Compute minutes virtual switch  [Solved]
javalin
Domoticz version: 4.10717
Post by javalin »
Hello, I would like to compute the total number of minutes that a virtual switch has been 'on' during a day. I have made a script that manages to download the json data from the database, I suppose that now it would be necessary to create another function that compares the 'on' and 'off' states to calculate the range time that it has been working and accumulate it in a counter. The result can be given in a text variable, for example. Here is the code I have developed, some help is welcome.
local activeDevice = 592
local scriptVar = 'Compute total minutes'
return
    on =
        timer =
            'every 1 minutes', -- for DEBUG
        httpResponses =
            scriptVar .. '*',
    logging =
        level = domoticz.LOG_DEBUG ,
        marker = scriptVar,
    execute = function(dz, item)
        if not(dz.devices(activeDevice).active) then return end
        local AC_room = dz.devices(590)
        local function triggerJSON(id, delay)
        url = dz.settings['Domoticz url'] .. '/json.htm?type=lightlog&idx=' .. id
        dz.openURL({ url = url, callback = scriptVar .. '_' .. id}).afterSec(delay or 0)
         -- main
        if item.isTimer then
        triggerJSON(AC_room.id)
        if item.isHTTPResponse then
            if item.isJSON then
                rt = item.json.result
                --dz.utils.dumpTable(item.json)                           -- dump the string represenation of the complete table to log
                local time = rt[1]["Date"]
                dz.log(time,dz.LOG_DEBUG)
Re: Compute minutes virtual switch
javalin wrote: Saturday 26 December 2020 20:12 some help is welcome.
some help below
return
    on =
        timer =
        httpResponses =
            scriptVar .. '*',
    logging =
        marker = scriptVar,
    data =
        state =
            initial = {},
        local function makeTimeStamp(dateString, pattern)
            local pattern = pattern or  "(%d+)%-(%d+)%-(%d+)%s(%d+):(%d+):(%d+)"
            local year, month, day, hour, minute, seconds= dateString:match(pattern)
            local convertedTimestamp = os.time({year = ('20' .. year), month = month, day = day, hour = hour, min = minute, sec = seconds})
            return convertedTimestamp
        -- main
        if item.isTimer or item.isDevice then
            if dz.data.state[dz.time.rawDate] == nil then
                dz.data.state[dz.time.rawDate] = AC_room.state  -- keep state at first run of the day
            return
        if item.isJSON then
            for _, record in ipairs(rt) do
                 dz.log('action ' .. record.Status .. ', at ' .. record.Date .. ' =>> timeStamp: ' .. makeTimeStamp(record.Date),dz.LOG_DEBUG)
            dz.log('Problem retrieving data..',dz.LOG_ERROR)
            dz.log(item,dz.LOG_DEBUG)
javalin
Post by javalin »
some help below
Thank you waaren, I get this error on Log Debug: (time result cannot be represented in this installation)
2020-12-27 16:57:01.444 Error: dzVents: Error: (3.0.19) Compute total minutes: An error occurred when calling event handler compute_minutes_waaren
2020-12-27 16:57:01.444 Error: dzVents: Error: (3.0.19) Compute total minutes: ...ipts/dzVents/generated_scripts/compute_minutes_waaren.lua:41: time result cannot be represented in this installation
Line 41 is:
javalin wrote: Sunday 27 December 2020 18:01 I get this error on Log Debug: (time result cannot be represented in this installation)
Can you try this one? It' s not a complete solution but should point you in the right direction.
return
    on =
        timer =
        httpResponses =
            scriptVar .. '*',
    logging =
        marker = scriptVar,
    data =
        state =
            initial = {},
            return os.time({year = year, month = month, day = day, hour = hour, min = minute, sec = seconds})
        -- main
            return
        if item.isJSON then
javalin
Post by javalin »
Thank you very much waaren, you give the timeStamp for each state log, that was the tricky point.
I understand the behavior of the script, in spite of everything, I will have to look more closely.
So, I have decided to continue the script with the code I show bellow and it seems to work. The most complicated thing has been to manage the various Log scenarios:
- Case 1: we have a log with successives 'On' and 'Off'. (easy)
- Case 2: we have a log with two consecutive 'Off' states.
- Case 3: we have a log with two consecutive 'On' states.
- Case 4: we have a log with an 'Off' status at the beginning.
- Case 5: we run the script with the switch in the 'On' state.
I think I have managed to solve the situations 1,2,3,4 and I still have the 5 under study. But I think I will need the current time to finish it as I think.
return
    on =
        timer =
        httpResponses =
            scriptVar .. '*',
    logging =
        marker = scriptVar,
    data =    --persistent data?
        state =
            initial = {},
        local AC_room = dz.devices(13)
        local counter = 0
        local lastTimeStamp = 0
            local pattern = pattern or  "(%d+)%-(%d+)%-(%d+)%s(%d+):(%d+):(%d+)"  -- must be this format!! "2016-12-12 07:35:00"
        -- main
                dz.data.state[dz.time.rawDate] = AC_room.state  -- keep state at first run of the day, will be something like: 2016-12-12T20:00:00Z
            return
        if item.isJSON then
            local leng = 0
            for k, v in pairs(rt) do
            	leng = leng+1
            dz.log('Lenght ' ..leng,dz.LOG_DEBUG)
                 if _>=2 and item.json.result[_].Data == item.json.result[_-1].Data and record.Status == "Off" then --Ok!, avoid bug for 2 successives 'Off' in Log
                 counter = counter - lastTimeStamp + makeTimeStamp(record.Date)
                 elseif _>=2 and item.json.result[_].Data == item.json.result[_-1].Data and record.Status == "On" then --Don´t have tested yet, avoid bug for 2 successives 'On' in Log
                 counter = counter
                 elseif _ == leng and record.Status == "Off" then --Ok!, avoid bug if you have an 'Off' as first state in Log (older state, not last state)
                 counter = counter
                 elseif _ == leng and record.Status == "On" then --Dont work, may be it needed to call to actual timeStamp. Need to resolve bug if srcipt runs at same time switch has 'On' state
                 counter = counter
                 elseif record.Status == "Off" then
                 counter = counter + makeTimeStamp(record.Date)
                 elseif record.Status == "On" then
                 counter = counter - makeTimeStamp(record.Date)
                 lastTimeStamp = makeTimeStamp(record.Date)
            minutes= counter/60
            seconds= counter%60
            if seconds < 10 then
            dz.log('Number of minutes ' ..math.floor(minutes)..':0'..seconds..'s',dz.LOG_DEBUG)
            dz.log('Number of minutes ' ..math.floor(minutes)..':'..seconds..'s',dz.LOG_DEBUG)
            dz.log('Counter ' .. dz.utils.round(counter,2),dz.LOG_DEBUG)
javalin wrote: Monday 28 December 2020 21:54 I think I have managed to solve the situations 1,2,3,4 and I still have the 5 under study. But I think I will need the current time to finish it as I think.
Good progress !
If you need the amount of records in an array type Lua table you can use #tablename
You normally only use the underscore as a placeholder for a varname if you don't intend to use it in your code
Current time in dzVents scripts is dz.time (or dz.time.dDate or os.time() if you only use current time as timestamp)
return
    on =
        timer =
        httpResponses =
            scriptVar .. '*',
    logging =
        marker = scriptVar,
        state =
            initial = {},
        local counter = 0
        -- main
            return
        if item.isJSON then
            dz.log('Lenght ' ..#rt,dz.LOG_DEBUG)
            for index, record in ipairs(rt) do
                 if index >= 2 and record.Data == rt[index - 1].Data and record.Status == "Off" then -- Ok!, avoid bug for 2 successives 'Off' in Log
                 elseif index >=2 and record.Data == rt[index - 1].Data and record.Status == "On"  then --Don´t have tested yet, avoid bug for 2 successives 'On' in Log
					counter = counter
                 elseif index == #rt and record.Status == "Off" then --Ok!, avoid bug if you have an 'Off' as first state in Log (older state, not last state)
					counter = counter
                 elseif index == #rt and record.Status == "On" then --Dont work, may be it needed to call to actual timeStamp. Need to resolve bug if script runs at same time switch has 'On' state
					counter = counter
            minutes = counter / 60
            seconds = counter % 60
				dz.log('Number of minutes ' ..math.floor(minutes) .. ':0' .. seconds .. 's',dz.LOG_DEBUG)
				dz.log('Number of minutes ' .. math.floor(minutes) .. ':' .. seconds .. 's',dz.LOG_DEBUG)
javalin
Post by javalin »
Thanks for the tips waaren. It is easier for me to understand the script with this format.
I have already solved 'Case 5' using the Current time, so the script can work with any type of Log and I have added an output for a text variable. I'll probably try to create a counter to store the result for each day. I think it will also be possible.
Why the script needs to store in a persistent variables called 'state' the first state of each day? I can't guess why
 dz.data.state[dz.time.rawDate] = switch.state
This is the new code:
return
    on =
        timer =
            'every 15 minutes', -- for DEBUG
        httpResponses =
            scriptVar .. '*',
    logging =
        marker = scriptVar,
        state =
            initial = {},
        local switch = dz.devices(589)
        local text = dz.devices(637)
        local counter = 0
        -- main
            if dz.data.state[dz.time.rawDate] == nil then   --["rawDate"]="2020-12-28" and ["rawDateTime"]="2020-12-28 22:56:01"
                dz.data.state[dz.time.rawDate] = switch.state  -- keep state at first run of the day, will be something like: 2016-12-12T20:00:00Z
            triggerJSON(switch.id)
            return
        if item.isJSON then
            dz.log(dz.time.dDate,dz.LOG_DEBUG)
                 if index == 1 and record.Status == "On" then --Ok!, avoid bug if script runs at same time switch has 'On' state
					counter = dz.time.dDate - makeTimeStamp(record.Date)
                 elseif index >= 2 and record.Data == rt[index - 1].Data and record.Status == "Off" then -- Ok!, avoid bug for 2 successives 'Off' in Log
					counter = counter + lastTimeStamp - makeTimeStamp(record.Date)
					counter = counter
            hours = math.floor(counter/60/60)
            minutes = math.floor(counter/60%60)
            if minutes < 10 then
			    	dz.log('Today: ' ..hours ..':0'..minutes .. ':0' .. seconds .. 's',dz.LOG_DEBUG)
                    text.updateText('Today: ' ..hours..':0'..minutes .. ':0' .. seconds .. 's')
			    	dz.log('Today: ' ..hours ..':0'..minutes .. ':' .. seconds .. 's',dz.LOG_DEBUG)
                    text.updateText('Today: ' ..hours ..':0'..minutes .. ':' .. seconds .. 's')
     			    dz.log('Today: ' ..hours ..':'..minutes .. ':0' .. seconds .. 's',dz.LOG_DEBUG)
                    text.updateText('Today: ' ..hours..':'..minutes .. ':0' .. seconds .. 's')
			    	dz.log('Today: ' ..hours ..':'..minutes .. ':' .. seconds .. 's',dz.LOG_DEBUG)
                    text.updateText('Today: ' ..hours ..':'..minutes .. ':' .. seconds .. 's')
Last edited by javalin on Tuesday 29 December 2020 23:03, edited 3 times in total.
javalin wrote: Tuesday 29 December 2020 22:10 Why the script needs to store in a persistent variables called 'state' the first state of each day? I can't guess why
I added this because it was not clear to me if you were looking for the "On" time of today or for a longer period.
The records in LightingLog are not kept forever and in theory this means that you will not find a time in LigtingLog for a last state change. In such a case you might be helped by the state at the beginning of a day.
javalin
Post by javalin »
I look for the "On" time of today.
Curiously now I have realized that I have the Log with statuses from yesterday:
 2020-12-29 22:30:01.461 Status: dzVents: Info: Compute total minutes: ------ Start internal script: compute_minutes_clean: HTTPResponse: "Compute total minutes_589"
2020-12-29 22:30:01.470 Status: dzVents: Debug: Compute total minutes: Processing device-adapter for AC Maria: Switch device adapter
2020-12-29 22:30:01.471 Status: dzVents: Debug: Compute total minutes: Processing device-adapter for Counter time relay: Text device
2020-12-29 22:30:01.471 Status: dzVents: Debug: Compute total minutes: Lenght 31
2020-12-29 22:30:01.471 Status: dzVents: Debug: Compute total minutes: 1609281001
2020-12-29 22:30:01.471 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-29 12:03:16 =>> timeStamp: 1609243396
2020-12-29 22:30:01.472 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-29 12:03:07 =>> timeStamp: 1609243387
2020-12-29 22:30:01.472 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-29 12:01:28 =>> timeStamp: 1609243288
2020-12-29 22:30:01.472 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-29 12:01:23 =>> timeStamp: 1609243283
2020-12-29 22:30:01.472 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-29 12:00:17 =>> timeStamp: 1609243217
2020-12-29 22:30:01.472 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-29 12:00:01 =>> timeStamp: 1609243201
2020-12-29 22:30:01.472 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-29 11:59:59 =>> timeStamp: 1609243199
2020-12-29 22:30:01.472 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-29 11:59:50 =>> timeStamp: 1609243190
2020-12-29 22:30:01.472 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-29 10:56:56 =>> timeStamp: 1609239416
2020-12-29 22:30:01.473 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-29 10:56:38 =>> timeStamp: 1609239398
2020-12-29 22:30:01.473 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-29 07:56:29 =>> timeStamp: 1609228589
2020-12-29 22:30:01.473 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-29 07:00:18 =>> timeStamp: 1609225218
2020-12-29 22:30:01.473 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-29 06:55:18 =>> timeStamp: 1609224918
2020-12-29 22:30:01.473 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-29 04:23:26 =>> timeStamp: 1609215806
2020-12-29 22:30:01.473 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-29 03:53:26 =>> timeStamp: 1609214006
2020-12-29 22:30:01.473 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-28 23:00:12 =>> timeStamp: 1609196412
2020-12-29 22:30:01.473 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-28 22:30:12 =>> timeStamp: 1609194612
2020-12-29 22:30:01.473 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-28 21:47:51 =>> timeStamp: 1609192071
2020-12-29 22:30:01.474 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-28 21:37:05 =>> timeStamp: 1609191425
2020-12-29 22:30:01.474 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-28 21:17:36 =>> timeStamp: 1609190256
2020-12-29 22:30:01.474 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-28 21:17:11 =>> timeStamp: 1609190231
2020-12-29 22:30:01.474 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-28 21:06:01 =>> timeStamp: 1609189561
2020-12-29 22:30:01.474 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-28 21:00:20 =>> timeStamp: 1609189220
2020-12-29 22:30:01.474 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-28 20:33:01 =>> timeStamp: 1609187581
2020-12-29 22:30:01.474 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-28 20:30:10 =>> timeStamp: 1609187410
2020-12-29 22:30:01.474 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-28 20:30:02 =>> timeStamp: 1609187402
2020-12-29 22:30:01.474 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-28 14:06:01 =>> timeStamp: 1609164361
2020-12-29 22:30:01.475 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-28 13:45:01 =>> timeStamp: 1609163101
2020-12-29 22:30:01.475 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-28 07:46:50 =>> timeStamp: 1609141610
2020-12-29 22:30:01.475 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-28 07:42:09 =>> timeStamp: 1609141329
2020-12-29 22:30:01.475 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-28 06:41:43 =>> timeStamp: 1609137703
2020-12-29 22:30:01.475 Status: dzVents: Debug: Compute total minutes: Today: 10:28:22s
Normaly my switches will never have yesterday's Log because every midnight I run a script to cleanup database that deletes everything older than a day in LightingLog. But for some reason yestarday didn´t run and it must be the reason for this long Log.
EDIT:
I have run now manually the srcipt to cleanup the database and now the LOG_DEBUG is correct:
 2020-12-29 22:53:01.238 Status: dzVents: Info: Compute total minutes: ------ Start internal script: compute_minutes_clean: HTTPResponse: "Compute total minutes_589"
2020-12-29 22:53:01.258 Status: dzVents: Debug: Compute total minutes: Processing device-adapter for AC Maria: Switch device adapter
2020-12-29 22:53:01.259 Status: dzVents: Debug: Compute total minutes: Processing device-adapter for Counter time relay: Text device
2020-12-29 22:53:01.259 Status: dzVents: Debug: Compute total minutes: Lenght 15
2020-12-29 22:53:01.259 Status: dzVents: Debug: Compute total minutes: 1609282381
2020-12-29 22:53:01.259 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-29 12:03:16 =>> timeStamp: 1609243396
2020-12-29 22:53:01.259 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-29 12:03:07 =>> timeStamp: 1609243387
2020-12-29 22:53:01.259 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-29 12:01:28 =>> timeStamp: 1609243288
2020-12-29 22:53:01.260 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-29 12:01:23 =>> timeStamp: 1609243283
2020-12-29 22:53:01.260 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-29 12:00:17 =>> timeStamp: 1609243217
2020-12-29 22:53:01.260 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-29 12:00:01 =>> timeStamp: 1609243201
2020-12-29 22:53:01.260 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-29 11:59:59 =>> timeStamp: 1609243199
2020-12-29 22:53:01.260 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-29 11:59:50 =>> timeStamp: 1609243190
2020-12-29 22:53:01.260 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-29 10:56:56 =>> timeStamp: 1609239416
2020-12-29 22:53:01.260 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-29 10:56:38 =>> timeStamp: 1609239398
2020-12-29 22:53:01.260 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-29 07:56:29 =>> timeStamp: 1609228589
2020-12-29 22:53:01.260 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-29 07:00:18 =>> timeStamp: 1609225218
2020-12-29 22:53:01.261 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-29 06:55:18 =>> timeStamp: 1609224918
2020-12-29 22:53:01.261 Status: dzVents: Debug: Compute total minutes: action On, at 2020-12-29 04:23:26 =>> timeStamp: 1609215806
2020-12-29 22:53:01.261 Status: dzVents: Debug: Compute total minutes: action Off, at 2020-12-29 03:53:26 =>> timeStamp: 1609214006
2020-12-29 22:53:01.261 Status: dzVents: Debug: Compute total minutes: Today: 3:29:00s
2020-12-29 22:53:01.261 Status: dzVents: Debug: Compute total minutes: Counter 12540.0
2020-12-29 22:53:01.262 Status: dzVents: Info: Compute total minutes: ------ Finished compute_minutes_clean
javalin
Re: Compute minutes virtual switch  [Solved]
Post by javalin »
Ok, solved :)
To use only daily data (today) from LightingLog I have wrote this line:
  if record.Date:sub(1,10) == dz.time.rawDate then
So bucle 'for' will be something like this:
        if item.isJSON then
					  counter = counter
