dimTo for X minutes, will this work?  [Solved]
rgroothuis
Post by rgroothuis »
When the light is switch on at 50% brightness, then I want to set the brightness to 100% for 5 min, I'm using this command:
VoorDeurLight.dimTo(100).forMin(5)
It will switch to 100% but it doesn't go back to the 50% after 5 min. How can I achieve this?
rwblinn
Domoticz version: 4
Re: dimTo for X minutes, will this work?
Post by rwblinn »
Use
.afterMin(5)
Tested with following dzVents snippet:
local IDX_SWITCH = 49
		timer = {
			'at 16:33',
	execute = function(domoticz, timer)
		-- Get current dimmer level
		local dimmerLevel = domoticz.devices(IDX_SWITCH).level
		-- Set dimmer full level
		domoticz.devices(IDX_SWITCH).dimTo(100).forMin(1)
		-- Set back to previous level
		domoticz.devices(IDX_SWITCH).dimTo(dimmerLevel).afterMin(1)
rgroothuis
Re: dimTo for X minutes, will this work?  [Solved]
Thanks, looks like this is working for me. Thanks.
