Only real usage of the Wunderground api in this script is for local barometer pressure. You could use another local (domoticz) barometer or switch to darkSky.roblom wrote: Sunday 02 June 2019 20:54 Is it just me or is this script not working anymore because the Wundergound stopped with the use of the API?
https://apicommunity.wunderground.com/w ... ground-api
dzVents version of the Solar Data Script [SOLVED]
- waaren
Re: dzVents version of the Solar Data Script
jake
Somehow I hadn't updated the script, therefore the mentioned 'elseif sunAltitude <= 1 and sunAltitude >= -7 then -- apply theoretical Lux of twilight' was not in my script, causing 'nil' values when sunaltitude was indeed beteen 1 and -7. I finally got disgusted in the error messages and checked out my script file. It's OK now.bramv wrote:@jake
Very strange. You had the same problem on 4 august with the 2.4 version of the script.
Maybee it's related to you browser or something like that. I see the script correct on this site in both versions.
It should be
So no == but >=
But if you loose a "greater then" character on this line maybee you loose some more and the script is not correct.
You also miss the part "sunAltitude <= 1 and"
However, (although I didn't check it now) I believe the AND statement in an if/elseif should be between brackets:
elseif (sunAltitude <= 1 and sunAltitude >= -7)- waaren
This is not the case. Only required use of brackets in a Lua if -, else - or elseif evaluation is to change default precedence (which is from left to right and standard calculation precedence )jake wrote: Sunday 27 October 2019 0:17 However, (although I didn't check it now) I believe the AND statement in an if/elseif should be between brackets:.Code: Select all
HFman
- Domoticz version: V4.1174
But Darksky doesn't have Lux right ? This is the one i still miss at every alternative ...waaren wrote: Sunday 02 June 2019 21:16Only real usage of the Wunderground api in this script is for local barometer pressure. You could use another local (domoticz) barometer or switch to darkSky.roblom wrote: Sunday 02 June 2019 20:54 Is it just me or is this script not working anymore because the Wundergound stopped with the use of the API?
Raspberry PI 3 - Opentherm Gateway + ESP8826 - EvoHome - ESPEasy CO2 + Fancontrol - RF-Link - zigbee2mqqt -
- waaren
Probably because Lux is very depending on your exact location. One small cloud between your location and the sun has a very big influence.HFman wrote: Sunday 27 October 2019 8:35 But Darksky doesn't have Lux right ? This is the one i still miss at every alternative ...
The new Buienradar hardware type does offer Sun power in watts / m2. Would that help you ?
HFman
Re: dzVents version of the Solar Data Script [SOLVED]
Yeah... Great thanks that is excatly what i need !
deennoo
Hello,oredin wrote: Monday 01 April 2019 10:19Hi,
This value is only used as a step for the whole computation and to compute the Lux value.
If you want to know more about it, look for Solar irradiance.
I'm facing a probleme : LUX Value Is crazy :
UpdateMeter: Error converting sValue/sUsage! (IDX: 19493, sValue: '4937972264600400208183447097222515965420472634484228007257426547208404256159892098951988747359340880352772096', sUsage: '0', dType: 246, sType: 1)Code: Select all
2020-05-09 15:45:11.750 Status: dzVents: Info: solarData 2.4.1-DarkSky: ============== SUN LOG ==================
2020-05-09 15:45:11.750 Status: dzVents: Info: solarData 2.4.1-DarkSky: Martillac latitude: 44.712698, longitude: -0.543056
2020-05-09 15:45:11.750 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Home altitude = 40 m
2020-05-09 15:45:11.750 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Angular Speed = 0.98562628336756 per day
2020-05-09 15:45:11.750 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Declination = 17.711758872199°
2020-05-09 15:45:11.750 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Universal Coordinated Time (UTC) 13.75 H.dd
2020-05-09 15:45:11.750 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Solar Hour 13.713796266667 H.dd
2020-05-09 15:45:11.750 Status: dzVents: Info: solarData 2.4.1-DarkSky: Altitude of the sun = 55.486909377782°
2020-05-09 15:45:11.750 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Angular hourly = -25.706944°
2020-05-09 15:45:11.750 Status: dzVents: Info: solarData 2.4.1-DarkSky: Azimuth of the sun = 226.82624786338°
2020-05-09 15:45:11.750 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Duration of the sun stroke of the day = 14.46 H.dd
2020-05-09 15:45:11.750 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Radiation max in atmosphere = 1332.59 W/m²
2020-05-09 15:45:11.750 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Local relative pressure = 999.90002441406 hPa
2020-05-09 15:45:11.750 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Absolute pressure in atmosphere = 995.10002441406 hPa
2020-05-09 15:45:11.750 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Coefficient of mitigation M = -467.60921288158 M0 = -465.36446423969
2020-05-09 15:45:11.750 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Using the newly fetched cloud cover value: 0.52 with UTC timestamp: 1589031911
2020-05-09 15:45:11.750 Status: dzVents: Info: solarData 2.4.1-DarkSky: Okta = 0.52
2020-05-09 15:45:11.750 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Kc = 0.91881559132433
2020-05-09 15:45:11.750 Status: dzVents: Info: solarData 2.4.1-DarkSky: Direct Radiation = 6.0137127581757e+106 W/m²
2020-05-09 15:45:11.750 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Scattered Radiation = -1.7680315509037e+106 W/m²
2020-05-09 15:45:11.750 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Total radiation = 4.2456812072721e+106 W/m²
2020-05-09 15:45:11.750 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Total Radiation in lux = 5.3742800092051e+108 Lux
2020-05-09 15:45:11.750 Status: dzVents: Info: solarData 2.4.1-DarkSky: Total weighted lux = 4.9379722646004e+108 Lux
2020-05-09 15:45:11.751 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Processing device-adapter for Luminosite Exterieur: Lux device adapter
2020-05-09 15:45:11.751 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Processing device-adapter for Azimute Soleil: Custom sensor device adapter
2020-05-09 15:45:11.751 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Processing device-adapter for Elevation soleil: Custom sensor device adapter
2020-05-09 15:45:11.752 Status: dzVents: Debug: solarData 2.4.1-DarkSky: Processing device-adapter for Couverture Nuageuse: Percentage device adapterFrom Darksky API :
longitude: -0.543056,
timezone: "Europe/Paris",
currently: {
time: 1589032896,
summary: "Faibles Passages Nuageux",
icon: "partly-cloudy-day",
precipIntensity: 0.0075,
precipProbability: 0.03,
precipType: "rain",
temperature: 26.52,
apparentTemperature: 26.54,
dewPoint: 15.29,
humidity: 0.5,
pressure: 1007.8,
windSpeed: 12.36,
windGust: 16.14,
windBearing: 111,
cloudCover: 0.47,
uvIndex: 5,
visibility: 16.093,
ozone: 347.1
offset: 2
http://domo-attitude.fr
I'll try to check the operations made to compute this value
It only appeared when you updated the script after my last correction this week-end ?
deennoo
nope this kind of value come 4/3 mounth agooredin wrote: Monday 11 May 2020 12:01
Ok, I'll check it out this week end.
gawel31
hi,
this DZvents script was working on my old raspberry. I changed my raspberry (raspberry pi 4 and new raspberry pi os) and now it doesn't work.
Logs:
So it seems to calculate...but i also have:
an my devices doesn't update;
Do you know what is the problem?
thanks
Logs:
2020-12-17 13:15:11.096 Status: dzVents: Info: solarData 2.4.1-DarkSky:
2020-12-17 13:15:11.096 Status: dzVents: Info: solarData 2.4.1-DarkSky: ============== SUN LOG ==================
2020-12-17 13:15:11.096 Status: dzVents: Info: solarData 2.4.1-DarkSky: Bayonnelatitude: 43.492949, longitude: -1.474841
2020-12-17 13:15:11.096 Status: dzVents: Info: solarData 2.4.1-DarkSky: Altitude of the sun = 23.077528353196�
2020-12-17 13:15:11.096 Status: dzVents: Info: solarData 2.4.1-DarkSky: Azimuth of the sun = 182.2697185954�
2020-12-17 13:15:11.096 Status: dzVents: !Info: solarData 2.4.1-DarkSky: Function math.pow(x, y) has been deprecated in Lua 5.3. Please consider changing code to x^y
2020-12-17 13:15:11.096 Status: dzVents: Info: solarData 2.4.1-DarkSky: Okta = 0.68
2020-12-17 13:15:11.096 Status: dzVents: Info: solarData 2.4.1-DarkSky: Direct Radiation = 150.14 W/m�
2020-12-17 13:15:11.096 Status: dzVents: Info: solarData 2.4.1-DarkSky: Total weighted lux = 25789.56 Lux
2020-12-17 13:15:11.108 Status: dzVents: Info: solarData 2.4.1-DarkSky: ------ Finished solarData.lua Code: Select all
2020-12-17 12:45:11.308 Error: dzVents: Error: (3.0.2) solarData 2.4.1-DarkSky: An error occurred when calling event handler solarData
2020-12-17 12:45:11.308 Error: dzVents: Error: (3.0.2) solarData 2.4.1-DarkSky: /home/pi/domoticz/scripts/dzVents/scripts/solarData.lua:196: attempt to perform arithmetic on a nil value (field 'lux') Do you know what is the problem?
thanks
- waaren
I looked at a couple of versions but do not see a version with the string lux in line 196gawel31 wrote: Thursday 17 December 2020 13:31Code: Select all
2020-12-17 12:45:11.308 Error: dzVents: Error: (3.0.2) solarData 2.4.1-DarkSky: An error occurred when calling event handler solarData 2020-12-17 12:45:11.308 Error: dzVents: Error: (3.0.2) solarData 2.4.1-DarkSky: /home/pi/domoticz/scripts/dzVents/scripts/solarData.lua:196: attempt to perform arithmetic on a nil value (field 'lux')
Can you share the script that generates this error?
gawel31
here is the script:
Prerequisits
Requires Domoticz v3.8551 or later
Platform independent
CHANGE LOG: See http://www.domoticz.com/forum/viewtopic.php?t=19220
Virtual Lux sensor and other real-time solar data
-- Authors ----------------------------------------------------------------
V1.0 - Sébastien Joly - Great original work
V1.1 - Neutrino - Adaptation to Domoticz
V1.2 - Jmleglise - An acceptable approximation of the lux below 1° altitude for Dawn and dusk + translation + several changes to be more userfriendly.
V1.3 - Jmleglise - No update of the Lux data when <=0 to get the sunset and sunrise with lastUpdate
V1.4 - use the API instead of updateDevice to update the data of the virtual sensor to be able of using devicechanged['Lux'] in our scripts. (Due to a bug in Domoticz that doesn't catch the devicechanged event of the virtual sensor)
V1.5 - xces - UTC time calculation.
V2.0 - BakSeeDaa - Converted to dzVents and changed quite many things.
V2.4.1-DarkSky - oredin - Use Dark Sky API instead of WU API
-- Variables to customize ------------------------------------------------
local city = 'Bayonne' -- Only for log purpose
local countryCode = 'FR' -- Only for log purpose
local idxSolarAzimuth = 199 -- (Integer) Virtual Azimuth Device ID
local idxSolarAltitude = 200 -- (Integer) Your virtual Solar Altitude Device ID
local dsAPIkey = '' -- Dark Sky API Key
local logToFile = false -- (Boolean) Set to true if you also wish to log to a file. It might get big by time.
local tmpLogFile = '/tmp/logSun.txt'-- Logging to a file if specified
local fetchIntervalDayMins = 15 -- Day time scraping interval. Never set this below 4 if you have a free WU API account.
local fetchIntervalNightMins = 30 -- Night time scraping interval.
-- Optional Domoticz devices
local idxLux = 198 -- (Integer) Domoticz virtual Lux device ID
local idxCloudCover = 336 -- (Integer) Domoticz Cloud Cover (PERCENTAGE TYPE) sensor device ID
local idxPressure = nil -- (Integer) Your Pressure Device ID. if you don't have one, the pressure value will be retrieve from Dark Sky API
-- (You don't have to configure these if you accept the values returned by the weather observation station)
local latitude = 43.492949 -- Latitude. (Decimal number) Decimal Degrees. E.g. something like 51.748485
local longitude = -1.474841 -- Longitude. (Decimal number) Decimal Degrees. E.g.something like 5.629728.
local altitude = 19 -- Altitude. (Integer) Meters above sea level.
-- Please don't make any changes below this line (Except for setting logging level)
local scriptName = 'solarData'
local scriptVersion = '2.4.1-DarkSky'
active = true,
logging = {
-- level = domoticz.LOG_DEBUG, -- Uncomment to override the dzVents global logging setting
marker = scriptName..' '..scriptVersion
timer = {
'every '..tostring(fetchIntervalDayMins)..' minutes at daytime',
'every '..tostring(fetchIntervalNightMins)..' minutes at nighttime',
httpResponses = {
scriptName..'DS',
data = {
lastOkta = {initial=0}
if item.isTimer then
local url = 'https://api.darksky.net/forecast/'..dsAPIkey..'/'..latitude..','..longitude..'?exclude=minutely,hourly,daily,alerts,flags&lang=fr&units=ca'
domoticz.log('Requesting new weather data from Dark Sky API...', domoticz.LOG_DEBUG)
domoticz.log('URL used: '..url, domoticz.LOG_DEBUG)
domoticz.openURL({url = url, method = 'GET', callback = scriptName..'DS'}).afterSec(10)
if not item.isHTTPResponse then return end
local response = item
if response.trigger ~= scriptName..'DS' then return end
domoticz.log('Dark Sky API json data has been received', domoticz.LOG_DEBUG)
local function leapYear(year)
return year%4==0 and (year%100~=0 or year%400==0)
local dsAPIData = response.json
if not dsAPIData then
domoticz.log('Could not find any dsAPIData in the DS API response', domoticz.LOG_ERROR)
return
local arbitraryTwilightLux = 6.32 -- W/m² egal 800 Lux (the theoritical value is 4.74 but I have more accurate result with 6.32...)
local constantSolarRadiation = 1361 -- Solar Constant W/m²
-- In case of that latitude, longitude and altitude has not been defined in the configuration,
-- we simply use the values that is returned for the current observation location.
-- Reading longitude, latitude and altitude from the observation_location instead of from
-- display_location. API documentation is not so clear about what display_location is.
if not latitude then
domoticz.log('You must change the latitude value !', domoticz.LOG_ERROR)
return
if not longitude then
domoticz.log('You must change the longitude value !', domoticz.LOG_ERROR)
return
if not altitude then
domoticz.log('You must change the altitude value !', domoticz.LOG_ERROR)
return
local relativePressure = dsAPIData.currently.pressure -- if you have an another way to get the Pressure, (local barometer ...) then you may optimize the script
if idxPressure and domoticz.devices(idxPressure).barometer then
relativePressure = domoticz.devices(idxPressure).barometer
local year = os.date('%Y')
local numOfDay = os.date('%j')
local nbDaysInYear = (leapYear(year) and 366 or 365)
local angularSpeed = 360/365.25
local declination = math.deg(math.asin(0.3978 * math.sin(math.rad(angularSpeed) *(numOfDay - (81 - 2 * math.sin((math.rad(angularSpeed) * (numOfDay - 2))))))))
local timeDecimal = (os.date('!%H') + os.date('!%M') / 60) -- Coordinated Universal Time (UTC)
local solarHour = timeDecimal + (4 * longitude / 60 ) -- The solar Hour
local hourlyAngle = 15 * ( 12 - solarHour ) -- hourly Angle of the sun
local sunAltitude = math.deg(math.asin(math.sin(math.rad(latitude))* math.sin(math.rad(declination)) + math.cos(math.rad(latitude)) * math.cos(math.rad(declination)) * math.cos(math.rad(hourlyAngle))))-- the height of the sun in degree, compared with the horizon
local azimuth = math.acos((math.sin(math.rad(declination)) - math.sin(math.rad(latitude)) * math.sin(math.rad(sunAltitude))) / (math.cos(math.rad(latitude)) * math.cos(math.rad(sunAltitude) ))) * 180 / math.pi -- deviation of the sun from the North, in degree
local sinAzimuth = (math.cos(math.rad(declination)) * math.sin(math.rad(hourlyAngle))) / math.cos(math.rad(sunAltitude))
if(sinAzimuth<0) then azimuth=360-azimuth end
local sunstrokeDuration = math.deg(2/15 * math.acos(- math.tan(math.rad(latitude)) * math.tan(math.rad(declination)))) -- duration of sunstroke in the day . Not used in this calculation.
local RadiationAtm = constantSolarRadiation * (1 +0.034 * math.cos( math.rad( 360 * numOfDay / nbDaysInYear ))) -- Sun radiation (in W/m²) in the entrance of atmosphere.
-- Coefficient of mitigation M
local absolutePressure = relativePressure - domoticz.utils.round((altitude/ 8.3),1) -- hPa
local sinusSunAltitude = math.sin(math.rad(sunAltitude))
local M0 = math.sqrt(1229 + math.pow(614 * sinusSunAltitude,2)) - 614 * sinusSunAltitude
local M = M0 * relativePressure/absolutePressure
domoticz.log('', domoticz.LOG_INFO)
domoticz.log('============== SUN LOG ==================', domoticz.LOG_INFO)
domoticz.log(city .. 'latitude: ' .. latitude .. ', longitude: ' .. longitude, domoticz.LOG_INFO)
domoticz.log('Home altitude = ' .. tostring(altitude) .. ' m', domoticz.LOG_DEBUG)
domoticz.log('Angular Speed = ' .. angularSpeed .. ' per day', domoticz.LOG_DEBUG)
domoticz.log('Declination = ' .. declination .. '°', domoticz.LOG_DEBUG)
domoticz.log('Universal Coordinated Time (UTC) '.. timeDecimal ..' H.dd', domoticz.LOG_DEBUG)
domoticz.log('Solar Hour '.. solarHour ..' H.dd', domoticz.LOG_DEBUG)
domoticz.log('Altitude of the sun = ' .. sunAltitude .. '°', domoticz.LOG_INFO)
domoticz.log('Angular hourly = '.. hourlyAngle .. '°', domoticz.LOG_DEBUG)
domoticz.log('Azimuth of the sun = ' .. azimuth .. '°', domoticz.LOG_INFO)
domoticz.log('Duration of the sun stroke of the day = ' .. domoticz.utils.round(sunstrokeDuration,2) ..' H.dd', domoticz.LOG_DEBUG)
domoticz.log('Radiation max in atmosphere = ' .. domoticz.utils.round(RadiationAtm,2) .. ' W/m²', domoticz.LOG_DEBUG)
domoticz.log('Local relative pressure = ' .. relativePressure .. ' hPa', domoticz.LOG_DEBUG)
domoticz.log('Absolute pressure in atmosphere = ' .. absolutePressure .. ' hPa', domoticz.LOG_DEBUG)
domoticz.log('Coefficient of mitigation M = ' .. M ..' M0 = '..M0, domoticz.LOG_DEBUG)
local okta = dsAPIData.currently.cloudCover
-- We store the last fetched value here to be used as a backup value
domoticz.log('Using the newly fetched cloud cover value: '..okta..' with UTC timestamp: '..dsAPIData.currently.time, domoticz.LOG_DEBUG)
domoticz.data.lastOkta = okta
local Kc = 1-0.75*math.pow(okta,3.4) -- Factor of mitigation for the cloud layer
local directRadiation, scatteredRadiation, totalRadiation, Lux, weightedLux
if sunAltitude > 1 then -- Below 1° of Altitude , the formulae reach their limit of precision.
directRadiation = RadiationAtm * math.pow(0.6,M) * sinusSunAltitude
scatteredRadiation = RadiationAtm * (0.271 - 0.294 * math.pow(0.6,M)) * sinusSunAltitude
totalRadiation = scatteredRadiation + directRadiation
Lux = totalRadiation / 0.0079 -- Radiation in Lux. 1 Lux = 0,0079 W/m²
weightedLux = Lux * Kc -- radiation of the Sun with the cloud layer
directRadiation = 0
scatteredRadiation = 0
arbitraryTwilightLux=arbitraryTwilightLux-(1-sunAltitude)/8*arbitraryTwilightLux
totalRadiation = scatteredRadiation + directRadiation + arbitraryTwilightLux
elseif sunAltitude < -7 then -- no management of nautical and astronomical twilight...
directRadiation = 0
totalRadiation = 0
Lux = 0
weightedLux = 0 -- should be around 3,2 Lux for the nautic twilight. Nevertheless.
domoticz.log('Okta = '..okta, domoticz.LOG_INFO)
domoticz.log('Kc = ' .. Kc, domoticz.LOG_DEBUG)
domoticz.log('Direct Radiation = '.. domoticz.utils.round(directRadiation,2) ..' W/m²', domoticz.LOG_INFO)
domoticz.log('Scattered Radiation = '.. domoticz.utils.round(scatteredRadiation,2) ..' W/m²', domoticz.LOG_DEBUG)
domoticz.log('Total radiation = ' .. domoticz.utils.round(totalRadiation,2) ..' W/m²', domoticz.LOG_DEBUG)
domoticz.log('Total Radiation in lux = '.. domoticz.utils.round(Lux,2)..' Lux', domoticz.LOG_DEBUG)
domoticz.log('Total weighted lux = '.. domoticz.utils.round(weightedLux,2)..' Lux', domoticz.LOG_INFO)
-- No update if Lux is already 0. So lastUpdate of the Lux sensor will keep the time when Lux has reached 0.
-- (Kind of timeofday['SunsetInMinutes'])
if idxLux and domoticz.devices(idxLux).lux + domoticz.utils.round(weightedLux, 0) > 0 then
domoticz.devices(idxLux).updateLux(domoticz.utils.round(weightedLux,0))
domoticz.devices(idxSolarAzimuth).updateCustomSensor(domoticz.utils.round(azimuth,0))
domoticz.devices(idxSolarAltitude).updateCustomSensor(domoticz.utils.round(sunAltitude,0))
local oktaPercent = domoticz.utils.round(okta*100)
local fetchIntervalMins = (domoticz.time.matchesRule('at daytime') and fetchIntervalDayMins or fetchIntervalNightMins)
if idxCloudCover and ((domoticz.devices(idxCloudCover).percentage ~= oktaPercent)
or (domoticz.devices(idxCloudCover).lastUpdate.minutesAgo >= (60 - fetchIntervalMins))) then
domoticz.devices(idxCloudCover).updatePercentage(oktaPercent)
if logToFile then
local logDebug = os.date('%Y-%m-%d %H:%M:%S',os.time())
logDebug=logDebug..' Azimuth:' .. azimuth .. ' Height:' .. sunAltitude
logDebug=logDebug..' cloud cover:' .. okta..' KC:'.. Kc
logDebug=logDebug..' Direct:'..directRadiation..' inDirect:'..scatteredRadiation..' TotalRadiation:'..totalRadiation..' LuxCloud:'.. domoticz.utils.round(weightedLux,2)
os.execute('echo '..logDebug..' >>'..tmpLogFile) -- compatible Linux & Windows
Last edited by gawel31 on Thursday 17 December 2020 23:02, edited 1 time in total.
- waaren
I suspect the device with id 198 is either not activated, -not a lux device or none existent.
If you replace the script with below one, it will give some extra details in the log on what is going wrong.
Prerequisits
local dsAPIkey = 'xxxxxxxxxxxxxxxxxxxx' -- Dark Sky API Key
active = true,
logging = {
timer = {
httpResponses = {
scriptName..'DS',
data = {
return
return
return
return
directRadiation = 0
directRadiation = 0
totalRadiation = 0
Lux = 0
if idxLux and domoticz.devices(idxLux) then
local myLux = domoticz.devices(idxLux)
local logMessage = '\n'
logMessage = logMessage .. '\nDevice: ' .. myLux.name
logMessage = logMessage .. '\ntype: ' .. myLux.deviceType
logMessage = logMessage .. '\nsubtype: ' .. myLux.deviceSubType
logMessage = logMessage .. '\nnvalue: ' .. myLux.nValue
logMessage = logMessage .. '\nsvalue: ' .. myLux.sValue
logMessage = logMessage .. '\nlux: ' .. tostring(myLux.lux)
domoticz.log(logMessage, domoticz.LOG_FORCE)
if myLux.lux then
if ( myLux.lux + domoticz.utils.round(weightedLux)) > 0 then
myLux.updateLux(domoticz.utils.round(weightedLux)).silent()
domoticz.log('Device with idx ' .. idxLux .. ' is not a lux type device!', domoticz.LOG_ERROR)
domoticz.log('Device with idx ' .. idxLux .. ' does not exist or is not active!', domoticz.LOG_ERROR)
if logToFile then
gawel31
It's OK! i made a mistake...my device was not a lux device.... Thanks a lot!
jmleglise
- Domoticz version: 2022.1
Please stop using this old thread. The new one is here : https://domoticz.com/forum/viewtopic.php?f=72&t=35541
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
KMTronic USB relay
