Fibaro FGS-224 Parameter 151 missing
bayensf
Post by bayensf »
Not sure how to do this or to request it. The parameter 151 to select a Auto or Delay mode is missing;
151 - Second Channel - Operating Mode
This parameter allows to choose operating mode for channel controlled with Q2 output. For timed modes (value 1, 2 or 3), time is set with parameter 155 and reaction to input change is set with parameter 153.
Parameter size: 1B
Default value: 0 (standard operation)
Available values:
0 – standard operation
1 – delayed OFF
2 – auto OFF
3 – flashing
How to add it?
Many thanks in advance for anyway guiding me to a solution,
Regards.
Fred.
Annamae
Re: Fibaro FGS-224 Parameter 151 missing
Post by Annamae »
when i change parameter 150 to 2 and 154 to 10 for example, Q1 is set to momentary with 1s ON. when I try to change with same value on Q2 (parameter 151 and 155) , Q2 is always set as standard mode.
And also if Q1 and Q2 are set in standard operation , lock enabled works well but if i change Q1 to auto OFF, lock doesn't works, curious because i want to avoid 2 outputs ON in same time and even if Q1 is auto OFF, Q1 is momentary ON and if Q2 is ON ... problems
is it a limitation ? a problem of configuration ? an evolution to make on this module ?
Best regards
onevanilla
