I have one request: make more devices of Domoticz recognisable in HomeHabit.
For example, I have an Airconditiong unit. In Domoticz it has a setpoint, inside temperature, running mode, fan mode, etc devices. But when I create the Thermostat widget in Homehabit I can only bind the the Temperature and setpoint device. Not the running mode and fan mode. No items found by HomeHabit. I can find all the devices seperately but I would like to have them combined in the Thermostat widget of HomeHabit.
The thing is probably that the switches like 'running mode' and 'fan mode' in the API are defined as lights. So from a developer point of view not easy to understand that they can be used in a heating/cooling system... See also https://www.domoticz.com/wiki/Domoticz_ ... rtain_type.
