Domoticz stopped and does not start anymore
Ptje
Post by Ptje »
My Domoticz installation has stopped and does not start anymore. I can't find what the problem is. I attached my Domoticz crashlog. Does someone can help my to see what the problem could by ? I hope I don't have to do a full new installation and configuration.......
Greetings,
Peter
domoticz_crash.log
(21.85 KiB) Downloaded 80 times
Ptje
Re: Domoticz stopped and does not start anymore
Post by Ptje »
When I start Domoticz I see the following,
2021-01-31 09:30:48.122  Status: Domoticz V2020.2 (build 12896) (c)2012-2021 GizMoCuz
2021-01-31 09:30:48.122  Status: Build Hash: d5c2e6a46-modified, Date: 2021-01-30 10:52:18
2021-01-31 09:30:48.122  Status: Startup Path: /home/pi/domoticz/
2021-01-31 09:30:48.169  Sunrise: 08:17:00 SunSet: 17:25:00
2021-01-31 09:30:48.169  Day length: 09:07:00 Sun at south: 12:51:00
2021-01-31 09:30:48.169  Civil twilight start: 07:41:00 Civil twilight end: 18:01:00
2021-01-31 09:30:48.169  Nautical twilight start: 07:01:00 Nautical twilight end: 18:41:00
2021-01-31 09:30:48.170  Astronomical twilight start: 06:21:00 Astronomical twilight end: 19:21:00
2021-01-31 09:30:48.242  Status: PluginSystem: Started, Python version '3.7.3'.
2021-01-31 09:30:48.247  Active notification Subsystems: email, fcm (2/13)
2021-01-31 09:30:48.251  Error: WebServer(HTTP) startup failed on address 0.0.0.0 with port: 8080: bind: Address already in use
2021-01-31 09:30:48.251  Error: WebServer(HTTP) check if no other application is using port: 8080
2021-01-31 09:30:48.263  Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied
2021-01-31 09:30:48.263  Error: WebServer(SSL) check privileges for opening ports below 1024
2021-01-31 09:30:48.264  Error: No servers are configured. Hence mydomoticz will not be started either (if configured)
terminate called without an active exception
2021-01-31 09:30:48.264  Error: Domoticz(pid:2461, tid:2461('domoticz')) received fatal signal 6 (Aborted)
2021-01-31 09:30:48.264  Error: siginfo address=0x99d, address=0xffffffff
2021-01-31 09:30:52.027  Error: Thread 1 (Thread 0x76018010 (LWP 2461)):
2021-01-31 09:30:52.027  Error: #0  __waitpid (options=0, stat_loc=0x7edef920, pid=2466) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2021-01-31 09:30:52.027  Error: #1  __waitpid (pid=2466, stat_loc=0x7edef920, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
2021-01-31 09:30:52.027  Error: #2  0x002cd4cc in dumpstack_gdb(bool) ()
2021-01-31 09:30:52.027  Error: #3  0x002cda98 in signal_handler(int, siginfo_t*, void*) ()
2021-01-31 09:30:52.027  Error: #4  <signal handler called>
2021-01-31 09:30:52.027  Error: #5  __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
2021-01-31 09:30:52.027  Error: #6  0x769b8230 in __GI_abort () at abort.c:79
2021-01-31 09:30:52.027  Error: #7  0x009cc084 in __gnu_cxx::__verbose_terminate_handler() ()
2021-01-31 09:30:52.028  Error: #8  0x0092f43c in __cxxabiv1::__terminate(void (*)()) ()
2021-01-31 09:30:52.028  Error: #9  0x0092f4b0 in std::terminate() ()
2021-01-31 09:30:52.028  Error: #10 0x001f17e4 in main ()
Aborted
But I don't see what is running on port 8080 or 443
Greetings,
Peter
Ptje wrote: Sunday 31 January 2021 9:33 ...but I don't see what is running on port 8080 or 443
sudo netstat -tulpn | grep '8080\|433'
Will show you what is on these ports.
Most of the time a
service domoticz stop
before a
service domoticz start
does work
erem
Domoticz version: 2021.1
Post by erem »
sometimes rasbian gets confused.
i believe a reboot of your pi will clear up the process that occupies port 8080
Regards,
Rob
Ptje
Post by Ptje »
waaren wrote: Sunday 31 January 2021 11:26
pi@raspberrypi:~ $ sudo netstat -tulpn | grep '8080\|433'
tcp6 0 0 :::8080 :::* LISTEN 551/domoticz
I see this at my fathers Domoticz.
tcp 0 0 127.0.0.1:8080 0.0.0.0:* LISTEN 430/motion
I see this at my Domoticz.
I don`t know of this is normal.
Greetings,
Peter
AllesVanZelf
Domoticz version: 12467
Post by AllesVanZelf »
Well, it looks like you have motion running on 8080.
Motion is surveillance software. Motion detection.
You could change the port Domoticz is using in /etc/init.d/domoticz.sh
fir example:
DAEMON_ARGS="$DAEMON_ARGS -www 8090"
Ptje
Post by Ptje »
Maybe I see ghosts, but I did watch yesterday a not official stream of Rico Verhoeven. During the match, I received a message from Monit, that Domoticz was stopped. It is not possible that something is installed with a script on my raspberry ?
I don't use motion software. And I did not change anything on my Raspberry myself..........
Greetings.
AllesVanZelf
In that case: check if motion is installed indead:
sudo apt list --installed |grep motion
Do you have a camera attached to your raspberry?
Ptje
Post by Ptje »
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
motion/stable,now 4.1.1-1.1+b2 armhf [installed]
So it is installed. I have no camera attached to the raspberry Pi
Greetings,
Peter
AllesVanZelf
Then I would have removed motion. But have a close look on dependencies before saying yes to removal.
 sudo apt remove motion
If you can remove motion without dependency problems, you should find out why motion is installed in the first place.
But without motion, Domoticz should be able to start.
sudo systemctl start domoticz
Ptje
Post by Ptje »
After the removal from "Motion" The port 8080 error was gone. I even had to place a old database back to get it running. I think that I killed soms stuff while trying to make Domoticz work. Thanks for the help !!
Greetings,
Peter
monette999
Post by monette999 »
Hi I have a similar issue.see attachment.
Are you still online and can help?Image
Gesendet von meinem CPH2343 mit Tapatalk
