switch error  [Solved]
kroonp
switch error
Post by kroonp »
Hello all,
Can anyone see what I am doing wrong in the script?
The intention is that if I turn on one switch, the other 2 will turn off.
However, this does not happen.
As soon as I press a switch, it lights up briefly and goes out again. The others don't respond.
Thank you for thinking along.
Peter
            devices = {
                'Thuis',
                'Afwezig',
                'Vakantie'
    logging =
        level = domoticz.LOG_ERROR, -- change to dz.LOG_ERROR when script is OK
        marker = 'test Statuscontrole',
    execute = function(dz)
        local Thuis = dz.devices('Thuis')
        local Vakantie=dz.devices('Vakantie')
	local Afwezig=dz.devices('Afwezig') -- idx 395
            if(Thuis.state=='On') then
                Afwezig.switchOff()
                Vakantie.switchOff()
           elseif(Afwezig.state=='On') then
                Thuis.switchOff()
            elseif(Vakantie.state=='On') then
                Thuis.switchOff()
                Afwezig.switchOff()
Re: switch error
kroonp wrote: Wednesday 13 January 2021 15:37 As soon as I press a switch, it lights up briefly and goes out again. The others don't respond.
Below modified script turns on more logging, shows which device caused the execution of the script and switches the devices silent() so the will not cause a subsequent execution of the script.
return
    on =
        devices =
            'Thuis',
            'Afwezig',
            'Vakantie',
    logging =
        level = domoticz.LOG_DEBUG, -- change to dz.LOG_ERROR when script is OK
    execute = function(dz, item)
        dz.log(item.name .. ', State: ' .. item.state .. ', Type: ' .. item.deviceType, dz.LOG_DEBUG )
        local Vakantie = dz.devices('Vakantie')
        local Afwezig = dz.devices('Afwezig') -- idx 395
        if (Thuis.state == 'On') then
            Afwezig.switchOff().silent()
            Vakantie.switchOff().silent()
        elseif (Afwezig.state == 'On') then
            Thuis.switchOff().silent()
        elseif (Vakantie.state == 'On') then
kroonp
Re: switch error
Post by kroonp »
Hallo waaren,
Unfortunately, it doesn't work as expected. Apparently there is still an error in the script.
The intention is that if I turn on one of the switches the other 2 will go out. I don't get it working either with if or elseif.
Is there any other way to get this working.
Peter
Re: switch error
kroonp wrote: Wednesday 13 January 2021 22:23 The intention is that if I turn on one of the switches the other 2 will go out. I don't get it working either with if or elseif.
The script logic is OK.
What do you see in the log?
kroonp
Re: switch error
Post by kroonp »
The log when i push the 3 switches
2021-01-14 09:59:15.614 Status: dzVents: Debug: test Statuscontrole: Afwezig, State: Off, Type: Light/Switch
2021-01-14 09:59:15.615 Status: dzVents: Debug: test Statuscontrole: Processing device-adapter for Thuis: Switch device adapter
2021-01-14 09:59:15.615 Status: dzVents: Debug: test Statuscontrole: Processing device-adapter for Vakantie: Switch device adapter
2021-01-14 09:59:15.615 Status: dzVents: Info: test Statuscontrole: ------ Finished 00 AB test
2021-01-14 09:59:17.880 Status: dzVents: Info: test Statuscontrole: ------ Start internal script: 00 AB test: Device: "Afwezig (Virtual switch)", Index: 225
2021-01-14 09:59:17.880 Status: dzVents: Debug: test Statuscontrole: Afwezig, State: On, Type: Light/Switch
2021-01-14 09:59:17.881 Status: dzVents: Debug: test Statuscontrole: Processing device-adapter for Thuis: Switch device adapter
2021-01-14 09:59:17.898 Status: dzVents: Debug: test Statuscontrole: Processing device-adapter for Vakantie: Switch device adapter
2021-01-14 09:59:17.898 Status: dzVents: Debug: test Statuscontrole: Constructed timed-command: Off
2021-01-14 09:59:17.898 Status: dzVents: Debug: test Statuscontrole: Constructed timed-command: Off NOTRIGGER
2021-01-14 09:59:17.898 Status: dzVents: Info: test Statuscontrole: ------ Finished 00 AB test
2021-01-14 09:59:51.846 Status: dzVents: Info: test Statuscontrole: ------ Start internal script: 00 AB test: Device: "Vakantie (Dummy)", Index: 246
2021-01-14 09:59:51.846 Status: dzVents: Debug: test Statuscontrole: Vakantie, State: On, Type: Light/Switch
2021-01-14 09:59:51.848 Status: dzVents: Debug: test Statuscontrole: Processing device-adapter for Thuis: Switch device adapter
2021-01-14 09:59:51.848 Status: dzVents: Debug: test Statuscontrole: Processing device-adapter for Afwezig: Switch device adapter
2021-01-14 09:59:51.848 Status: dzVents: Debug: test Statuscontrole: Constructed timed-command: Off
2021-01-14 09:59:51.848 Status: dzVents: Debug: test Statuscontrole: Constructed timed-command: Off NOTRIGGER
2021-01-14 09:59:51.849 Status: dzVents: Debug: test Statuscontrole: Constructed timed-command: Off NOTRIGGER
2021-01-14 09:59:51.849 Status: dzVents: Info: test Statuscontrole: ------ Finished 00 AB test
kroonp
Re: switch error
Post by kroonp »
I also tried this script.
Does not work either.
Peter
return
    on =
        devices =
            'Thuis',
            'Afwezig',
            'Vakantie',
    logging =
        marker = 'Testing Statuscontrole',
        local Vakantie = dz.devices('Afwezig')
        local Afwezig = dz.devices('Vakantie') -- idx 395
        if(item.name=='Thuis') then
                if Afwezig.state=='On' then
                    Afwezig.switchOff()
                if Vakantie.state=='On' then
                    Afwezig.switchOff()
     if(item.name=='Afwezig') then
            if Thuis.state=='On' then
                Thuis.switchOff()
      if(item.name=='Vakantie') then
                Thuis.switchOff()
                Afwezig.switchOff()
Index: 395
2021-01-14 10:51:17.198 Status: dzVents: Debug: Testing Statuscontrole: Thuis, State: On, Type: Light/Switch
2021-01-14 10:51:17.199 Status: dzVents: Debug: Testing Statuscontrole: Processing device-adapter for Afwezig: Switch device adapter
2021-01-14 10:51:17.199 Status: dzVents: Debug: Testing Statuscontrole: Processing device-adapter for Vakantie: Switch device adapter
2021-01-14 10:51:17.199 Status: dzVents: Info: Testing Statuscontrole: ------ Finished 00 AB test
Re: switch error
kroonp wrote: Thursday 14 January 2021 10:02 The log when i push the 3 switches
This log shows that the script works as expected and the right commands are send. What happens if you switch the devices in the Gui from the switch tab ?
Re: switch error
kroonp wrote: Thursday 14 January 2021 10:56 I also tried this script.
You don't have to modify the script. It works as expected. If the switches do not react there is another issue on the system.
kroonp
Re: switch error
Post by kroonp »
Thuis Afwezig Vakantie
Start postion Off Off Off
switch Thuis On On Off Off
switich Afwezig On On blink-Off Off
switchVakantie On On Off blink-Off
switich Afwezig On Off On Off
switchVakantie On Off On blink-Off
switich Vakantie On Off Off ON
switch Afwezig On Off On Off
kroonp
Re: switch error
Post by kroonp »
The third version ( from vakantie-afwezig to thuis) works Oke!
Re: switch error
kroonp wrote: Thursday 14 January 2021 12:44 The third version ( from vakantie-afwezig to thuis) works Oke!
Can you please double check that no other scripts are active- or On-Off actions / On-Off delays are defined for these switches?
kroonp
Re: switch error
Post by kroonp »
I closed all other scripts.
I restart system
Does not work
I created three new dummy's: een-twee-drie
I have adapted your script with the three new dummy switches. Get the same result as the third postions as above.
return
    on =
        devices =
            'een',
            'twee',
            'drie'
    logging =
        local Thuis = dz.devices('een')  -- 1847
        local Vakantie = dz.devices('twee') -- 1848
        local Afwezig = dz.devices('drie') -- 1849
Re: switch error
kroonp wrote: Thursday 14 January 2021 15:48 I have adapted your script with the three new dummy switches. Get the same result as the third postions as above.
Found something. Because the script did not look at the item that triggered the script it always evaluates the first if.
I tested below version and that one does the job in all cases.
return
    on =
        devices =
            'Een',
            'Twee',
            'Drie'
    logging =
        level = domoticz.LOG_ERROR, -- change to dz.LOG_DEBUG when developing / debugging
        local Thuis = dz.devices('Een')  -- 1847
        local Vakantie = dz.devices('Twee') -- 1848
        local Afwezig = dz.devices('Drie') -- 1849
        if item.active then
            if item ~= Thuis then Thuis.switchOff().silent() end
            if item ~= Vakantie then Vakantie.switchOff().silent() end
            if item ~= Afwezig then Afwezig.switchOff().silent() end
kroonp
Re: switch error  [Solved]
Post by kroonp »
Great that you found that. Now it works for me too. It took me and you a lot of effort but I am very happy that it is now working, I will be even more careful and check next time. Thanks again and have a nice day.
Peter
