I would like, when someone opens the garage through the API, to be notified with its username.
I can see the username in the logs, when I watch the garage's history.
But I did not find how to pass this username to my script.
Do someone have information on this point ?
Regards,
LeNouveau
PS : I don't really care about the script language, I can adapt if required.
Notify with Username
- waaren
Re: Notify with Username
Can you check this?
__________________________________________________________________________________________________________________________
When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
___________________________________________________________________________________________________________________________
triggerinfo.lua
requires: sqlite3
dzVents >= 3.0.13
domoticz >= V2020.2 build 12693
return
on =
devices =
'triggerInfo', -- name of device(s) to be notified on
logging =
level = domoticz.LOG_DEBUG,
marker = 'trigger Info',
execute = function(dz, item)
local function getLightingLogData(id)
local _,rc = dz.utils.osCommand('which sqlite3')
if rc == 0 then
local cmd = 'sudo sqlite3 -list -noheader domoticz.db "SELECT DeviceRowID ID, User, Date FROM LightingLog WHERE DeviceRowID = ' .. id .. ' ORDER BY Date DESC LIMIT 1;" '
return dz.utils.osCommand(cmd)
dz.log('sqlite3 not available. Please make sure it is installed (sudo apt install sqlite3) and accessible', dz.LOG_ERROR)
-- main
if item.active then
local lightingLogLine = getLightingLogData(item.id)
if lightingLogLine:find('|') then
local lightingLogLineTable = dz.utils.stringSplit( getLightingLogData(item.id) ,'|')
local user = lightingLogLineTable[2]
local modTime = lightingLogLineTable[3]
dz.log( 'user: '.. user .. ' opened me at ' .. modTime,dz.LOG_DEBUG)
dz.notify(item.name, user .. ' opened me at ' .. modTime)
dz.log( 'Unexpected result from sqlite3 .. ' .. tostring(lightingLogLine),dz.LOG_ERROR)
This looks promising.
Thank you.
Thank you.
