sorry for my bad english,
Currently I control part of my switches programmed on domoticz with homebridge.
I wanted to know if it is possible to do the reverse?
Add a virtual witch on Domoticz who controlled a switch on homebridge?
thanks
in french :
contrôler homebridge avec domoticz
Bonjour,
Actuellement je contrôle une partie de mes switch programmée sur domoticz avec homebridge.
JE voulais savoir s'il est possible de faire l'inverse ?
Ajouter un witch virtuel sur Domoticz qui contrôlerait un switch sur homebridge ?
Merci
control homebridge with domoticz
- erem
- Domoticz version: 2021.1
Re: control homebridge with domoticz
are you running the homebridge eDomoticz plugin?
that seems to work both ways.
Regards,
Rob
Rob
Yes, I am using this pluggin.
How to make it work in the direction domoticz -> homebridge?
thank you
thank you
- erem
@freetribes
in my system there is nothing special i do to make it work both ways
there is a delay between switching a device in domoticz and homebridge. i timed it at about 60 secs.
this may be the sync interval of homebridge
in the log i see
[20/12/2020, 13:44:17] [eDomoticz] synchronizeAccessories in progress...
in the log i see
Regards,
Rob
Rob
