Retrieve Domoticz time in API/JSON call  [Solved]
peterbos
Post by peterbos »
I want to synchronize the time on a NodeMCU8266 (*) with the time Domoticz shows in the upper left corner of the dashboard page. This way I can avoid issues with summer and winter time, which are quite difficult to manage when using an NTP-server as source.
Of course I can synchronize with a CustomEvent every X hours, but then I have to maintain code on both the NodeMCU and in Domoticz. Is a JSON call available that I can use to get the time? I looked for it in the API/JSON guide but didn't find it. With a JSON call I only have to maintain the NodeMCU side since the Domoticz side is taken care of by Domoticz itself.
Thanks,
Peter
(*) Great stuff to combine with Domoticz by the way!
Number8
Domoticz version: 2022.1
Re: Retrieve Domoticz time in API/JSON call
Post by Number8 »
This should do it:
/json.htm?type=command&param=getSunRiseSet
Debian buster on NUC and three RPi with buster.
gerardvs
Domoticz version: latest-1
Post by gerardvs »
Not sure why you post this in dzVents if you want to call the API but you could use
Although you are not interested in sunrise or sunset there is also a 'ServerTime' attribute with the current time.
--Gerard
peterbos
Re: Retrieve Domoticz time in API/JSON call [SOLVED]
Post by peterbos »
I found it. In the JSON/API guide there's a JSON commandstring /json.htm?type=command&param=getSunRiseSet. In addition to the sunrise and sunset times it also gives the ServerTime, which is what I was looking for. I then tried the commandstring /json.htm?type=command&param=getServerTime and that worked to. The response from Domoticz was:
"ServerTime" : "2021-01-13 22:00:37",
"status" : "OK",
"title" : "getServerTime"
I hope this undocumented feature may exist until forever :D
Peter
peterbos
Re: Retrieve Domoticz time in API/JSON call  [Solved]
Post by peterbos »
Hi Gerard and Number 8,
Our posts crossed each other.
Peter
