Tesla hardware module
Re: Tesla hardware module
Yes, I have.....
MrHobbes74
- Domoticz version: latest B
Ok. Well I guess you need to play with the parameters. Otherwise I wouldn’t know it. I’ll try tonight to setup MFA to check.chrispazz wrote:Yes, I have.....
MrHobbes74
Did you try to provide a backup passcode instead of the passcode? That will avoid the devices section.MrHobbes74 wrote:Ok. Well I guess you need to play with the parameters. Otherwise I wouldn’t know it. I’ll try tonight to setup MFA to check.chrispazz wrote:Yes, I have.....
Tried:
TypeError: <lambda>() takes 1 positional argument but 2 were given
MrHobbes74
Weird. I’ll have a look tonight. Maybe I’ll copy and adapt it to my own scriptchrispazz wrote:Tried:
- dyter
- Domoticz version: 8841
If you have Teslamate, you can extract the token API with command:
docker exec -it teslamate_database_1 psql -U teslamate -d teslamate -c "select access from tokens;"
(teslamate_database_1 is the name of docker machine)
And on android, you can use MyTeslaCore to get a new API
Domoticz v2024.1 on Synology Docker host, RFLink, ESPEasy wemos D1, Ecodevices, relays x8, dahua doorbell, reolink cameras ....
YOU ARE MY HERO!
It works!
It works!
dranreb38
Good morning all,
I now own a Tesla Model 3 LR 2021, but I cannot use Tesla hardware because I have an error log:
2021-02-27 19: 09: 35.685 Error: TeslaApi: Received token is zero length.
2021-02-27 19: 09: 35.686 Error: Tesla: Aborting due to too many failed authentication attempts (and prevent getting blocked)!
I enter my email address from my tesla account, with the password. (I do not use two-factor authentication) then my VIN. yet my password is correct. I also use teslamate which works. Thank you for your help
Domoticz 2020.2 (build 12743) on Raspberry Raspbian GNU/Linux 10 (buster)
MrHobbes74
Hi,dranreb38 wrote:Good morning all,
Tesla changed the authorization procedure.
You need to update to the latest beta version, there you can add a self generated token. See also earlier in this forum.
JPSke
- Domoticz version: 2022.1
@MrHobbes74
In the car you can adjust the charge rate. Any chance of making that possible in Domoticz?
hamster
- Domoticz version: 2020.2
Hey @MrHobbes74, while you work on getting the new API integrated, would it be difficult to change the "state" of the sensor to something like "token expired" when a manually entered token needs to be refreshed?
MrHobbes74
Good point! I’m not working on getting the API integrated at the moment due to lack of time. But this I can do, I think it’s a good idea. Keep you posted!hamster wrote: Thursday 25 March 2021 3:14 Hey @MrHobbes74, while you work on getting the new API integrated, would it be difficult to change the "state" of the sensor to something like "token expired" when a manually entered token needs to be refreshed?
JeandelaPierre
How do I install the new hardware module ... sorry I'm quite a newbie on this. I have the toke n zero length issue as we!l.... But i can't find the how to update the hardware module anywhere ....MrHobbes74 wrote: Friday 05 February 2021 8:57It’s integrated! If you download the latest beta, you can fill in a manual API key (access token).MrHobbes74 wrote:All, I have added the option to specify a API key (a.k.a. access token) in the tesla configuration.
This allows you to use another app to generate the API key / access token
(e.g. via https://registration.teslatasks.com/generateTokens, or download a python script like https://github.com/enode-engineering/te ... n/tesla.py which worked for me)
A token usually works for about a month.
That will give me some time to consider a solution, and meanwhile the tesla module can be used again.
The pull request into domoticz is active, hopefully integration is tomorrow.
Thnx in advance mrHobbes...
hamster
you have to update to the latest domoticz beta
PVuser
- Domoticz version: 2021.1
Using https://abetterrouteplanner.com, the login is always available. Also they have some additional Values. I really don't know how they do it, but perhaps they are open for information. SmartHome is a really other section
JeandelaPierre
thnx! did that onze and my database crashed ... and had to reinstall everything all over again .... I'm going to look for the right procedure. Thnx!
grtz,
John
mjvh
Hi all,dyter wrote: Friday 12 February 2021 19:18 If you have Teslamate, you can extract the token API with command:
im new here and running EVVehicle for my Tesla S and installed Teslamate to extract a token to use EVVehicle.
Can anyone tell me step-by-step how to extract my token from Teslamate? Tnx all!
- dyter
This is the only one step !
hamster
@MrHobbes74 would you be able to provide a quick example on how to force an Active update via URL? was thinking it would be nice to force an update when i got home from my phone via Tasker/cURL/similar, but not sure where to start. checked wiki but didnt see any example commands yet. thanks!
JPSke
Is there someone still involved in maintenance for this plugin?
I am noticing some strange behaviour lately: although everything seems normal, I get these weird messages in the log:
2022-01-24 16:24:01.013 Status: Tesla: Executing command: Get Location state
2022-01-24 16:24:02.866 Status: Tesla: Executing command: Get Charge state
2022-01-24 16:24:04.706 Status: Tesla: Executing command: Start charging
2022-01-24 16:24:05.206 Error: Tesla: Timeout requesting Start charging. Will retry.
2022-01-24 16:24:10.509 Status: Tesla: Executing command: Start charging
2022-01-24 16:24:10.961 Error: Tesla: Timeout requesting Start charging. Will retry.
2022-01-24 16:24:16.326 Status: Tesla: Executing command: Start charging
2022-01-24 16:24:16.871 Error: Tesla: Timeout requesting Start charging. Will retry.
and:
Error: Tesla: Multiple tries requesting Start charging. Assuming car asleep.
Thanks in advance for any help.
JP
and:
JP
