[SOLVED] Time trigger fires outside of defined date range
zavjah
Post by zavjah »
I have encountered a strange behavior with this time trigger recently:
	on = {timer =
	        {'20 minutes after sunrise on mon,tue,wed,thu,fri on 2/3-30/09',    	-- Summer time during the week
	         'at 08:00 on sat,sun on 2/3-30/09',                                			-- Summer time, weekend
	         'at 09:00 on 1/10-31/12,1/1-01/03'                                			-- Winter time
Although it should not (it is before 2/3) the first line is triggering the rest of the script, which ios shown in the log, too:
2021-01-21 08:26:00.483  Status: dzVents: Info: ------ Start internal script: Rollladen_AufMorgens:, trigger: "20 minutes after sunrise on mon,tue,wed,thu,fri on 2/3-30/09"
2021-01-21 08:26:00.498  Status: dzVents: Info: ===>>> Normale Sommerzeit, werktags: öffne Rollladen 20 Min. nach Sonnernaufgang <<<===
2021-01-21 08:26:00.598  Status: dzVents: Info: ------ Finished Rollladen_AufMorgens
Interesting enough, the last line, the only one that is supposed to trigger the script, is also triggered:
2021-01-21 09:00:00.390  Status: dzVents: Info: ===>>> Winterzeit: öffne Rollladen erst um 09:00 <<<===
2021-01-21 09:00:00.493  Status: dzVents: Info: ------ Finished Rollladen_AufMorgens
I've checked everything but I cannot figure out, why this started to happen. I am not sure, when did it start, but i am pretty sure that it worked for a while correctly.
Can anyone tell me what is wrong?
thx,
Zavjah
Re: Time trigger fires outside of defined date range
zavjah wrote: Thursday 21 January 2021 18:22 Although it should not (it is before 2/3) the first line is triggering the rest of the script, which ios shown in the log, too:
I cannot replicate this on my installation (dzVents 3.1.1 (Build 12865 )
zavjah
Post by zavjah »
I am using dzvents 3.0.2, I assume that is the version of the stable codlre (see attachment.
Might this be the problem?
I upgraded sometime last summer and it might be that I didn't noticed the change because the trigger fitted the time.
Is this possible?
zavjah wrote: Friday 22 January 2021 8:37 I am using dzvents 3.0.2, I assume that is the version of the stable code
I just checked against the latest stable and could replicate your issue.
That leaves you with some choices:
1. Change your script into something like
return
    on =
        timer =
	         '20 minutes after sunrise on mon,tue,wed,thu,fri on 2/3-30/09',    	--during the week
	         'at 09:00 on 1/10-31/12,1/1-01/03',                   			-- Winter time
	logging =
	    level = domoticz.LOG_DEBUG,
	    marker = 'timeChecker',
	execute = function(dz, item)
       local timeruleSummer = ( item.trigger == '20 minutes after sunrise on mon,tue,wed,thu,fri on 2/3-30/09' or item.trigger ==  'at 08:00 on sat,sun on 2/3-30/09')
       if timeruleSummer and dz.time.matchesRule('on 2/3-30/9') then
            dz.log('It is summertime. I will continue (' .. item.trigger .. ').' ,dz.LOG_DEBUG)
        elseif timeruleSummer then
            dz.log('It is outside summertime (' .. item.trigger..') I will stop.' ,dz.LOG_DEBUG)
            return
        dz.log('Minutes sunrise ' .. dz.time.sunriseInMinutes ,dz.LOG_DEBUG)
        dz.log('Minutes now ' .. (dz.time.hour * 60 + dz.time.minutes)  ,dz.LOG_DEBUG)
        dz.log('Minutes delta ' .. (dz.time.hour * 60 + dz.time.minutes) - dz.time.sunriseInMinutes ,dz.LOG_DEBUG)
2. update to beta
zavjah
[SOLVED] Re: Time trigger fires outside of defined date range
Post by zavjah »
HI waaren,
thanks for testing on the latest stable. I'm glad, that now I know that the script is fine but dzvents wrong.
I'll consider upgrading to beta.
thx
Zavjah
zavjah
Post by zavjah »
waaren wrote: Friday 22 January 2021 10:24
return
    on =
        timer =
	logging =
            return
2. update to beta
Hi waaren,
just out of curiosity: which part of the trigger is misinterpreted by dzvents, "20 minutes after sunset"?
Cheers,
zavjah
zavjah wrote: Friday 22 January 2021 12:57 just out of curiosity: which part of the trigger is misinterpreted by dzvents ?
It is the combination of rules. That part is reworked in recent builds
