Well, I use SVT to decide when the heater must go on. Then I manipulate the setpoint of the wall thermostat to go 1 degree above setpoint temperature of SVT. This turns on the heater right away. When the SVT heater turns off, I reduce the setpoint of the wall thermostat to 1 degree below the SVT setpoint. This turns the heater off.piotrux wrote:Thank you explanation. My stove is old there is no on and off switch. I have custom thermostat build on "let's control it". In that case how can i adjust to make it work? I want a constant temperature in the room thanks to netatmoand SVT.
So once again, SVT is in control and does an awesome job to keep the room temperature stable within +-0.1 degree. Since I have seen opentherm system, the manipulate wall thermostat does the actual switching.
I even made the script smarter, so that when I adjust the wall thermostat manually, the SVT setpoint is updated as well.
