Hi All,
is it easy to fix to turn on a light, and then when motion detected dim a light to certain level and 2 mins after last motion dim back to last dim level?
for example:
when it is dark in a room, turn on and dim lights to 10%, when motion detected dim lights to 75%, and then 2 minutes after last motion back to last level?
So it might be that the light was off before motion wants to turn on the light to 75%, but after the motion is detected i want it BACK to OFF when the last state was OFF..
I know this can be done in dzvents, but is it also possible in lua?
Dim level by motion
- waaren
Re: Dim level by motion
dzVents is Lua so if you know how to solve it in dzVents you can just copy the underlying Lua code from the dzVents/runtime directory and repeat what the dzVents developers coded.BarryT wrote: Friday 25 December 2020 14:40 I know this can be done in dzvents, but is it also possible in lua?
BarryT
- Domoticz version: 2024.3
I just want to try out a lua script, not dzvents since i de-activated this due some reasons..waaren wrote: Friday 25 December 2020 15:48dzVents is Lua so if you know how to solve it in dzVents you can just copy the underlying Lua code from the dzVents/runtime directory and repeat what the dzVents developers coded.BarryT wrote: Friday 25 December 2020 14:40 I know this can be done in dzvents, but is it also possible in lua?
- waaren
I did not write that you should use the complete dzVents framework. What is in my post is a suggestion to have a look at the Lua code in dzVents runtime directory and copy paste the relevant Lua code in your own Lua script.BarryT wrote: Saturday 26 December 2020 10:42 I just want to try out a Lua script, not dzVents since i de-activated this due some reasons..![]()
I my book that is what coding is all about. Use what other coders already invented and build on that.
Ittiz
- Domoticz version: 13939
Should be doable, try these scripts. I adapted them from scripts I use in my own system. I haven't tested the changes however, you may have to fix typos/debug.
Device Script, turns the light on or brightens it when motion detected:
Timer script, turns the light off or sets it to low light level after timeout:
You WILL need another script to set the light level variable when you change it at the switch. I don't have anything like it so I won't bother providing it here, but it should be simple enough. If you don't the light values will ALWAYS default to the values you set in the variables.
local TimerName = "Living Room Minder" --Name of the dummy switch that determines whether the light should auto on
local MotionSensor = "Living Room Motion Sensor" --Name of the motion sensor in the room
local LightSwitch = "Living Room Dimmer" -- Name of the light switch
local LightTimer = "Living Room Dimmer Blind Timeout" -- Name of auto-off timeout user variable
local LastLightStateHigh = "Living Room LghtSttHg" -- Light level to set to when motion detected user variable
if ((devicechanged[MotionSensor] == 'On') and (otherdevices[TimerName] == 'On') and (otherdevices[LightSwitch] == 'Off')) then
local s1 = otherdevices_lastupdate[LightSwitch]
if (s1 == nil) then
s1 = "2000-01-01 00:00:00"
local year1 = string.sub(s1, 1, 4)
local month1 = string.sub(s1, 6, 7)
local day1 = string.sub(s1, 9, 10)
local hour1 = string.sub(s1, 12, 13)
local minutes1 = string.sub(s1, 15, 16)
local seconds1 = string.sub(s1, 18, 19)
local t1 = os.time()
local t2 = os.time{year=year1, month=month1, day=day1, hour=hour1, min=minutes1, sec=seconds1}
local difference1 = t1-t2
local difference2 = t1-t3
if (difference1 > tonumber(uservariables[LightTimer])) then -- If the light was turned off don't turn it back on!
if (tonumber(uservariables[LastLightStateHigh]) ~= "On") then
commandArray[LightSwitch]='Set Level ' .. tonumber(uservariables[LastLightStateHigh])
commandArray[LightSwitch] = "On"
local LightSwitch = "Living Room Dimmer" -- CHANGE: Name of light switch
local MotionSensor = "Living Room Motion Sensor" -- CHANGE: Name of motion sensor.
local LightTimer = "Lvngrm Light Off Timeout" -- CHANGE: Name of auto-off timeout user variable
local LvngRmMndr = "Living Room Minder" -- Dummy switch to Enable/disable auto off.
local LastLightStateLow = "LvngRmLghtSttLw" -- Light level to set to when NO motion detected user variable
--LightSwitch could be a dimmer, so we check if it's not off rather than if it's on.
if (otherdevices[LvngRmMndr] == "On" and otherdevices[LightSwitch] ~= "Off") then
local s1 = otherdevices_lastupdate[MotionSensor]
if (s1 == nil) then
if (tonumber(uservariables[LastLightStateLow]) ~= "Off") then
commandArray[LightSwitch]='Set Level ' .. tonumber(uservariables[LastLightStateLow])
commandArray[LightSwitch] = "Off"
BarryT
Sorry for the late answer, but thanks for these scripts!!Ittiz wrote: Sunday 27 December 2020 5:15 Should be doable, try these scripts. I adapted them from scripts I use in my own system. I haven't tested the changes however, you may have to fix typos/debug.
Device Script, turns the light on or brightens it when motion detected:Timer script, turns the light off or sets it to low light level after timeout:Code: Select all
commandArray = {} local TimerName = "Living Room Minder" --Name of the dummy switch that determines whether the light should auto on local MotionSensor = "Living Room Motion Sensor" --Name of the motion sensor in the room local LightSwitch = "Living Room Dimmer" -- Name of the light switch local LightTimer = "Living Room Dimmer Blind Timeout" -- Name of auto-off timeout user variable local LastLightStateHigh = "Living Room LghtSttHg" -- Light level to set to when motion detected user variable if ((devicechanged[MotionSensor] == 'On') and (otherdevices[TimerName] == 'On') and (otherdevices[LightSwitch] == 'Off')) then local s1 = otherdevices_lastupdate[LightSwitch] if (s1 == nil) then s1 = "2000-01-01 00:00:00" end local year1 = string.sub(s1, 1, 4) local month1 = string.sub(s1, 6, 7) local day1 = string.sub(s1, 9, 10) local hour1 = string.sub(s1, 12, 13) local minutes1 = string.sub(s1, 15, 16) local seconds1 = string.sub(s1, 18, 19) local t1 = os.time() local t2 = os.time{year=year1, month=month1, day=day1, hour=hour1, min=minutes1, sec=seconds1} local difference1 = t1-t2 local difference2 = t1-t3 if (difference1 > tonumber(uservariables[LightTimer])) then -- If the light was turned off don't turn it back on! if (tonumber(uservariables[LastLightStateHigh]) ~= "On") then commandArray[LightSwitch]='Set Level ' .. tonumber(uservariables[LastLightStateHigh]) else commandArray[LightSwitch] = "On" end end end return commandArray
You WILL need another script to set the light level variable when you change it at the switch. I don't have anything like it so I won't bother providing it here, but it should be simple enough. If you don't the light values will ALWAYS default to the values you set in the variables.Code: Select all
commandArray = {} local LightSwitch = "Living Room Dimmer" -- CHANGE: Name of light switch local MotionSensor = "Living Room Motion Sensor" -- CHANGE: Name of motion sensor. local LightTimer = "Lvngrm Light Off Timeout" -- CHANGE: Name of auto-off timeout user variable local LvngRmMndr = "Living Room Minder" -- Dummy switch to Enable/disable auto off. local LastLightStateLow = "LvngRmLghtSttLw" -- Light level to set to when NO motion detected user variable --LightSwitch could be a dimmer, so we check if it's not off rather than if it's on. if (otherdevices[LvngRmMndr] == "On" and otherdevices[LightSwitch] ~= "Off") then local s1 = otherdevices_lastupdate[MotionSensor] if (s1 == nil) then s1 = "2000-01-01 00:00:00" end local year1 = string.sub(s1, 1, 4) local month1 = string.sub(s1, 6, 7) local day1 = string.sub(s1, 9, 10) local hour1 = string.sub(s1, 12, 13) local minutes1 = string.sub(s1, 15, 16) local seconds1 = string.sub(s1, 18, 19) local t1 = os.time() local t2 = os.time{year=year1, month=month1, day=day1, hour=hour1, min=minutes1, sec=seconds1} local difference1 = t1-t2 if (difference1 > tonumber(uservariables[LightTimer])) then if (tonumber(uservariables[LastLightStateLow]) ~= "Off") then commandArray[LightSwitch]='Set Level ' .. tonumber(uservariables[LastLightStateLow]) else commandArray[LightSwitch] = "Off" end end end return commandArray
