getting a nil error. probably a simple fix  [Solved]
Gravityz
Domoticz version: 2025.1
Post by Gravityz »
well, i am getting rusty with dzvents
i am trying to time the time between a device gets updated but i am getting a nil error
i declared a global variable but somehow something is still wrong
also tried WatermeterDeltaTime = domoticz.time.compare('Watermeter').lastUpdate.ms but that did not help either
in the global_data is this
WatermeterDeltaTime = { initial = 9999 },
    active = true,
        devices = {
            'Watermeter'
    execute = function(domoticz, Watermeter)
        WatermeterDeltaTime = domoticz.time.compare(Watermeter.lastUpdate.ms)
        if WatermeterDeltaTime <= 9000 then
         domoticz.devices('fastpulse').updateWaterflow(WatermeterDeltaTime)
       --domoticz.devices('fastpulse').updateWaterflow(1)
Re: getting a nil error. probably a simple fix
Gravityz wrote: Friday 22 January 2021 9:27 well, i am getting rusty with dzvents
You compare a time object (domoticz.time) with a number(Watermeter.lastUpdate.ms)
can you try again after changing
to
WatermeterDeltaTime = domoticz.time.compare(Watermeter.lastUpdate).ms
That will compare two time objects and returns the ms attribute
Gravityz
Re: getting a nil error. probably a simple fix  [Solved]
Post by Gravityz »
thanks,
working now.
