Reset actual power pv panels
steef27
Post by steef27 »
Hi Guys,
I connected my pv system (SolarEdge) to Domoticz, but sometimes the API connection gets lost.
I wrote scome scripts to connect my room lights te the actual power generation.
When it is dark (no actual generation) my lights will switch on.
In cases the actual power generation will not be updated my light will not switch on. So I wrote a script to reset te actual power generation when the actual generation is greater than 0 and the the last update of the device is more than 15 minutes ago.
The problem is the log shows an error "attempt to call a nil value (field 'updateEnergy')"
Does anyone have an idea?
local pv = 114
		timer = {
			'every 5 minutes',
    logging = { level = domoticz.LOG_DEBUG },
    execute = function(dz, item)
            local pvActual        = dz.devices(pv).actualWatt
            local pvLastupdated   = dz.devices(pv).lastUpdate.minutesAgo
            if 	(pvLastupdated > 15 and pvActual > 0)
                then
                    dz.devices(pv).updateEnergy('0')
                    dz.log('Actuele opwekking: ' .. pvActual .. ' watt',LOG_DEBUG)
                    dz.log('Laatst bijgewerkt: ' .. pvLastupdated .. ' minuten geleden',LOG_DEBUG)
                    dz.log('Bijgewerkt: Ja',LOG_DEBUG)
                    dz.log('Bijgewerkt: Niet nodig',LOG_DEBUG)
Re: Reset actual power pv panels
steef27 wrote: Wednesday 16 December 2020 19:50 The problem is the log shows an error "attempt to call a nil value (field 'updateEnergy')"
updateEnergy is only available for Electric usage device types. I expect that pv is a KwH device type and there you need the updateElectricity(power, energy) method.
Something like
dz.devices(pv).updateElectricity(0, dz.devices(pv).WhTotal )
steef27
Post by steef27 »
attempt to call a nil value (field 'updateElekricity')
steef27
Post by steef27 »
ah .... dz.devices(pv).updateElectricity(0, dz.devices(pv).WhTotal)
