Heatit Z-TRM3 thermostat
DeVille70
Has anyone been able to install the Heatit Z-TRM3 thermostat? I tried, but with no success.
Yabby
Re: Heatit Z-TRM3 thermostat
I just swapped my Z-TRM2 for 3, i did install them but there is an issue with the setpoint, which cannot be set. It seems to be affecting all the system based on open z-wave. Apparently an issue on the format of the command. It seems widespread in the forums
DeVille70
Thanks. Did it include correctly? I get a number of devices, but no configuration options at all of the Z-Wave node. That makes me suspect it did not include correctly, or I use the wrong xml file.
Yabby
Yes I managed to include it correctly
Is this still an issue or is the Heat It Z-TRM3 fully functional in Domoticz?
Geitje
I have this exact same problem. Inclusion if fine, but I cannot set the setpoint from Domoticz. The setpoint is reported fine if I change it on the device itself.
How have others resolved this?
Zwave, Zigate, RFlink etc.
Emmerich
Thanks for the update and quick reply. I'll be sure to keep an eye on this thread. Looking for the same issue.
MyFordBenefits Login
Last edited by Emmerich on Wednesday 30 December 2020 10:46, edited 2 times in total.
Geitje
I found this on Github:
https://github.com/OpenZWave/open-zwave/pull/2458
So it seems a OpenZwave issue, so little to do with Domoticz. Let's just wait until thay merge the pull request on Github...
