00.419 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2021-03-04 21:56:00.668 Status: dzVents: Info: Handling httpResponse-events for: "mailHistory"
2021-03-04 21:56:00.668 Status: dzVents: Info: mailHistory: ------ Start internal script: Script #1: HTTPResponse: "mailHistory"
2021-03-04 21:56:00.791 Status: dzVents: Debug: mailHistory: ExecuteShellCommand: command = mail -A /tmp/lua_C851pY -s "power log" [email protected] < /dev/null 2> /dev/null
2021-03-04 21:56:00.791 Status: dzVents: Debug: mailHistory: ExecuteShellCommand: callback = mailHistory
2021-03-04 21:56:00.791 Status: dzVents: Debug: mailHistory: ExecuteShellCommand: timeout = 20
2021-03-04 21:56:00.791 Status: dzVents: Debug: mailHistory: ExecuteShellcommand: path = /home/pi/domoticz/scripts/dzVents/data/
2021-03-04 21:56:00.793 Status: dzVents: Info: mailHistory: ------ Finished Script #1
2021-03-04 21:56:00.793 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2021-03-04 21:56:00.946 Status: dzVents: Info: Handling shellcommandResponse-events for: "mailHistory"
2021-03-04 21:56:00.946 Status: dzVents: Info: mailHistory: ------ Start internal script: Script #1: ShellCommandResponse: "mailHistory"
2021-03-04 21:56:00.948 Status: dzVents: Debug: mailHistory: {["dump"]=function, ["errorText"]="", ["timeoutOccurred"]=false, ["isHTTPResponse"]=false, ["isScene"]=false, ["isCustomEvent"]=false, ["statusText"]="", ["isSystem"]=false, ["trigger"]="mailHistory", ["baseType"]="shellcommandResponse", ["isXML"]=false, ["isHardware"]=false, ["isDevice"]=false, ["hasLines"]=false, ["data"]="", ["isJSON"]=false, ["isVariable"]=false, ["ok"]=false, ["isGroup"]=false, ["isTimer"]=false, ["isSecurity"]=false, ["callback"]="mailHistory", ["statusCode"]=127, ["isShellCommandResponse"]=true, ["shellCommandResponse"]="mailHistory"}
2021-03-04 21:56:00.949 Status: dzVents: Info: mailHistory: ------ Finished Script #1
2021-03-04 21:57:01.643 Status: Notification sent (Email)
- waaren
What do do see when you give this command from the CLI ?kozzen wrote: Thursday 04 March 2021 22:21 mail -A /tmp/lua_C851pY -s "power log" [email protected] < /dev/null
What do you see when do a cat tmp/lua_C851pY
returncode 127 is most of the time "command not found"
kozzen
when i type this i get nothing no fault
i get permission denied
mail -A /tmp/lua_C851pY -s "power log" [email protected] < /dev/null 2> /dev/nullCode: Select all
cat tmp/lua_C851pY- waaren
I suggested something elsekozzen wrote: Thursday 04 March 2021 23:26 when i type thisi get nothing no faultCode: Select all
i get permission deniedCode: Select all
cat tmp/lua_C851pY
mail -A /tmp/lua_C851pY -s "power log" [email protected] < /dev/null if cat tmp/lua_C851pY gives you a permission denied then use
sudo cat tmp/lua_C851pY
Best to first get the mail command with attachment from the Command Line fixed. There are multiple ways to set that up.
To do this is not specific domoticz so you might want to look at specialized Linux forums to get that working.
