Speak does not work in Fully Kiosk or WallPanel
hsvt
Post by hsvt »
I have tried to use the speakOn function in combination with block.
It works in Google Chrome on the laptop and tablet.
But when I start Dashticz with Fuly Kiosk or WallPanel it doesn't works.
PlaysoundOn works well.
I want to have Dashticz full screen on a tablet, with the speakOn.
How can I get it Works??
Or is it possible to starts Dashticz full screen in Chrome.
Lokonli
Re: Speak does not work in Fully Kiosk or WallPanel
Post by Lokonli »
Did you already set text-to-speak engine in your panel Android settings to google tts? You might have to download google tts as well.
hsvt
Post by hsvt »
Yes.
In Chrome on the same tablet it works fine.
Lokonli
Post by Lokonli »
hsvt wrote: Saturday 09 January 2021 13:48 Yes.
I forgot: For me speakOn on tablet with Fully Kiosk didn't work neither.
I have a little scripts that that calls the Fully Kiosk web interface:
#!/bin/bash
cmd="$*"
cmd=${cmd// /%20}
curl "http://tablet.lokonli.home:2323/?cmd=textToSpeech&text=($cmd)&password=password&type=json"
hsvt
Post by hsvt »
Lokonli wrote: Saturday 09 January 2021 14:36 I have a little scripts that that calls the Fully Kiosk web interface:
#!/bin/bash
cmd="$*"
cmd=${cmd// /%20}
I don't know where I have to put this.
Lokonli
Post by Lokonli »
First activate the internal webserver in Fully Kiosk. Somewhere in the Fully Kiosk settings. You have to set a password as well.
Probably only works on the paid version.
Find the IP address of your tablet.
Then first test the Fully Kiosk server, by browsing from another laptop/PC:
http://fullykioskip:2323
There you should be able to login. Look for a command or menu entry 'Speak Text'.
The text you enter there will be spoken by Fully on your tablet. First check this.
If this is working, then copy the small script below to for instance /home/pi/scripts/fullyspeak.sh. Change the IP address (tablet.lokonly.com) and the password, (password=Secret)
Script:
#!/bin/bash
cmd="$*"
cmd=${cmd// /%20}
curl "http://tablet.lokonli.home:2323/?cmd=textToSpeech&text=($cmd)&password=Secret&type=json"
give execution rights:
chmod a+x /home/pi/scripts/fullyspeak.sh
Test the script:
/home/pi/scripts/fullyspeak.sh the script works
Then in Domoticz you can use the script in for instance the On-command of a switch:
script:///home/pi/scripts/fullyspeak.sh this switch is on
madpatrick
Domoticz version: 2025.2
Post by madpatrick »
Lokonli wrote: Sunday 10 January 2021 8:56 Then in Domoticz you can use the script in for instance the On-command of a switch:
Hi Lokonli,
Great feature. Pitty this doesn't work out of the box with Fully.
Everything works excepts the last step.
The script doesn't run when I switch on or off
Lokonli
Post by Lokonli »
I've to use three slashes for the actions in Domoticz:
(The third slash to have an absolute path)
script:///home/lokonli/scripts/fullyspeak.sh switch is on
madpatrick
Thanks Lokonli. It is working now.
