Flashing lights, howto?  [Solved]
rgroothuis
Post by rgroothuis »
I've the following script that is triggered when the doorbell is pressed.
I want the lights to go on and off 5 times but I cannot get this working.
On top of this the current status of the lamp needs to be saved so that I can but the light back on or off again after the flashing is completed.
This is my script, what am I doing wrong?
 	logging = {
 		level = domoticz.LOG_DEBUG,
 		marker = 'ControlDeurBel'
		devices = {
			'Deurbel Input 1'
        -- If the Doorbell is pressed, take action and ring the bell.
		if (device.name == 'Deurbel Input 1') and (device.state == 'On') then
		    local deurBelOut = domoticz.devices('Deurbel Output 2')
            -- Log information to the debug window
            domoticz.log('Doorbell was pressed, lets ring the bell!', domoticz.LOG_INFO)
            -- Send a message to Telegram that the doorbell was pressed.
            local DateTimePressed = os.date("%d/%m/%Y %X")
        	domoticz.notify("HoekHuis Deurbel", "Doorbell was pressed at " .. DateTimePressed .. ".", domoticz.PRIORITY_HIGH)
            -- Enable the doorbell, smart implant output.
            -- Smart implant is configured to switch off the output automatically.
        	deurBelOut.switchOn()
        	-- Enable the gang door light
		    local VoorDeurLight = domoticz.devices('Lamp Hal Voordeur')
		    domoticz.log('Switch on the gang front door lamp.', domoticz.LOG_DEBUG)
        	VoorDeurLight.switchOn()
        	VoorDeurLight.switchOff().afterSec(10)
        	-- Switch On and Off the Kitchen light
		    local KeukenLamp = domoticz.devices('Keuken Lamp')
		    KeukenLamp.cancelQueuedCommands()
		    -- Save the status of the keuken Lamp to put it back to this status later
		    local KeukenLampStatus = KeukenLamp.state
		    domoticz.log('Keuken lamp status: ' .. KeukenLampStatus .. '.', domoticz.LOG_DEBUG)
		    -- Flash the kitchen lamp a couple of times
		    KeukenLamp.switchOn().forSec(1).repeatAfterSec(1, 5)
		    domoticz.log('Keuken lamp was flashed a number of times.', domoticz.LOG_DEBUG)
            if (KeukenLampStatus == 'On') then
                domoticz.log('Switch keuken lamp on again.', domoticz.LOG_DEBUG)
                KeukenLamp.switchOn().afterMin(1)
                domoticz.log('Switch keuken lamp off again.', domoticz.LOG_DEBUG)
                KeukenLamp.switchOff().afterMin(1)
The log that is generated is as follow:
2020-12-19 15:49:22.484 Status: dzVents: Info: ControlDeurBel: ------ Start internal script: ControlDeurBel: Device: "Deurbel Input 1 (HoekHuisZwave)", Index: 275
2020-12-19 15:49:22.484 Status: dzVents: Debug: ControlDeurBel: ============================================================================================
2020-12-19 15:49:22.484 Status: dzVents: Debug: ControlDeurBel: Device Deurbel Input 1 was changed. Status is: On.
2020-12-19 15:49:22.485 Status: dzVents: Debug: ControlDeurBel: Processing device-adapter for Deurbel Output 2: Switch device adapter
2020-12-19 15:49:22.485 Status: dzVents: Info: ControlDeurBel: Doorbell was pressed, lets ring the bell!
2020-12-19 15:49:22.485 Status: dzVents: Debug: ControlDeurBel: Constructed timed-command: On
2020-12-19 15:49:22.486 Status: dzVents: Debug: ControlDeurBel: Processing device-adapter for Lamp Hal Voordeur: Switch device adapter
2020-12-19 15:49:22.486 Status: dzVents: Debug: ControlDeurBel: Switch on the gang front door lamp.
2020-12-19 15:49:22.486 Status: dzVents: Debug: ControlDeurBel: Constructed timed-command: On
2020-12-19 15:49:22.486 Status: dzVents: Debug: ControlDeurBel: Constructed timed-command: Off
2020-12-19 15:49:22.486 Status: dzVents: Debug: ControlDeurBel: Constructed timed-command: Off AFTER 10 SECONDS
2020-12-19 15:49:22.486 Status: dzVents: Debug: ControlDeurBel: Processing device-adapter for Huiskamer Lamp: Switch device adapter
2020-12-19 15:49:22.486 Status: dzVents: Debug: ControlDeurBel: Keuken lamp status: On.
2020-12-19 15:49:22.486 Status: dzVents: Debug: ControlDeurBel: Constructed timed-command: On FOR 1 SECONDS
2020-12-19 15:49:22.487 Status: dzVents: Debug: ControlDeurBel: Constructed timed-command: On FOR 1 SECONDS REPEAT 6 INTERVAL 1 SECONDS
2020-12-19 15:49:22.487 Status: dzVents: Debug: ControlDeurBel: Keuken lamp was flashed a number of times.
2020-12-19 15:49:22.487 Status: dzVents: Debug: ControlDeurBel: Switch keuken lamp on again.
2020-12-19 15:49:22.487 Status: dzVents: Debug: ControlDeurBel: Constructed timed-command: On AFTER 60 SECONDS
2020-12-19 15:49:22.487 Status: dzVents: Debug: ControlDeurBel: ============================================================================================
2020-12-19 15:49:22.487 Status: dzVents: Info: ControlDeurBel: ------ Finished ControlDeurBel
2020-12-19 15:49:22.768 Status: dzVents: Info: ControlDeurBel: ------ Start internal script: ControlDeurBel: Device: "Deurbel Input 1 (HoekHuisZwave)", Index: 275
2020-12-19 15:49:22.768 Status: dzVents: Debug: ControlDeurBel: ============================================================================================
2020-12-19 15:49:22.768 Status: dzVents: Debug: ControlDeurBel: Device Deurbel Input 1 was changed. Status is: Off.
2020-12-19 15:49:22.769 Status: dzVents: Info: ControlDeurBel: ------ Finished ControlDeurBel
erem
Domoticz version: 2021.1
Re: Flashing lights, howto?  [Solved]
Post by erem »
this works for me
		devices = {
			'DoorBell'
	    if (domoticz.devices('DoorBell').state == 'On' and domoticz.devices('SomeoneHome').state == 'On')
	    then
	        if domoticz.devices('Staande driehoek lamp').state == 'Off'
	        then
    	        domoticz.devices('Staande driehoek lamp').switchOn().forSec(1).repeatAfterSec(1, 3)  -- repeat=(aftersec, nroftimes)
    	        domoticz.log('Device ' .. device.name .. ' was engaged while lamp was off', domoticz.LOG_INFO)
		        domoticz.devices('Staande driehoek lamp').switchOff().forSec(1).repeatAfterSec(1, 3) -- repeat=(aftersec, nroftimes)
		        domoticz.log('Device ' .. device.name .. ' was engaged while lamp was on', domoticz.LOG_INFO)
		    --domoticz.log('Device ' .. device.name .. ' was engaged', domoticz.LOG_INFO)
	    if domoticz.devices('DoorBell').state == 'On'
	    then
		    domoticz.devices('DoorBell').switchOff().silent()
Regards,
Rob
rgroothuis wrote: Saturday 19 December 2020 15:54 This is my script, what am I doing wrong?
If you use forSec() the before state is significant
Can you try this and if not OK yet, please describe what you expect and what is not working like expected.
return
    on =
        devices =
            'Deurbel Input 1'
    logging =
        marker = 'ControlDeurBel',
    execute = function(dz, item)
        local deurBelOut = dz.devices('Deurbel Output 2')
        local VoorDeurLight = dz.devices('Lamp Hal Voordeur')
        local KeukenLamp = dz.devices('Keuken Lamp')
        if item.name == 'Deurbel Input 1' and item.active then
            dz.log('Doorbell was pressed, lets ring the bell!', dz.LOG_INFO)
            dz.notify("HoekHuis Deurbel", "Doorbell was pressed at " .. DateTimePressed .. ".", dz.PRIORITY_HIGH)
            dz.log('Switch on the gang front door lamp.', dz.LOG_DEBUG)
            dz.log('Keuken lamp status: ' .. KeukenLampStatus .. '.', dz.LOG_DEBUG)
            if KeukenLamp.active then
                KeukenLamp.switchOff().forSec(1).repeatAfterSec(1, 5)
            dz.log('Keuken lamp was flashed a number of times.', dz.LOG_DEBUG)
                dz.log('Switch keuken lamp on again.', dz.LOG_DEBUG)
                dz.log('Switch keuken lamp off again.', dz.LOG_DEBUG)
rgroothuis
erem wrote: Saturday 19 December 2020 16:36 this works for me
		devices = {
			'DoorBell'
	    then
	        then
	    then
Excellent, this trick worked for me. Thanks for the support.
