Yeelights Scene Selector (RGBW)
DewGew
Domoticz version: V4.10618
Post by DewGew »
I made a script to select a custom scene for my Yeelight Color bulbs. Works with multiple bulbs.
Premade scenes in the script is: Sunrise, Sunset, Calm, Alarm, Notify, Police 1, Police 2, Candle Flicker, Birthday Party.
Creata a dummy selector switch.
Copy script below to Eventseditor.
Change settings part to suit your needs.
Add level names to selector switch.
    Yeelight Scene Selector
    Project: Domoticz
    Interpreter: dzVents, Device
    Author: DewGew
    Version: 20190308
-- Settings
local selector= 123 --Selector Switch IDX
local yeelights = {'192.168.xxx.xxx', '192.168.xxx.xx'} -- yeelights ipnumbers
local port = '55443'
-- Put the level names here:
local level10 = 'Sunrise'
local level20 = 'Sunset'
local level30 = 'Calm'
local level40 = 'Alarm'
local level50 = 'Notify'
local level60 = 'Police 1'
local level70 = 'Police 2'
local level80 = 'Candle'
local level90 = 'Birthday Party'
-- End Settings
local sunrise = '[\"cf\",2,1,\"50,2,4000,1,900000,2,4000,100\"]'
local sunset = '[\"cf\",2,2,\"50,2,4000,75,900000,2,4000,1\"]'
local alarm = '[\"cf\",0,0,\"500,1,16711696,100,500,1,16711696,10\"]'
local calm = '[\"cf",0,0,\"2000,1,255,70,2000,1,255,100,5000,1,255,70,3000,1,13369548,100,3000,1,13369548,10\"]'
local notify = '[\"cf",0,0,\"1000,2,2700,100,1000,7,0,0,1000,2,2700,10,1000,7,0,0\"]'
local police_1 = '[\"cf",0,0,\"1000,1,1002236,100,1000,7,0,0,1000,1,16711696,10,1000,7,0,0\"]'
local police_2 = '[\"cf",0, 0,\"1000,1,1002236,100,1000,1,1002236,10,1000,1,16711696,50,1000,1,1002236,30,1000,7,0,0,1000,1,16711696,10,1000,7,0,0\"]'
local candle_flicker = '[\"cf",0,0,\"800,2,2700,50,800,2,2700,30,1200,2,2700,80,800,2,2700,60,1200,2,2700,90,2400,2,2700,50,1200,2,2700,80,800,2,2700,60,400,2,2700,70\"]'
local birthday_party = '[\"cf",0,0,\"1996,1,14438425,80,1996,1,14448670,80,1996,1,11153940,80\"]'
        devices = {selector}
        for ix, ipadress in ipairs(yeelights) do
            if (device.state == 'Off') then
                runcommandoff = "sudo echo -ne '{\"id\":1,\"method\":\"set_power\", \"params\":[\"off\", \"smooth\", 500]}\\r\\n' | nc -w1 " ..ipadress.." " ..port..""
                os.execute(runcommandoff)
            elseif (device.state == level10) then
                runcommand = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":" ..sunrise.. "}\\r\\n' | nc -w1 " ..ipadress.." " ..port..""
                os.execute(runcommand)
            elseif (device.state == level20) then
                runcommand = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":" ..sunset.. "}\\r\\n' | nc -w1 " ..ipadress.." " ..port..""
            elseif (device.state == level30) then
                runcommand = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":" ..calm.. "}\\r\\n' | nc -w1 " ..ipadress.." " ..port..""
            elseif (device.state == level40) then
                runcommand = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":" ..alarm.. "}\\r\\n' | nc -w1 " ..ipadress.." " ..port..""
            elseif (device.state == level50) then
                runcommand = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":" ..notify.. "}\\r\\n' | nc -w1 " ..ipadress.." " ..port..""
            elseif (device.state == level60) then
                runcommand = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":" ..police_1.. "}\\r\\n' | nc -w1 " ..ipadress.." " ..port..""
            elseif (device.state == level70) then
                runcommand = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":" ..police_2.. "}\\r\\n' | nc -w1 " ..ipadress.." " ..port..""
            elseif (device.state == level80) then
                runcommand = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":" ..candle_flicker.. "}\\r\\n' | nc -w1 " ..ipadress.." " ..port..""
            elseif (device.state == level90) then
                runcommand = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":" ..birthday_party.. "}\\r\\n' | nc -w1 " ..ipadress.." " ..port..""
            domoticz.log('Set light to ' ..device.state..' mode',domoticz.LOG_FORCE)
schumi2004
Domoticz version: 4.10603
Re: Yeelights Scene Selector (RGBW)
Post by schumi2004 »
Nice script but i'm having a issue that the lights won't react on the Dummy switch selector.
Changed the settings to my needs, changed IP';s and Idx.
When selected and changing scene i see it in log but the lights itself don;t respond.
Any ideas, did i missed a step?
schumi2004
Any help, suggestions?
schumi2004 wrote:Any help, suggestions?
What happens if you enter the nc command on the CLI as the domoticz user?
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
schumi2004
waaren wrote: Thursday 20 June 2019 14:39
I think i understand where you're heading at.
NC is not available on my Synology (a find did not gave any results) or it should be an abbreviation for something else.
NC stands for ?
schumi2004 wrote: Thursday 20 June 2019 16:03
NC stands for ?
if you don't have the nc program on your system this script will not work.
nc is short for netcat. I have it on my Synology now but I had to install it separately with
sudo /opt/bin/ipkg install netcat
first.
schumi2004
Mmmm that explains although i expected some errors.
I'll need to do some reading on how to bootstrap my DS715 first to get ipkg and continue.
Thanks for your help ;)
Thuis
Post by Thuis »
DewGew wrote: Friday 08 March 2019 11:47 I made a script to select a custom scene for my Yeelight Color bulbs. Works with multiple bulbs.
Thank you so much for sharing this :-D
I Love Domoticz ! And the community around it :-)
snuiter
Post by snuiter »
Great script is it possible to do this also with the dzvents command like
setColor(r, g, b, br, cw, ww, m, t),
so I can easily integrate an action like the notify
snuiter wrote: Friday 15 January 2021 22:21 Great script is it possible to do this also with the dzvents command like
No this it too specific for yeelights.
