JSON in a CustomEvent JSON URL  [Solved]
peterbos
Post by peterbos »
I want to send JSON data in a custom event JSON URL as an easy way of sending data from a Windows program to Domoticz. One of the several URLs I tried was
http://192.168.1.162:8080/json.htm?type=command&param=customevent&event=testTrigger&data={"field1":"This is field 1","field2":"This is field 2"}
I made a simple script to recive the data:
		customEvents = {
			'testTrigger' -- event triggered by emitEvent
	data = {},
	logging = {},
	execute = function(dz, triggeredItem)
		if (triggeredItem.isCustomEvent) then
		    if (triggeredItem.isJSON) then
		        local myData = triggeredItem.json
			dz.log('Test succeeded, data = ' .. myData.field1 , dz.LOG_ERROR)
I also tried it with "", '', extra {} and/or [] but I keep getting error messages of all kind. What is the right way to pass a JSON with this custom event JSON?
Peter
peterbos
Re: JSON in a CustomEvent JSON URL  [Solved]
Post by peterbos »
I solved it.
Peter
peterbos wrote: Thursday 31 December 2020 0:35 I want to send JSON data in a custom event JSON URL as an easy way of sending data from a Windows program to Domoticz.
[Edit] Good that you solved it. For other forum members facing the same..
Below curl and script should do it if you allowed your local network to access domoticz without password.
[Setup][Settings][System]
Local Networks (no username/password):
Networks:
127.0.0.*;192.168.1.*;::1
curl -d '{"field1":"This is field 1","field2":"This is field 2"}' 'http://192.168.1.162:8080/json.htm?type=command&param=customevent&event=testTrigger'
return
    on =
        customEvents =
            'testTrigger',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = ' testCiustomEvent',
    execute = function(dz, item)
        if item.isJSON then
            dz.log('Test succeeded, json received = ' , dz.LOG_FORCE)
            dz.utils.dumpTable(item.json)
            dz.log('Test partial succeeded, item = ', dz.LOG_FORCE)
            dz.utils.dumpTable(item)
peterbos
Post by peterbos »
Hi Waaren,
Maybe your solution works but I can't trigger the custom event from a browser with the simple command. I found out that the problem was not in the URL but in the script. The check if the data is a JSON fails but the data is treated as a JSON correctly.
This script works but only without either of the two commands I commented out:
		customEvents = {
	data = {},
	logging = {},
		--if (triggeredItem.isJSON) then        <--- doesn't work
		--if (triggeredItem.data.isJSON) then      <--- doesn't work also
		    dz.log(triggeredItem.data , dz.LOG_ERROR)
		    dz.log('Test succeeded, data = ' .. triggeredItem.data.field1 , dz.LOG_ERROR)
		--end
Peter
peterbos wrote: Friday 01 January 2021 17:27 Hi Waaren,
I cannot replicate your issue so I can only guess you are on a version before build 12019
In this version I made the check for valid JSON strings a bit more forgiving. According the standard a JSON string cannot start with a curly bracket but because the Lua JSON decoder does allow it, I changed dzVents behavior in versions > 12019 to accept them as valid JSON
What do you see when you repeat my tests?
    (my test system runs on a system named nuc and I use port 8084 for my test / development domotcicz)
    test in Browser window
    http://nuc:8084/json.htm?type=command&param=customevent&event=testTrigger&data={"field1":"This is field 1","field2":"This is field 2"}
2021-01-01 18:30:39.902  Status: dzVents: Info:  testCustomEvent: ------ Start internal script: dz 20201231 customSensor: Custom event: "testTrigger"
2021-01-01 18:30:39.903  Status: dzVents: Info:  testCustomEvent: dzVents version: 3.1.0
2021-01-01 18:30:39.904  Status: dzVents: Info:  testCustomEvent: domoticz version: 2020.2 (build 12803)
2021-01-01 18:30:39.904  Status: dzVents: Info:  testCustomEvent: isJSON: true ; ==>> {["field2"]="This is field 2", ["field1"]="This is field 1"}
2021-01-01 18:30:39.904  Status: dzVents: Info:  testCustomEvent: data ==>> {"field1":"This is field 1","field2":"This is field 2"}
2021-01-01 18:30:39.904  Status: dzVents: Info:  testCustomEvent: data.field1 =>> nil
2021-01-01 18:30:39.906  Status: dzVents: Info:  testCustomEvent: ------ Finished dz 20201231 customSensor
    test from commandLine
    curl -d '{"field1":"This is field 1","field2":"This is field 2"}' 'nuc:8084/json.htm?type=command&param=customevent&event=testTrigger'
2021-01-01 18:32:59.834  Status: dzVents: Info:  testCustomEvent: ------ Start internal script: dz 20201231 customSensor: Custom event: "testTrigger"
2021-01-01 18:32:59.836  Status: dzVents: Info:  testCustomEvent: dzVents version: 3.1.0
2021-01-01 18:32:59.836  Status: dzVents: Info:  testCustomEvent: domoticz version: 2020.2 (build 12803)
2021-01-01 18:32:59.836  Status: dzVents: Info:  testCustomEvent: isJSON: true ; ==>> {["field1"]="This is field 1", ["field2"]="This is field 2"}
2021-01-01 18:32:59.836  Status: dzVents: Info:  testCustomEvent: data ==>> {"field1":"This is field 1","field2":"This is field 2"}
2021-01-01 18:32:59.836  Status: dzVents: Info:  testCustomEvent: data.field1 =>> nil
2021-01-01 18:32:59.838  Status: dzVents: Info:  testCustomEvent: ------ Finished dz 20201231 customSensor
return
    on =
        customEvents =
            'testTrigger',
    logging =
        marker = ' testCustomEvent',
        dz.log('dzVents version: ' .. dz.settings.dzVentsVersion)
        dz.log('domoticz version: ' .. dz.settings.domoticzVersion)
        if (item.isJSON) then
                dz.log('isJSON: true ; ==>> '.. dz.utils.toStr(item.json) )
        dz.log('data ==>> ' .. dz.utils.toStr(item.data) )
        dz.log('data.field1 =>> ' .. dz.utils.toStr(item.data.field1) )
peterbos
Post by peterbos »
Hi Waaren,
I have Domoticz 2020.2 with dzvents 3.0.2. The difference between our approaches is that I send the data as part of the URL and you use two lines from a commandLine (which?) in which the data is not part of the URL.
Peter
peterbos wrote: Friday 01 January 2021 23:04 Hi Waaren,
If you look closely to my last post you will see that I tested two different methods. One from the browser address bar with data as part of the url and one using curl with data separated from the url (command line Debian) but this will not work for your version either because it is using post and that was not available for dzVents 3.0.2
If you intend to keep using the stable version with dzVents 3.0.2, you will have to keep using item.data when sending from a browser. If you update to the beta channel you will have the fixed version (and a lot more)
peterbos
Post by peterbos »
Hi Waaren,
I downloaded Domoticz and dzVents only two months ago, so it surprised me that I have an old version of dzVents. I see that the current stable version is 3.1.0. Is that the version you're pointing to? I prefer not to use a beta version.
I used the Check for updates button in Domoticz but get the message No updates available. How do I install dzVents 3.1.0?
Peter
peterbos wrote: Sunday 03 January 2021 0:39 I used the Check for updates button in Domoticz but get the message No updates available. How do I install dzVents 3.1.0?
You downloaded the release (aka) stable version. Hotfixing and development of domoticz takes place in the Beta channel. Releases are not hotfixed. If you want the latest version you nee to switch to Beta.
