For some reason, I do not receive data anymore from my DHT22 sensor(s).
I have no idea what's wrong.
5 S_HUM true 1200 2021-02-01 16:26:34
6 S_TEMP true 1200 2021-02-01 16:26:35
255 S_ARDUINO_NODE 2.3.2 false 1200 2021-02-01 16:26:34
0 S_TEMP #1. V_TEMP (11) true 1200 2021-02-01 16:26:36
Showing 1 to 4 of 4 entries
So the S_TEMP is a DS12B sensor which works fine! I think the sensor (DHT) is not working because no data is being send. I have a other mysensor with a DHT22 and that is also not sending any data anymore. I have the newest MySensors...
Any thoughts?
Or should I move to a other solution?
No data from sensor
jadijkstra2000
iguaan
Re: No data from sensor
What's the delay between readings?
Try delay 5s, i know delay is bad but give it a try (not wait())
Had issues with it also and then changed sensor.
Sent from my MI 9 using Tapatalk
