sensor the strength of light outside - zwave
ropske
Domoticz version: V3_8394
Post by ropske »
is there a sensor available that works on Zwave that can measure the strength of the ligth outside?
I want to use this to lower our rollers in the house.
When i use the sunset, this is to early for us, as it is still clear outside.
Or is there another solution for my 'problem'.
Thank you in advance.
jake
Re: sensor the strength of light outside - zwave
Post by jake »
Wel, the motion sensor from Fibaro has an illumination sensor.
Use a calculated outside lux sensor. Script is available here on the forum.
Combine previous sensor with a 2nd script that gives you azimuth angle of the sun. That way you know from which angle on the sun is able to reach the room in the first place.
