Dashboard not shown on different computer Topic is solved
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
Been using Domoticz for about 7 years now and was allready long time impressed by Dashticz.
Had no time to implement it but since the beginning of this year I have a lot of time.
So I implemented it on my pi4 and started to learn the basics.
All is working well on my laptop in Chrome browser.
But when I want to show the dashboard on my home computer the start screen ends up with "error for more help ..."
I tried chrome browser, firefox and edge all with the same result.
I reduced my config to:
var config = {}
config['domoticz_ip'] = 'http://***.***.*.**:8080';
config['app_title'] = Dashticz';
config['language'] = 'nl-NL'
config['login_timeout'] = '60';
config['domoticz_timeout'] = '2000';
config['room_plan'] = 0;
on my laptop all devices appear on my home computer still error.
What could be wrong?
Jan
Lokonli
Re: Dashboard not shown on different computer
Post by Lokonli »
Probably an authentication issue.
Did you whitelist your LAN in Domoticz Settings -> Local networks?
JuanUil
Post by JuanUil »
Hi Lokonli,
Yes I did
127.0.0.*;192.168.2.*;127.0.0.*;192.162.1.*
strange is that on my laptop everything is oke and on tablet and home computer not.
JuanUil wrote: Saturday 09 January 2021 12:21
Can you try below line? This to make sure also IPv6 type of network traffic can acces domoticz from the LAN without user/password
127.0.0.*;192.168.2.*;192.162.1.*;::1
[EDIT] Not sure this works on your version if that is indeed still 4.11083
JuanUil
Post by JuanUil »
Hi Waaren,
no succes.
On laptop oke, on homecomputer and android tablet nok
I am on version 12833 of domoticz and version 3.7.2 beta of dashticz
Lokonli
Post by Lokonli »
On your homecomputer can you open devtools (f12), refresh Dashticz, and report here the errors and user messages you see on the console tab?
Probably you also see some failed network requests on the network tab.
JuanUil
Post by JuanUil »
This is what I get
TSS: content-tss.js loaded:  http://192.168.2.16:8082/ content-tss.js:1:9
INS: content-ads.js loaded:  http://192.168.2.16:8082/ content-ads.js:1:9
TSS: Excluding content tss (trigger: send-message) content-tss.js:50:13
Deze pagina gebruikt de niet-standaard property ‘zoom’. Overweeg het gebruik van calc() in de relevante propertywaarden of gebruik ‘transform’ samen met ‘transform-origin: 0 0’. bundle.js:3:6720
Object { readyState: 4, getResponseHeader: getResponseHeader(f), getAllResponseHeaders: getAllResponseHeaders(), setRequestHeader: setRequestHeader(f, p), overrideMimeType: overrideMimeType(f), statusCode: statusCode(f), abort: abort(f), state: state(), always: always(), catch: catch(f), … }
js/main.js:299:15
Lokonli
Post by Lokonli »
The files content-tss.js and content-ads.js are not from Dashticz.
Do you have some browser plugins active? or network proxy?
What kind of homecomputer do you have? Which browser? versions?
What is the IP adress of you Domoticz server?
In DevTools->network tab do you see a network request with an error return code?
JuanUil
Post by JuanUil »
Hi Lokonli
This is shown in the network tab after refresch
and this when i refresh thepage in the console
I have no proxy and no other plugins on my homecomputer then on my laptop
192.168.2.16
a tower with amd processor.
tried firefox latest version. tried both normal and private mode
tried Chrome latest version both normal and private mode
on my laptop with Chrome latest version no problems
also tried on 2 tablets (android) same problem.
thanx for your help!!!
JuanUil
Post by JuanUil »
anybody any idea what could be the problem causing this strange behaviour?
Lokonli
Post by Lokonli »
On the network tab you see the language file gives a 404 error.
Language should be 'nl_NL' instead of 'nl-NL' ...
JuanUil
Post by JuanUil »
Hi Lokonli,
That did the trick!!!
Tanx for the help.
but I don't understand that it was loading on my laptop but not on homecomputer and tablets.
Anyway it is working that is the most important!
again thank you
jan
