Neo Siren, like this one https://www.zigbee2mqtt.io/devices/NAS-AB02B0.html, on domoticz, it shows all devices on devices tab, except, the duration of the alarm! On page description, they have the 'duration' and on Z2M Log, they show the duration code insert, but dont appers on domoticz devices.
So I am not able to configure the duration of the alarm.
Anyone have one off this? How too add the duration?
Ty
Neo NAS-AB02B0 Siren 'Duration' device does not appear!
Re: Neo NAS-AB02B0 Siren 'Duration' device does not appear!
It is on the issue list of the plugin: https://github.com/stas-demydiuk/domoti ... issues/582
Wait until it is done or use the ui of z2m or use mqtt.
Nefsolive
Hi EddyG,EddyG wrote: Thursday 25 February 2021 9:20 It is on the issue list of the plugin: https://github.com/stas-demydiuk/domoti ... issues/582
Yes, I use Z2M Plugin and asked about this problem a few days. But so far no answer! How can I use the Z2M UI through the plugin?
You will have to wait until duration is incorporated into the plugin.
You can use the Z2M ui to set duration manually.
Or you can use mqtt commands to set duration, see: https://www.zigbee2mqtt.io/devices/NAS- ... nas-ab02b0
