show y-axis labels on the right of graph
adeibiza
Post by adeibiza »
i have an embedded graph but would like to show the labels on the right not the left as to me it makes more sense to see the current data and not have to trace across from the left side
is this possible (i dont mind if it's moved & only on the right but preferable to show y axis on both left and right ?
blocks['humidity'] = {
    title:'Humidity',
    customHeader: {},
    devices: ['80','84','87','106','82', '131','83'],
    width:12,
    datasetColors: ['red','yellow','blue','orange','green','purple','black'],
    graphTypes:['hu'],
        legend: {
                'hu_80': '153',
                'hu_84': '163',
                'hu_87':'154',
                'hu_106':'151',
                'hu_82':'152',
                'hu_131':'Room',
                'hu_83': 'Outside',
    height:'180px',
    width:12,
        buttonsPadX: 2,
        buttonsPadY: 2,
        buttonsBorder: 'orange',
        buttonsColor: '#fff',
        buttonsFill: '#000',
        buttonsIcon: 'orange',
        buttonsMarginX: 1,
        buttonsMarginY: 1,
        buttonsRadius: 5,
        //buttonsShadow: 'rgba(255, 255, 255, 0.1)',
        buttonsSize: 10,
        borderWidth:3,
Lokonli
Re: show y-axis labels on the right of graph
Post by Lokonli »
That is relatively easy. I've implemented it in latest beta (16:20 today CET)
New block parameters:
  axisRight: true,     //to show y axis on the right (default is false)
  axisAlternate: false //show multiple Y axes alternating left/right. (default is true)
adeibiza
Post by adeibiza »
b*lls, doesn't work for me (i haven't updated to v3.7 as i have some custom changes in a couple of js files (not related to graphs))
if i update will it over-write (cosmestic) changes i made in blocks.js or blocktypes.js ?
Lokonli
Post by Lokonli »
Yes.
If you've made changes to blocktypes you can move those to the hook in custom.js
What did you change to blocks.js?
adeibiza
Post by adeibiza »
around line 2100 getting rid of the dew point display
  if (typeof device['DewPoint'] !== 'undefined') {
    if (single_block) {
      blockValues[0].value +=
        ' '; // + number_format(device['DewPoint'], 1) + ' °';
    } else {
no big deal, just wondering :)
noob, how do i implement that new beta and where do i find it :)
Lokonli
Post by Lokonli »
If you followed the installation instructions (manual or auto install) then type the following in the Dashticz folder:
If you are on master, first switch to beta:
git checkout beta
Then get the latest changes with:
git pull
If you have made some local changes to the source files then you may get an error. You can throw away all changes with:
git reset --hard HEAD
adeibiza
Post by adeibiza »
thanks, just fyi - it overwrote the custom.js & custom.css files in custom folder - which seems odd (i did a backup before upgrading ;) )
HansieNL
Post by HansieNL »
adeibiza wrote: Thursday 24 December 2020 16:10 thanks, just fyi - it overwrote the custom.js & custom.css files in custom folder - which seems odd (i did a backup before upgrading ;) )
I can confirm that the files will be overwritten. @Lokonli Can these files be excluded if following command is executed?
Blah blah blah
Lokonli
Post by Lokonli »
I'll check
Lokonli
Post by Lokonli »
HansieNL wrote: Thursday 24 December 2020 18:42
I've decided to remove the custom.css and custom.js files from the Dashticz repository. This has been implemented in 3.7.2
The first update might be painfull ...
