I'm having a problem with the Domoticz - Remote Server. On the server i made a user with device sharing on and sharing 4 devices.
On the other domoticz system im connecting to the remote server with the user login and password.
The problem is that only 1 device out of the 4 devices is showing up in the device list. The 1 that is showing up is a 1 -wire temperature sensor.
The other 3 are:
1 Type: General, Kwh
2 Type: General, Custom sensor
These 3 are not showing up in the device list.
Domoticz - Remote server
- FireWizard
Re: Domoticz - Remote server
Hello @webrazor,
It is a known issue, that sensors, created by a plug-in are not sent to the Master Domoticz.
The same with created "Dummy" devices in the Slave.
Do the sensors, not sent, fall into one of those categories?
webrazor
To bad, yes the other 3 are dummy devices.
Are there any other simple solutions to get data from 1 domoticz to another domoticz?
- FireWizard
Hello @webrazor,
Yes, there are possibilities.
In that case I use MQTT between the Master and Slave Domoticz.
To do so, it is the easiest to install, both on the Master and on the Slave a MQTT server (broker).
As you indicate that your platform is a Raspberry Pi, you can follow this guideline:
https://randomnerdtutorials.com/how-to- ... pberry-pi/
or in Dutch:
https://raspberrypi.tilburgs.com/mosquitto-mqtt/
Beside that you need to install Node Red in order to convert the outgoing message from one device to the incoming from the other.
You can send both directions.
See: https://nodered.org/docs/getting-started/raspberrypi
If you need a flow, let me know. I have this "on stock".
or in Dutch:
- erem
- Domoticz version: 2021.1
Use a dzVents script to push the data to the master from the remote, or use mqtt.
this topic contains a start point
viewtopic.php?t=31618
Regards,
Rob
Rob
