Refresh Tradfri status in Domoticz
JanvdW
Post by JanvdW »
The Tradfri lamps in my Domoticz setup (2020.2 (build 12705)) are working fine, as long as I switch them on and off via Domoticz. But when the bulb is switched on/off manually (so by a physical power on/off), the Domoticz status is not updated. How can I check the Tradfri status regularly and update the Domoticz status with the current status?
pipiche
Re: Refresh Tradfri status in Domoticz
Post by pipiche »
I suggest that you mention what Zigbee key you are using, or if this is based on the IKEA TRadfri gateway
Wiki is available here.
Zigbee for Domoticz FAQ
JanvdW
Post by JanvdW »
I use a CC2531 USB sniffer and used this installation instruction.
JanvdW
Post by JanvdW »
I found similar problems for Domoticz/ Zigate and Philips Hue (and this post too), but I didn't succeed to find a solution fo my Domoticz. I made a script to loop through my Tradfri lamps and I can change the the bulb status on and off rather easily. The problem is that I can't detect which bulbs are unreachable (because they are not powered, because manually switched off). How can I check that?
pipiche
Post by pipiche »
JanvdW wrote: Monday 11 January 2021 18:52 I found similar problems for Domoticz/ Zigate and Philips Hue (and this post too), but I didn't succeed to find a solution fo my Domoticz. I made a script to loop through my Tradfri lamps and I can change the the bulb status on and off rather easily. The problem is that I can't detect which bulbs are unreachable (because they are not powered, because manually switched off). How can I check that?
On Domoticz beta, we have added an option, which then will Switch Off a Switch/Dim device if that one is not reachable on the network.
You have to got to Settings - Advanced and enable : deviceOffWhenTimeOut
JanvdW
Post by JanvdW »
I have updated to the newest version (Version: 2020.2 (build 12838)), but can't find this option. I have looked in the menu 'Setup' 'Settings' in the web interface. I suppose that I should look somewhere else?
pipiche
Post by pipiche »
I’m talking about the Web Admin page of Zigate plugin
JanvdW
Post by JanvdW »
Ah, right. Unfortunately I do not use Zigate, but the CC2531 Zigbee Adapter, so his doesn't solve my problem. Does anyone have other ideas how to solve this?
