Simultaneous connections
meyland
Post by meyland »
I'm developing a plugin and I need to be able to make about 20-30 simultaneous connections to a website.
I don't know how to make all these connections by using the connection object. Can anyone give me a hint? :D
regards
Peter
pipiche
Re: Simultaneous connections
Post by pipiche »
meyland wrote: Monday 04 January 2021 20:17 I'm developing a plugin and I need to be able to make about 20-30 simultaneous connections to a website.
You should check the plugins/examples/HTTP.py
self.httpConn = Domoticz.Connection(Name=self.sProtocol+" Test", Transport="TCP/IP", Protocol=self.sProtocol, Address=Parameters["Address"], Port=Parameters["Mode1"])
And you do as many as you need.
Now if you don't want to use the Connection API you might go for a multi Thread opening their own connection via urlibrequest or other python3 module like that
Domoticz version: 2026.3
There is a Multi-Thread example https://github.com/domoticz/domoticz/bl ... hreaded.py
See also the Wiki for some remarks about this: https://www.domoticz.com/wiki/Developin ... rk_details:
meyland
Post by meyland »
Many thanks, I will look at the examples to night
regards
Peter
meyland
Post by meyland »
a thought: is it possible to use the asyncio module, ie async and await syntax in a plugin?
regards
Peter
pipiche
Post by pipiche »
yes you can use the async
meyland
Post by meyland »
Sounds good. Are there any examples on how to use asyncio?
regards
Peter
