Hello, I am trying to create a selector for the colors of the lamp, but it always gives an error.
If I enter the addresses in the browser, it is switched correctly, but it does not work in the Selectror switch.
Can anyone help me further?
RGB Selector dont work by me.
salopette
- Domoticz version: BETA
- sshot-4.jpg (112.83 KiB) Viewed 479 times
- sshot-3.jpg (68.24 KiB) Viewed 480 times
- sshot-2.jpg (213.07 KiB) Viewed 480 times
salopette
Re: RGB Selector dont work by me.
can someone please help me?
- waaren
You need 3 /// when using it like this.
So something like
http:///dz:8084/json.htm?type=command¶m=setcolbrightnessvalue&idx=3481&color={%22m%22:3,%22t%22:0,%22r%22:255,%22g%22:91,%22b%22:85,%22cw%22:0,%22ww%22:0}&brightness=3
salopette
Hi, I don't quite understand!
I take the link for the color / brightness change from Chrome in develop mode.
2021-02-17 18:51:03.306 Status: User: salopette (IP: 83.135.91.243) initiated a switch command (11917/Sauna-Color/Set Level)
2021-02-17 18:51:03.517 Error: Error opening url: http://192.168.178.37:8089/json.htm?type=command¶m=setcolbrightnessvalue&idx=486&color={%22m%22:3,%22t%22:0,%22r%22:255,%22g%22:137,%22b%22:0,%22cw%22:0,%22ww%22:0}&brightness=100
2021-02-17 18:51:06.017 Dummy: Light/Switch (Sauna-Color)
2021-02-17 18:51:06.007 Status: User: salopette (IP: 83.135.91.243) initiated a switch command (11917/Sauna-Color/Set Level)
2021-02-17 18:51:06.248 Error: Error opening url: http://192.168.178.37:8089/json.htm?type=command¶m=setcolbrightnessvalue&idx=486&color={%22m%22:3,%22t%22:0,%22r%22:255,%22g%22:137,%22b%22:0,%22cw%22:0,%22ww%22:0}&brightness=100
2021-02-17 18:51:07.588 Dummy: Light/Switch (Sauna-Color)
2021-02-17 18:51:07.580 Status: User: salopette (IP: 83.135.91.243) initiated a switch command (11917/Sauna-Color/Set Level)
2021-02-17 18:51:07.819 Error: Error opening url: http://192.168.178.37:8089/json.htm?type=command¶m=setcolbrightnessvalue&idx=486&color={%22m%22:3,%22t%22:0,%22r%22:255,%22g%22:137,%22b%22:0,%22cw%22:0,%22ww%22:0}&brightness=100
2021-02-17 18:51:09.259 Dummy: Light/Switch (Sauna-Color)
2021-02-17 18:51:09.246 Status: User: salopette (IP: 83.135.91.243) initiated a switch command (11917/Sauna-Color/Set Level)
2021-02-17 18:51:09.463 Error: Error opening url: http://192.168.178.37:8089/json.htm?type=command¶m=setcolbrightnessvalue&idx=486&color={%22m%22:3,%22t%22:0,%22r%22:255,%22g%22:137,%22b%22:0,%22cw%22:0,%22ww%22:0}&brightness=100
2021-02-17 18:51:10.738 Dummy: Light/Switch (Sauna-Color)
2021-02-17 18:51:10.730 Status: User: salopette (IP: 83.135.91.243) initiated a switch command (11917/Sauna-Color/Set Level)
2021-02-17 18:51:10.949 Error: Error opening url: http://192.168.178.37:8089/json.htm?type=command¶m=setcolbrightnessvalue&idx=486&color={%22m%22:3,%22t%22:0,%22r%22:255,%22g%22:137,%22b%22:0,%22cw%22:0,%22ww%22:0}&brightness=100- waaren
Not much to understand. Just add the extra /
