Hello all,
Not sure when it happened, but since a week or so, the current temperature and setpoint disappeared from from the widget. Also the actual temperature and setpoint are no longer available in the graph.
Think it it I is related to an update on the pi I did at that moment in time (apt-get upgrade).
Any ideas what I broke? Thanks a million, Jeroen
EvoHome temperature and setpoint disappeared from widget
JeroenL
- Domoticz version: 2023.2
- A4E0614C-3C12-46CA-9B9D-3D516E32C3DC.jpeg (115.3 KiB) Viewed 6832 times
JeroenL
Re: EvoHome temperature and setpoint disappeared from widget
Update (on what does not work...)
Did a reset to Factory Settings of the EvoHome controller, reonnected / reconfigured my EvoHome (Wifi).
I also have an HGI80, where it looks like other zones do get passed through correctly. Looks like it is only the EvoHome not cooperating. Access via the Honeywell app works as before.
Hope someone has a clue what else to try...
Update @2021-02-01
Still not working. However, I noticed that when I refresh the browser page showingthe thermostat, for a second or so values are shown on the screen, but the get "overwritten" with something (blank text, a non-showing image?)
Also, I did install the Evohome Wifi hardware version in parallel, that one does work.
Update @2021-02-01
JeroenL
Finally, not so complex, just removed the devices in the settings/devices menu. Ensure "Allow new hardware is on" et voila.... a while later it was back. Re-added the device to my dashboard.
