On statement and global_data.lua [SOLVED]
Antori91
Domoticz version: 4.10717
Post by Antori91 »
Is there any way to use an entity declared in global_data.lua within the on statement of a dzVents script?
I mean:
This works -->
           timer   = {'every 1 minutes'},
           devices = {'Horaires/Start Chauffage','Horaires/Stop Chauffage', 17, 16}
But, this doesn't work (Off course, IDX_HEATINGSELECTOR and IDX_THERMOSTAT_SETPOINT are defined in my global_data.lua file)
Runtime Error in the log: 2021-01-13 13:01:33.368 Status: dzVents: Error (2.4.19): /home/pi/domoticz/scripts/dzVents/scripts/Heating.lua:9: attempt to index global 'helpers' (a nil value)
           devices = {'Horaires/Start Chauffage','Horaires/Stop Chauffage', domoticz.helpers.IDX_HEATINGSELECTOR, domoticz.helpers.IDX_THERMOSTAT_SETPOINT}
OR
           devices = {'Horaires/Start Chauffage','Horaires/Stop Chauffage', helpers.IDX_HEATINGSELECTOR, helpers.IDX_THERMOSTAT_SETPOINT}
Last edited by Antori91 on Wednesday 13 January 2021 14:55, edited 2 times in total.
Domoticz High Availability Cluster: Synology Dz V4.10693 (Main) - Raspberry Dz V4.10717 (Backup) - Scripts Node.js
Alarm server: Raspberry - motionEye - iot_ALARM-SVR Node.js
Sensors/Actuators: ESP8266-Arduino
https://github.com/Antori91/Home_Automation
Re: On statement and global_data.lua
Antori91 wrote: Wednesday 13 January 2021 12:51 Is there any way to use an entity declared in global_data.lua within the on statement of a dzVents script?
Yes; using Lua's require
local dz = require ("global_data")
return
    on =
        devices =
            dz.helpers.IDX_HEATINGSELECTOR,
            dz.helpers.IDX_THERMOSTAT_SETPOINT,
    logging =
        level = domoticz.LOG_INFO,
        marker = 'globalData definitions',
    execute = function(dz, item)
        dz.log('Triggered by ' ..item.name, dz.LOG_FORCE)
Antori91
Post by Antori91 »
waaren wrote: Wednesday 13 January 2021 13:59
Thanks Waaren.
