CommandArray not executed Topic is solved
azonneveld
Domoticz version: 2024.4
Post by azonneveld »
[EDIT]
Seems to be solved in 2021.1
[/EDIT]
Sometimes lines put into the commandarray are not executed.
Because I suspected the array was not always executed, I created two scripts, devicebased and a time based (acting as a watchdog)
The idea is that tWakeupAssist is triggered using a timer. This works fine.
Next, when the tWakeupAssist is set 'on' it should be set 'off' and some actions are triggered (indicated by "...some other actions are triggered...")
The timebased script, tests if the tWakeupAssist is 'on' for more than 2 minutes.
If the device is still on, the devicebased script has probably failed to run. So, tWakeupAssist is triggered again.
I checked the error-log, but it shows no errors.
The script fails approx. once or twice a month. De device is triggered every day.
Who could give me a suggestion to fix this failing script?
Devicebased lua script:
            if (deviceName=='tWakeupAssist') then
                    if deviceValue == "On" then
                        commandArray[#commandArray + 1] = {['tWakeupAssist'] = "Off"}
Timebased lua script
    -- WakeUpAssistant Check trigger
    if otherdevices['tWakeupAssist']=='On' then
        difference = timedifference(otherdevices_lastupdate['tWakeupAssist'])
        if difference >= 2 then
           commandArray[#commandArray + 1] = {['SendNotification']='WakeUpAssistant Trigger Failed'}
           commandArray[#commandArray + 1] = {['tWakeupAssist'] = 'On'}
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe (sems&modbus) - open weather map - wol - BBQ detection - rsync backup - zendure
jvdz
Domoticz version: 4.107
Re: CommandArray not executed
Post by jvdz »
How does the whole script look so we can check what else could interfere?
azonneveld
jvdz wrote: Thursday 04 March 2021 13:52 How does the whole script look so we can check what else could interfere?
--============== SETTINGS =========================
local LuxLow = 800
local tNow = os.date("*t");
local tNowInMin = tNow.min + tNow.hour * 60
local ZonOp = tonumber(timeofday['SunriseInMinutes']);
local ZonOnder = tonumber(timeofday['SunsetInMinutes'])
local t =  os.date("*t");
local Taan = uservariables["VerwarmingAanTemp"]
local Tuit = uservariables["VerwarmingUitTemp"]
local mCrestaTemp,mCrestaHumidity
-- loop through all the changed devices
for deviceName,deviceValue in pairs(devicechanged) do
-- WAKE ASSIST
    if otherdevices_svalues['Profiel'] ~= '40' then
        --if (otherdevices['WakeUpAssistant'] == 'On') then  -- WakeUpAssistant Enabled
        --for deviceName,deviceValue in pairs(devicechanged) do
                    if deviceValue == "On" and otherdevices['SkipWakeupassistant'] ~= 'On' and (otherdevices['WakeUpAssistant'] == 'On') then
                        --- UITZETTEN GAAT VIA GLOBALS, HIER WORDT TRIGGER GEZET
                        if (otherdevices_svalues['Profiel']~='30') then   -- niet uitzetten als profiel op nooituit staat
                            commandArray[#commandArray + 1] = {['Variable:WakeUpAssistTriggered']='1'}
                            commandArray[#commandArray + 1] = {['Variable:WakeUpAssistStarted']=tostring(tNowInMin)}
                        commandArray[#commandArray + 1] = {['Slaap Licht'] = "On"}   -- Activatie device voor group SleepAssistantBoven
                        commandArray[#commandArray + 1] = {['Ikea Socket 02'] = "On FOR 15"}  -- lamp op logeerkamer 15 minuten aan
                        if (((tNowInMin <= ZonOp) and (uservariables['LuxAlive'] == 0))  or ((tonumber(otherdevices['LuxMeter']) < LuxLow) and uservariables['LuxAlive'] == 1)) then
                            commandArray[#commandArray + 1] = {['Group:Woon Lamp'] = "On AFTER 10"}
                        if otherdevices_svalues['NotificationLevel']=='20' then -- NotificationLevel Debug
                           commandArray[#commandArray + 1] = {['SendNotification']='WakeUpAssistant Triggered'}
                        -- WakeUpAssistant uit functie onderdrukken via NooitUit_Auto
                        if otherdevices['NooitUit_Auto'] == 'On' then
                            if otherdevices_svalues['Profiel']~='30' then
                                commandArray[#commandArray + 1] = {['Profiel'] = "Set Level: 30"}
                                commandArray[#commandArray + 1] = {['NooitUit_Auto'] = "Off"}
                                if otherdevices_svalues['NotificationLevel']~='0' then -- Notification not muted
                                    commandArray[#commandArray + 1] = {['SendNotification']='Profiel geschakeld naar NooitUit_Auto, als je morgen de uitfunctie van WakeUpAssistant ook wilt onderdrukken, kies dan een profiel en zet NooitUit_Auto weer aan'}
-- KRABBEN REPORT
                        if otherdevices_svalues['NotificationLevel']~='0' then -- NotificationLevel not muted
                            local sCrestaTemp, sCrestaHumidity = otherdevices_svalues['Tuin Temp']
                            mCrestaTemp, mCrestaHumidity = otherdevices_svalues['Tuin Temp']:match("([^;]+);([^;]+)")
                            local mMin = otherdevices_svalues['Minimum Temp']
                            if tonumber(mCrestaTemp) < 3 and tonumber(mMin) < 0.5 then
                            --if tonumber(mCrestaTemp) < 30 and tonumber(mMin) < 10 then
                                os.execute ('(/bin/sleep 20 && /home/pi/domoticz/scripts/autokrabben.sh > /dev/null)&')
                                commandArray[#commandArray + 1] = {['SendNotification']='Krabben Report, temperatuur:' ..tostring(mCrestaTemp)}
                                --os.execute("/bin/sleep 1 && /home/pi/domoticz/scripts/autokrabben.sh")
                    elseif deviceValue == "Off" or otherdevices['SkipWakeupassistant'] == 'On' then
                           commandArray[#commandArray + 1] = {['SkipWakeupassistant']='Off'}
            --end
    elseif (otherdevices['WakeUpAssistant'] ~= 'On') then
            commandArray[#commandArray + 1] = {['Variable:WakeUpAssistTriggered']='0'}
-- Skip WakeUpAssistant
           local t = tonumber(uservariables["WakeUpAssistantNextMinutes"] - tNowInMin)
            --print('assistant ' .. tostring(t))
        if deviceName == 'SkipWakeupassistant' then
            if deviceValue == 'On' then
                if t < 0 or t > 90  then  -- WakeUpAssistant mag geskipt worden, maximaal 1 uur voor de wekker, en ook niet na de wekker
                    --print('assistant skip uitgezet')
This part is executed, since i received the notification:
jvdz
Post by jvdz »
Script looks good but has many triggers added to the queue, so are you sure you test for 2 minutes "On" in stead of 2 seconds?
azonneveld
jvdz wrote: Thursday 04 March 2021 16:12 Script looks good but has many triggers added to the queue, so are you sure you test for 2 minutes "On" in stead of 2 seconds?
When I check the tWakeupAssist device log, it is switched on and 2 minutes later switched to off.
2021-03-04 06:12:01	Off	EventSystem/AssistWakeUp2_2
2021-03-04 06:10:01	On	timer
azonneveld wrote: Thursday 04 March 2021 14:30
I added some lines to print the content of the commandArray (or empty) just before it is returned to the eventSystem. Maybe it will help in finding the issue.
local function tprint (t, indent, done) -- introduced done to prevent infinite loops for tables with self-references
  local done = done or {}
  indent = indent or 0
  for key, value in pairs (t) do
    pre = (string.rep (" ", indent)) -- indent it
    if type (value) == "table" and not done[value] then
      done [value] = true
      print (pre .. tostring (key) .. ":");
      tprint (value, indent + 2, done)
    elseif type(value) == 'function' and not done[value] then
      print( pre .. (tostring (key) .. "()"))
      pre = pre .. (tostring (key) .. ": ")
      print (pre .. tostring(value))
local LuxLow = 800
-- WAKE ASSIST
-- KRABBEN REPORT
            --end
if #commandArray == 0 then
    print ('Wake Assist: -empty commandArray-')
    tprint(commandArray)
jvdz
Post by jvdz »
But the question remains. ;)
Just a wild guess but I think you are testing for 2 seconds and have a racing condition on your hands were the event systems is still processing the list of events returned from the device script and the Time script is ran detecting the switch is "On" and it is 2 seconds ago.
So please check that function and when you are using the one I use with the same name, it does return the lapsed time in seconds, not minutes, so increase the 2 to something like 30 as I assume the stack of events will be done after 30 seconds. :)
azonneveld
jvdz wrote: Thursday 04 March 2021 16:56 I think you are testing for 2 seconds
Below is the time difference function I am using:
function round(num, numDecimalPlaces)
  local mult = 10^(numDecimalPlaces or 0)
  return math.floor(num * mult + 0.5) / mult
function timedifference(s)
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   difference = round((os.difftime (t1, t2) / 60),0)
   return difference
azonneveld
waaren wrote: Thursday 04 March 2021 16:54 I added some lines to print the content of the commandArray (or empty) just before it is returned to the eventSystem. Maybe it will help in finding the issue.
I have included your lines in my script... "now we wait..."
jvdz
Post by jvdz »
Also please show the domoticz log records when this issue happens so we can see the timing of the events, but I am pretty sure this will be a race condition.
azonneveld
I altered the logging lines a bit, because it was flooding the log
local doLog = false
-- WAKE ASSIST
                doLog = true
bottom of script
if doLog == true then
        print ('tWakeupAssist -empty commandArray-')
    	print("tWakeupAssist Failed to Trigger")
azonneveld
This is not gonna work... the notification of the failed trigger came first, meaning the script was not executed the first time.
Need to figure out some way to not flood the log, but capture the occurrence :roll: .
azonneveld wrote: Thursday 04 March 2021 18:09 I altered the logging lines a bit, because it was flooding the log
local doLog = false
-- WAKE ASSIST
                doLog = true
bottom of script
jvdz
Post by jvdz »
azonneveld wrote: Thursday 04 March 2021 17:37
Sorry, but I see I missed this one while typing my post around that time. So it is indeed the difference in minutes which makes the race condition unlikely and am curious if the extra logging will provide some explanation.
azonneveld
Found some kind of solution to prevent the log from flooding. Usually my 'alarm clock' goes between 06 and 07. So most of the time this should capture it.
Altered the logging lines to:
if tNowInMin > 360 and tNowInMin < 420 then
azonneveld
I think this is a hit!
The script that generates the logs:
if otherdevices['tWakeupAssist'] == 'On' then
    print("=============== tWakeupAssist DEBUG ====================")
The log:
2021-03-10 06:50:01.187 Status: Schedule item started! Name: tWakeupAssist, Type: On Time, DevID: 50, Time: 2021-03-10 06:50:01
2021-03-10 06:50:01.499 Status: LUA: =============== tWakeupAssist DEBUG ====================
2021-03-10 06:50:01.499 Status: LUA: tWakeupAssist -empty commandArray-
2021-03-10 06:50:01.787 Status: LUA: =============== tWakeupAssist DEBUG ====================
2021-03-10 06:50:01.787 Status: LUA: 1:
2021-03-10 06:50:01.787 Status: LUA: tWakeupAssist: Off
2021-03-10 06:50:01.787 Status: LUA: 2:
2021-03-10 06:50:01.787 Status: LUA: Variable:WakeUpAssistTriggered: 1
2021-03-10 06:50:01.787 Status: LUA: 3:
2021-03-10 06:50:01.787 Status: LUA: Variable:WakeUpAssistStarted: 410
2021-03-10 06:50:01.787 Status: LUA: 4:
2021-03-10 06:50:01.787 Status: LUA: Slaap Licht: On
2021-03-10 06:50:01.788 Status: LUA: 5:
2021-03-10 06:50:01.788 Status: LUA: Ikea Socket 02: On FOR 15
2021-03-10 06:50:01.788 Status: LUA: 6:
2021-03-10 06:50:01.788 Status: LUA: Group:Woon Lamp: On AFTER 10
2021-03-10 06:50:01.788 Status: LUA: 7:
2021-03-10 06:50:01.788 Status: LUA: Profiel: Set Level: 30
2021-03-10 06:50:01.788 Status: LUA: 8:
2021-03-10 06:50:01.788 Status: LUA: NooitUit_Auto: Off
2021-03-10 06:50:01.788 Status: LUA: 9:
2021-03-10 06:50:01.788 Status: LUA: SendNotification: Profiel geschakeld naar NooitUit_Auto....
2021-03-10 06:50:01.788 Status: LUA: =============== tWakeupAssist DEBUG ====================
azonneveld wrote: Wednesday 10 March 2021 7:53 I think this is a hit!
Can you please explain what the difference is between what you get and what you expected? Probably obvious for you but I am having a hard time to understand it.
azonneveld
waaren wrote: Wednesday 10 March 2021 10:40 Can you please explain what the difference is between what you get and what you expected? Probably obvious for you but I am having a hard time to understand it.
The script is executed when tWakeupAssist is 'on'. The first thing the script does, is switch it off.
So, it should always return a commandarray.
At 06:50:01.187 the tWakeupAssist is triggered.
Next the script runs, but it doesnt turn off the tWakeUpAssist; this gives: tWakeupAssist -empty commandArray-
288ms later, the script is started again, and now it is executed.
Good behaviour:
2021-03-11 06:10:01.012 Status: Schedule item started! Name: tWakeupAssist, Type: On Time, DevID: 50, Time: 2021-03-11 06:10:01
2021-03-11 06:10:01.215 Status: LUA: =============== tWakeupAssist DEBUG ====================
2021-03-11 06:10:01.215 Status: LUA: 1:
2021-03-11 06:10:01.215 Status: LUA: tWakeupAssist: Off
2021-03-11 06:10:01.215 Status: LUA: 2:
Bad behaviour:
Here is the summarized code:
-- Debug Logging
azonneveld
azonneveld wrote: Thursday 11 March 2021 7:27
So, it should always return a commandarray and only run once.
Good behaviour:
Bad behaviour, script is triggered twice:
........cut...............
-- Debug Logging
[/quote]
azonneveld wrote: Thursday 11 March 2021 7:27 So, it should always return a commandarray.
Bad behaviour:
Maybe you will see some interesting values when you add some prints. Something like below?
        print('sValue of Profiel: '  .. tostring(otherdevices_svalues['Profiel'] ) )
        -- Any other interesting device values Here ?
azonneveld
waaren wrote: Thursday 11 March 2021 8:46 Maybe you will see some interesting values when you add some prints. Something like below?
I think it is a longshot, but added:
Could not think of anything else, since the off statement is the first thing the script should handle. In case the script crashes on something, I would expect a notification in the log.
The strangest thing about it, is that the script is executed on the next run. It seems to me the execution is somehow interrupted, or the value of the tWakeupAssist is not accessible for a couple of ms.
