How to set timer to last day of the month
Kranendijk
Domoticz version: 4.10717
Post by Kranendijk »
Thanks to the great help of this forum Inwas able to use dzvents for my energy meter. I have a script to copy the current week total to another device to store it as last week. A timer running each saturday at 23:55 does that job.
Now I want something similar for the month values. Like “rune every last day of the month at 23:55”. Should be possible but I am not able to figure that out.
Can’t be difficult, but I don’t see it...
Help appeciated. As always :D
HvdW
Domoticz version: 2023.2
Re: How to set timer to last day of the month
Post by HvdW »
Cron does the job.
Take a look over here.
I'm testing this one:
If you're lucky to be using one of those implementations, it's as simple as:
55 23 L * * ?
Bugs bug me.
Kranendijk wrote: Thursday 28 January 2021 18:53 Now I want something similar for the month values. Like “rune every last day of the month at 23:55”. Should be possible but I am not able to figure that out.
This could do it
return
    on =
        timer =
            'at 23:55 on 28/2,29/2,30/*,31/*',
    execute = function(dz, item)
        if os.date("%d", os.time() + 24 * 3600 )  ~= '01' then
            dz.log(item.trigger .. " ==>> today is not the last day of the month" , dz.LOG_FORCE)
            return
            dz.log(item.trigger .. " ==>> today is the last day of the month" , dz.LOG_FORCE)
        dz.log('rest of the script below this line', dz.LOG_FORCE )
Kranendijk
Really. That simple??
I’ll give it a shot, big thanks!
HvdW
Post by HvdW »
That's 7 times twice on 30th and 31th
Bugs bug me.
HvdW wrote: Thursday 28 January 2021 21:21 That's 7 times twice on 30th and 31th
True but in the execute part of the script there is an extra check that will stop the execution of the script if it is not the last day of the month, before the scripts real work starts.
Do you know a better way in pure dzVents ?
HvdW
Post by HvdW »
Correct @waaren
For simplicity you could trigger it every day as well, like:
return
    on =
        timer =
            'at 23:55',
            return
Bugs bug me.
HvdW wrote: Thursday 28 January 2021 22:12 For simplicity you could trigger it every day as well, like:
The time rule looks indeed a bit intricate at first but that is only once and you save 365 - 19 = 346 unnecessary script triggers yearly by using it.
I can live with both approaches :D
HvdW
Post by HvdW »
Correct again @Waaren
I like script simplicity and computers don't care about repetition.
How many times a day is this script being run to check if it's 23:55?
Bugs bug me.
