Steinel Motion sensor not switching
DwaynePeeters
Post by DwaynePeeters »
Hello all,
Could someone please perhaps point me in the right direction solving the following?:
Today I installed a new motion Sensor from Steinel (IS 140-2) and all is working well. In Domoticz it shows as a switch, and if I walk pass, the switch turns on and after a few seconds automatically off. But when I try to let it switch on a light, it refuses to do so.
I've tried switching the light via a blocky script and I've tried configuring a sub/slave device, both not working.
- Switching the light manually works
- Motion detector works
- When configured as sub/slave, the motion sensor turns on (in dashboard), also the light turns on in dashboard, but the actual light doesn't switch on.
My blocky switch simply looks like this:
if "pir" = on
do set "light" = on
Any help would be much appreciated! :D
Kind regards,
Dwayne
JeroenL
Domoticz version: 2023.2
Re: Steinel Motion sensor not switching
Post by JeroenL »
Dear Dwayne,
I never managed to get it stable in Domoticz unfortunately. Recently moved all my Zwave devices to Fibaro Homecenter 3, and domoticz controls them as secondary controller.
Whilst looking for this migration, I can across this info for the Steinel, which is also problematic out of the box in Fibaro.
https://intuitech.de/steinel/
Basically set the following parameters:
Param 1 op 5
Param 2 op 2000
Param 8 op 0
For me this finally worked after 6 months of messing about. Maybe the same works in domoticz.
