If you are in the dilemma of buying a Shark APEX Uplight Lift-away DuoClean vacuum or not, this article is for you. We will write a Shark apex uplight review.
Our Impressions Compared to the Shark Navigator
1) It is less heavy than the Shark Navigator.
Yes, the Shark APEX UpLight Vacuum is a few pounds lighter than the Shark Navigator. t was simple for us to operate and navigate.
2) Able to go through all surfaces and thoroughly clean each one.
Yes, the Shark APEX UpLight vacuum cleans our tile floors, carpets, and carpet rugs well, and does nicely around the floor's baseboard margins. The suction is comparable to or better than that of the Navigator.
Nevertheless, the suction strength is powerful, and it picks up a great deal of hair, dirt, and dirt that you can't see on the floor.
In fact, the suction is so powerful that we have to walk over the borders of our area carpets with extreme caution. We've had to switch off the vac and put the border back down a few times after sucking up around the edges of our rugs.
So there was still the issue of transitioning from a tiled floor to a rug-covered space. We have to elevate the ground connector somewhat over the edge, just as we did with our previous vacuum. When We vacuum, this is when We have to take the wand, which maybe 10 times per day. However, since this vacuum is much lighter, it becomes much simpler to do so.
3) Longer power cord
The Shark Apex UpLight Corded Lift Away vacuum, like the Navigator, has a longer cable. For a total length of 30 feet, add 5 feet.
4) Vacuum beneath most furniture without having to attach or unhook anything.
You can vacuum beneath most furnishings without pulling off the dirt container as this is a stick vac with the pod (dust container) at the top. The simple design of the ground connector is slightly below 4 inches. This ensures it can fit underneath mattresses with typical frames and several of the non-wheeled furniture items in our house.
We can clean the whole floor of our home, even beneath the couch, without moving anything or changing to a new tool in our situation. We are not only doing this everyday chore faster, but our house is also cleaner below the couch.
What we don’t like about the Shark apex uplight duoclean vacuum
Only the floor attachment has a light.
There is no illumination when you detach the pod from the stick section of the vac to use the hand-held component. The hand-held part of the Navigator features a light. This was really useful because we normally use a dusting accessory in a dimly lit environment.
Now, when we use this vacuum feature, we have to switch on the lights to see what we're cleaning.
Stretchy hose for handheld attachment use is not stretchy
When utilizing the hand accessories, the extendable hose isn't very flexible. It was also a problem with the Navigator. Without a lot of force, the hose will not expand out.
We hope that our review can help you decide if Shark apex uplight is for you.
