help with script
pvklink
Domoticz version: latest b
help with script
Post by pvklink »
hi @waaren.
You made (a year agoo) two scripts for me.
One to manage a usb lamp, one to save and restore states of devices.
My usb lamp normally gives a flame in the evening. When the doorbell rings it becomes red for 30 seconds.
It sometimes does not return to flame-state.
So i thought to use another script made by you, backup and restore the state of devices.
So i tried the restore the state with below test script, and yes this works!
Problem is that the lamp becomes red for 30 seconds and that i have to restore the lamp after x-second, 30 in this case..
Could you help me to add this option to the restore script?
@update, could you check my trial to fix this, i added a variable(timer) but that gives an error ?
error:
2021-01-02 20:29:44.244 Error: dzVents: Error: (3.0.19) /home/pi/domoticz/scripts/dzVents/scripts/global_data.lua:111: attempt to index a number value (field '?')
my programming trial (relevant part of global_data.lua)
   state_devices =
	function(dz,devstate,checkLights,checkDimmable,timer)	-- added the timer PVK
        if devstate == 'backup' then
            for index, deviceName in ipairs(checkLights) do
                dz.globalData.states[deviceName] = dz.devices(deviceName).active
            for index, deviceName in ipairs(checkDimmable) do
                dz.globalData.levels[deviceName] = dz.devices(deviceName).levelVal or dz.devices(deviceName).level
        elseif devstate == 'restore' then
			if timer == nil then timer = 0 end
                if dz.globalData.states[deviceName] == true then
                    dz.devices(deviceName).switchOn().afterSec(timer)
                    dz.devices(deviceName).switchOff().afterSec(timer)
                dz.devices(deviceName).dimTo(dz.globalData.levels[deviceName].afterSec(timer))
        elseif devstate == 'clean' then
	    dz.globalData.states = {}
            dz.globalData.levels = {}
    end,
testscript
	on =    {
		devices = {'test'}
	execute = function(dz, item)
    if item.state == 'On' then
        dz.helpers.state_devices(dz,'backup',{},{'usb lamp'})
        dz.helpers.alertLidl(dz, "rood", 30)
        dz.helpers.state_devices(dz,'restore',{},{'usb lamp'})
original global_data.lua
return
  data =
        myGlobalVar = { initial = 12 },
        mylogging = {initial = 'Eerst aanmaak van global variable mylogging in global_data.lua'},
        states = { initial = {}},
        levels = { initial = {}},
    helpers =
        alertLidl = function(dz, action, period)
            local controlVar = dz.variables("controlVar")
            local value = controlVar.value
            if controlVar.value ~= action then
                controlVar.set(action)
                if period then
                    controlVar.set(value).afterSec(period)
                    dz.log("alert requested; controlVar set to " .. action .. ". It will return to ".. value .. " after " .. period .. " seconds." ,dz.LOG_FORCE)
                    dz.log("alert requested; controlVar set to " .. action  ,dz.LOG_FORCE)
                dz.log("No changed needed; controlVar is already set to " .. value,dz.LOG_DEBUG)
    end,
        globalMessage2 = function(dz,item,info,messageTable,action, message, logcode)
        if logcode == nil then logcode = 3 end
        if action == 'add' and logcode > 0 then
            messageTable = dz.helpers.addMessage(dz, item, info, message, messageTable, logcode)
        elseif action == 'del' then
            dz.globalData.mylogging = message
            dz.devices('timerlog').updateText(message)
        elseif action == 'chg' then
            dz.helpers.dumpMessages(dz, messageTable)
    end,
   addMessage =
        function(dz, item, info, message, messages,logcode)
	        	local trigger
		if item.isDevice then
				trigger = ", Device: " .. item.name
	        elseif item.isTimer then
				trigger = ", Timer: " .. item.trigger
		elseif item.isVariable then
				trigger = ", Variable: " .. item.name
				trigger = ", Unknown trigger"
		messages[#messages + 1] = {}
		if logcode ~= 2 then
		            messages[#messages].log  = 'scriptname: ' .. info.scriptName .. trigger .. ' ' .. message
		if logcode ~= 1 then
			messages[#messages].text = dz.time.rawDate .. '  ' .. dz.time.rawTime .. ' : ' .. message
			--messages[#messages].text = dz.time.rawDate .. '  ' .. dz.time.rawTime .. ' : ' .. message .. '<br>'
           	return messages
	end,
   matchesWildCardedString =
	function (dz,stringToMatch, wildCardedString)
        	local magicalChars  =  '[^%w%s~{\\}:&(/)<>,?@#|_^*$]'  -- Lua 'magical chars'
	        local regExpression = ('^' .. wildCardedString:gsub("[%^$]",".")) -- make it a valid regexpression
        	if wildCardedString:find('*') and wildCardedString:find('?') then
	            dz.log('Not possible to combine single char wildcard(s) "?" with multi char wildcard(s) "*"',dz.LOG_ERROR)
        	    return false
	        elseif wildCardedString:find('*') then -- a * wild-card was used
        	    wildCardedString = (regExpression:gsub("*", ".*") .. '$'):gsub(magicalChars,'.') -- replace * with .* (Lua for zero or more of any char)
	        elseif wildCardedString:find('?') then -- a ? wild-card was used
        	    wildCardedString = (regExpression:gsub("?", ".") .. '$'):gsub(magicalChars,'.') -- replace ? with . (Lua for single any char)
		return stringToMatch:match(wildCardedString) == stringToMatch
	end,
   delayedURL =
	function(dz,callback,delay)   --functie om een andere script aan te roepen
        	local logString = "/json.htm?type=command&param=addlogmessage&message=" .. dz.utils.urlEncode("Hook_alarm")
	        local url= dz.settings['Domoticz url'] .. logString
        	dz.openURL({    url = url,method = "GET",callback = callback }).afterSec(delay)
	end,
    state_devices =
	function(dz,devstate,checkLights,checkDimmable)
                dz.devices(deviceName).dimTo(dz.globalData.levels[deviceName])
    end,
    dumpMessages =
        function(dz, messages)
            local textDevice = dz.devices('timerlog')
	    local currentText = dz.globalData.mylogging
            local newText = currentText
	    local lf = '<br>'					--local lf = "\n" 	--local lf = "\r\n"	--PVK \n of \r\n UITGEZET ANDERS werkt dashticz niet
            local maxLines = 8
            for i, record in ipairs(messages) do
                if record.log then dz.log(record.log, dz.LOG_INFO) end
                if record.text then newText = record.text .. lf .. newText end
            dz.log(newText, dz.LOG_INFO)
            if newText ~= currentText then
                --lines = dz.utils.stringSplit(newText, lf)  -- create lines table from newText string						--PVK UITGEZET ANDERS werkt dashticz niet
                --newText = table.concat(lines, lf, 1, (math.min(maxLines,#lines))) -- recreate newText string from first maxLines 		--PVK UITGEZET ANDERS werkt dashticz niet
                textDevice.updateText(newText)
		dz.globalData.mylogging = newText  -- ADDED
        end,
Jablotron connection, Ikea
pvklink
Re: help with script
Post by pvklink »
Think i solved it myself...
old
new
dz.devices(deviceName).dimTo(dz.globalData.levels[deviceName]).afterSec(timer)
pvklink wrote: Saturday 02 January 2021 20:58 Think i solved it myself...
old
new
Top!
[Tip]
the dzVents errormessage contains a line number so it make sense to share the original file with unchanged line numbers (So no extra lines and no deleted lines) if you are looking for help.
pvklink
Post by pvklink »
Yes, sorry, too enthousiastic...
