No temperature visible at Qubino ZMNHND1 Flush 1D relay+
Ptje
Post by Ptje »
I had a Qubino ZMNHND1 Flush 1D relay+ I want it to use for a heater in the garage. That was no problem. I can switch it on and off. Now I added a original temperature sensor to use is for temperature control.
I can't see no temperature at the hardware tab. I did exclude the node and include it again with a connected temperature sensor. There is no temperature visible in the hardware tab.
I see,
649 Controller 0005532C 1 Heat Light/Switch Switch Off - - 2021-02-10 22:00:32
648 Controller 00055300 1 Sensor Light/Switch Switch Off - - 2021-02-10 22:00:32
647 Controller 00055301 1 Switch Light/Switch Switch Off - - 2021-02-10 22:00:32
I bought the sensor at robbshop and send them a mail why it does not work. The tell they don't support open source projects and that I have to search at forums.
Is here someone who can and will help me ?
Greetings,
Peter
kiddigital
Re: No temperature visible at Qubino ZMNHND1 Flush 1D relay+
Post by kiddigital »
Make sure that new devices can be added (and not only for 5 minutes as it van take longer for Z-wave devices).
Look in the Z-wave controller panel and look if the temperature is available there. If not, ask for a node refresh (press the button) and wait a while to allow the node to respond to the refresh request (depending on the sleep interval, etc. it can take an hour or longer).
Also, you can take a look at the Z-Wave device definition file for your node type to see if temperature is defined as a node property. If not, than Z-Wave (and thus Domoticz also) is unaware of the existence of the temperature sensor.
Good luck and let us know if you succeed (or not).
