Just today I installed the garden plants that cannot stand frost in the barn in the garden (schuurtje)
I installed an electric ventilator/heater, a Shelly device and a temperature sensor as well.
Here is the simple script that adapts heating times depending on temperature fall.
-- Schuurtje -- vorstbeveiliging
local SWITCH = 'Shelly 21-0' -- switch device
local TEMP_SETPOINT = 0.5
local TEMP_SENSOR = 'TFA2'
local BAT_THRESHOLD = 30 -- low temperature sensor battery warning
local LOGGING = true
return
on =
timer =
'every 15 minutes'
--LOG level: This is the log level you want for this script. Can be domoticz.LOG_INFO, domoticz.LOG_MODULE_EXEC_INFO, domoticz.LOG_DEBUG or domoticz.LOG_ERROR
--marker: A string that is prefixed before each log message. That way you can easily create a filter in the Domoticz log to see just these messages.
logging =
level = LOGGING and domoticz.LOG_DEBUG or domoticz.LOG_ERROR,
--level = LOGGING and domoticz.LOG_ERROR,
marker = 'dzVents heating',
execute = function(dz)
-- collect all input data
local schuurtje_switch_state = dz.devices(SWITCH).state
local temp = dz.devices(TEMP_SENSOR).temperature
local bat = dz.devices(TEMP_SENSOR).batteryLevel
local setpointValue = TEMP_SETPOINT
local average_temp = 40 -- very high so the heating will not fire
-- info only on log level = LOG_DEBUG
dz.log('SWITCH : ' .. schuurtje_switch_state, dz.LOG_DEBUG)
dz.log('Temp : ' .. temp, dz.LOG_DEBUG)
dz.log('Bat : ' .. bat, dz.LOG_DEBUG)
dz.log('Setpoint_value : ' .. TEMP_SETPOINT, dz.LOG_DEBUG)
-- test if conditions are met and set acting values
if ((temp > 1.1)) then
dz.log('Temperature is more than 1.1 degrees : ' .. temp, dz.LOG_DEBUG)
-- dz.notify('Notifyer', 'Temperature is more than 1.1 degrees' .. temp , dz.PRIORITY_HIGH)
elseif (bat < BAT_THRESHOLD) then
dz.log('Battery level of temperature sensor TFA2 = ' .. bat, dz.LOG_DEBUG)
dz.notify('Notifyer', 'Temperature sensor TFA2 ' .. bat .. 'battery level low.',dz.PRIORITY_HIGH)
dz.log('Temperature sensors value is : ' .. temp, dz.LOG_DEBUG)
-- now determine what to do
if (temp >= setpointValue) then
dz.devices(SWITCH).switchOff()
dz.log('Target temperature reached, Switch schuurtje off')
elseif (average_temp <= (setpointValue -1)) then
dz.log('Average temperature more than 1 degree below setpointValue, switchOn during 9 minutes')
dz.devices(SWITCH).switchOn().forMin(9)
elseif ((temp > (setpointValue - 1)) and (temp < (setpointValue - 0.5))) then
dz.log('Temperature less than 1 degree below setpointValue, switchOn during 6 minutes')
dz.devices(SWITCH).switchOn().forMin(6)
elseif ((temp > (setpointValue -0.5)) and (temp < setpointValue)) then
dz.log('Temperature less than 0.5 degree below setpointValue, switchOn during 4 minutes')
dz.devices(SWITCH).switchOn().forMin(4)
else -- not predicted situation
-- The heater installed for frost prevention sets its temperature not at 0 but at 4.7 degrees
-- this is why this script has been written
-- so if things fail the heater can take back control
dz.log('Unpredicted situation, Swich on')
-- einde Schuurtje --
