How to control with a Selector Switch (zigbee device) [Solved]
I recently bought a zigbee TuYa wireless wall switch (2 buttons).
The domoticz-zigbee2mqtt-plug-in has created a Selector Switch with 6 levels (1_single, 1_double, 1_hold, 2_single, 2_double, 2_hold)
Each button has 3 actions (single click, double click and long press)
I want create a script which e.g. clicking "1_single", turns a group or device ON and clicking "1_double" turns this group or device OFF
Does anyone has an example ho to approach this?
- Domoticz version: 2024.7
Re: How to control a Selector Switch (zigbee device)
It is easier to toggle the group with only 1_single.
You can do this with a dzvents script. It can check the status of the group and then toggle it on or off.
See for example viewtopic.php?t=25062
I had to add 4 Selector Levels (per switch): Off, Click, Hold, Release. Then in the event handler you can check the level
- waaren
Below script could be a solution for thisgschmidt wrote: ↑Monday 14 December 2020 19:49 The domoticz-zigbee2mqtt-plug-in has created a Selector Switch with 6 levels (1_single, 1_double, 1_hold, 2_single, 2_double, 2_hold)
Does anyone has an example how to approach this?
local ZSelector = 'Zigbee selector' -- change to name of your selector
return
on =
devices =
ZSelector,
logging =
level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when all OK
marker = ZSelector,
execute = function(dz, item)
-- enter your devices and controls below this line
local group_1 = dz.groups('testGroup1')
local device_2 = dz.devices('testDevice2')
local Z =
{-- levelname targetDevice, action, delay, level -- delay and level are optional
['1_single'] = { group_1, 'On' },
['1_double'] = { group_1, 'Off' },
['1_hold'] = {group_1, 'Off', 30 },
['2_single'] = { device_2, 'On' },
['2_double'] = { device_2, 'dimTo', 12, 60 },
['2_hold'] = { device_2, 'dimTo', 0, 10 } -- when level is set and no delay the delay should be set to 0
-- No changes required below this line
local function switch(object, action, delay, level)
object.cancelQueuedCommands()
if action == 'Off' then object.switchOff().afterSec(delay)
elseif action == 'On' then object.switchOn().afterSec(delay)
elseif action == 'dimTo' and object.isDevice then object.dimTo(level).afterSec(delay) -- dimTo not available to groups
dz.log('unknown action (' .. action ..') please report.', dz.LOG_ERROR)
local row = Z[item.levelName]
switch(row[1], row[2], ( row[3] or 0 ), row[4] )
Thanx for the example script!waaren wrote: ↑Monday 14 December 2020 21:12Below script could be a solution for thisgschmidt wrote: ↑Monday 14 December 2020 19:49 The domoticz-zigbee2mqtt-plug-in has created a Selector Switch with 6 levels (1_single, 1_double, 1_hold, 2_single, 2_double, 2_hold)
However, the following error is repeatedly shown (also when no action is performed) in the LOG:
2020-12-14 22:16:34.803 Error: dzVents: Error: (3.0.18) error loading module 'Script #1' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/Script #1.lua':
2020-12-14 22:16:34.803 ...domoticz/scripts/dzVents/generated_scripts/Script #1.lua:28: '}' expected (to close '{' at line 27) near '_single'
- waaren
OK, my bad.. Lua does not like the keys to start with a number. Can you try again after changing the Z table declaration togschmidt wrote: ↑Monday 14 December 2020 22:25 However, the following error is repeatedly shown (also when no action is performed) in the LOG:Code: Select all
2020-12-14 22:16:34.803 Error: dzVents: Error: (3.0.18) error loading module 'Script #1' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/Script #1.lua': 2020-12-14 22:16:34.803 ...domoticz/scripts/dzVents/generated_scripts/Script #1.lua:28: '}' expected (to close '{' at line 27) near '_single'
local Z =
Works like a charm (only a small error you forgot the () after switchOn)waaren wrote: ↑Monday 14 December 2020 22:30OK, my bad.. Lua does not like the keys to start with a number. Can you try again after changing the Z table declaration togschmidt wrote: ↑Monday 14 December 2020 22:25 However, the following error is repeatedly shown (also when no action is performed) in the LOG:Code: Select all
local Z = {-- levelname targetDevice, action, delay, level -- delay and level are optional ['1_single'] = { group_1, 'On' }, ['1_double'] = { group_1, 'Off' }, ['1_hold'] = {group_1, 'Off', 30 }, ['2_single'] = { device_2, 'On' }, ['2_double'] = { device_2, 'dimTo', 12, 60 }, ['2_hold'] = { device_2, 'dimTo', 0, 10 } -- when level is set and no delay the delay should be set to 0 }
elseif action == 'On' then object.switchOn.afterSec(delay)
Re: How to control with a Selector Switch (zigbee device)
If my device is a RGBW dimmer what functions need to be added to control the Color and White?
So lets say under ['1_hold'] I want to set the RGB color to setRGB(255,0,0) and dimto level 70
- waaren
Can you test this one?
return
on =
devices =
ZSelector,
logging =
marker = ZSelector,
local Z =
{-- levelname targetDevice, action, delay, value -- delay and value are optional
-- R, G, B, dimlevel
['1_hold'] = {device_2, 'setColor', 0, { 255, 0, 0, 70 } },
local function switch(object, action, delay, value)
elseif action == 'dimTo' and object.isDevice then object.dimTo(value).afterSec(delay) -- dimTo not available to groups
elseif action == 'setColor' and object.isDevice then object.setColor(value[1], value[2], value[3], value[4]).afterSec(delay)
dz.log('unknown action (' .. action ..') for object ' .. object.name .. ' ( a ' .. object.baseType ..'). Please report.', dz.LOG_ERROR)
switch(row[1], row[2], ( row[3] or 0 ), row[4] ) -- object (device / group), action, delay, value
Thanx man, this script is working (I have changed the order of the selector buttons a bit, and set the color to green):
local ZSelector = 'Woonkamer_Switch' -- change to name of your selector
return
on =
devices =
ZSelector,
logging =
marker = ZSelector,
local group_1 = dz.groups('Kerstverlichting')
local device_2 = dz.devices('Woonkamer_Licht')
local Z =
['2_double'] = { device_2, 'Off' },
['2_hold'] = {device_2, 'setColor', 0, { 0, 255, 0, 70 } },
2020-12-16 20:02:23.161 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-12-16 20:02:30.049 Status: dzVents: Info: Handling events for: "Woonkamer_Switch", value: "2_hold"
2020-12-16 20:02:30.049 Status: dzVents: Info: Woonkamer_Switch: ------ Start internal script: Script #1: Device: "Woonkamer_Switch (Zigbee2MQTT)", Index: 527
2020-12-16 20:02:30.050 Status: dzVents: Debug: Woonkamer_Switch: Processing device-adapter for Kerstverlichting: Group device adapter
2020-12-16 20:02:30.051 Status: dzVents: Debug: Woonkamer_Switch: Processing device-adapter for Woonkamer_Licht: RGB(W) device adapter
2020-12-16 20:02:30.051 Status: dzVents: Debug: Woonkamer_Switch: Processing device-adapter for Woonkamer_Licht: Switch device adapter
2020-12-16 20:02:30.051 Status: dzVents: Debug: Woonkamer_Switch: OpenURL: url = http://127.0.0.1:9090/json.htm?type=command¶m=setcolbrightnessvalue&idx=534&brightness=70&color={"m":3,"t":0,"cw":0,"ww":0,"r":0,"g":255,"b":0}
2020-12-16 20:02:30.051 Status: dzVents: Debug: Woonkamer_Switch: OpenURL: method = GET
2020-12-16 20:02:30.051 Status: dzVents: Debug: Woonkamer_Switch: OpenURL: post data = nil
2020-12-16 20:02:30.051 Status: dzVents: Debug: Woonkamer_Switch: OpenURL: headers = nil
2020-12-16 20:02:30.051 Status: dzVents: Debug: Woonkamer_Switch: OpenURL: callback = nil
2020-12-16 20:02:30.051 Status: dzVents: Info: Woonkamer_Switch: ------ Finished Script #1
2020-12-16 20:02:30.053 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-12-16 20:02:30.066 Status: setcolbrightnessvalue: ID: 216, bri: 70, color: '{m: 3, RGB: 00ff00, CWWW: 0000, CT: 0}
When I manually change the WW color temperature of the "dz.devices('Woonkamer_Licht')" to the value I want, the log show this:
2020-12-16 19:49:52.450 Status: setcolbrightnessvalue: ID: 216, bri: 61, color: '{m: 2, RGB: 000000, CWWW: 59a6, CT: 166}'
I already figured it out myself...half...
Just added the extra attributes
color temp change is working.....only dimlevel is not working
return
on =
devices =
ZSelector,
logging =
marker = ZSelector,
local Z =
-- setColor(r, g, b, br, cw, ww, m, t, dimlevel)
['2_hold'] = {device_2, 'setColor', 0, { 0, 0, 0, 50, 119, 225, 2, 225, 10 } },
elseif action == 'setColor' and object.isDevice then object.setColor(value[1], value[2], value[3], value[4], value[5], value[6], value[7], value[8], value[9]).afterSec(delay)
Ah stupid.....the 'br' attribute is the brightness....so dimto() is not needed if 'br' is set
- waaren
m is the colormode. Here set to 2 ; see the
the method setColor accepts more parms (see the API wiki and the dzVents wiki
If I understand you correctly you could try with
return
on =
devices =
ZSelector,
logging =
marker = ZSelector,
local Z =
-- R, G, B, dimlevel, cw, ww, m, t (dimlevel, cw, ww, m and t are optional)
['2_hold'] = {device_2, 'setColor', 0, { 0, 255, 0, 70, 89, 166, 2, 166 } },
elseif action == 'setColor' and object.isDevice then object.setColor(value[1], value[2], value[3], value[4], value[5], value[6], value[7], value[8]).afterSec(delay)
I already figured it out myself....like this: (br = dimLevel)waaren wrote: ↑Wednesday 16 December 2020 21:07m is the colormode. Here set to 2 ; see the
local ZSelector = 'Woonkamer_Switch' -- change to name of your selector return { on = { devices = { ZSelector, }, }, logging = { level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when all OK marker = ZSelector, }, execute = function(dz, item) -- enter your devices and controls below this line local group_1 = dz.groups('Kerstverlichting') local device_2 = dz.devices('Woonkamer_Licht') local Z = {-- levelname targetDevice, action, delay, value -- delay and value are optional ['1_single'] = { group_1, 'On' }, ['1_double'] = { group_1, 'Off' }, ['1_hold'] = {group_1, 'Off', 30 }, ['2_single'] = { device_2, 'On' }, ['2_double'] = { device_2, 'Off' }, -- R, G, B, dimlevel, cw, ww, m, t (dimlevel, cw, ww, m and t are optional) ['2_hold'] = {device_2, 'setColor', 0, { 0, 255, 0, 70, 89, 166, 2, 166 } }, } -- No changes required below this line local function switch(object, action, delay, value) object.cancelQueuedCommands() if action == 'Off' then object.switchOff().afterSec(delay) elseif action == 'On' then object.switchOn().afterSec(delay) elseif action == 'dimTo' and object.isDevice then object.dimTo(value).afterSec(delay) -- dimTo not available to groups elseif action == 'setColor' and object.isDevice then object.setColor(value[1], value[2], value[3], value[4], value[5], value[6], value[7], value[8]).afterSec(delay) else dz.log('unknown action (' .. action ..') for object ' .. object.name .. ' ( a ' .. object.baseType ..'). Please report.', dz.LOG_ERROR) end end local row = Z[item.levelName] switch(row[1], row[2], ( row[3] or 0 ), row[4] ) -- object (device / group), action, delay, value end }
local ZSelector = 'Woonkamer_Switch' -- Script for wall switch to control RGBWW devices
return
on =
devices =
ZSelector,
logging =
marker = ZSelector,
local Z =
-- setColor attributes (r, g, b, br, cw, ww, m, t)
['2_single'] = {device_2, 'setColor', 0, { 0, 0, 0, 70, 119, 180, 2, 180 } },
['2_hold'] = {device_2, 'setColor', 0, { 0, 0, 0, 2, 119, 180, 2, 180 } },
I am using this dzVents Wall Switch script for a while now.
But I was wondering if it is possible to turn off this group:
and at the same time silently dimTo(80) device_1?
device_1 is a dimmer switch (dimming a group of zigbee bulbs) which, is part of group_1
I also voice control this dimmer switch but it remembers the last dimming level when turned on with Google Home voice.
Now if the Wall_Switch turns off group_1, after ['1_hold'] was selected (which dimTo(30) device_1), Google Home remembers the last dimming level 30. Therefor I want to Turn Off group_1 and silently dimTo(80) device_1
return
on =
devices =
ZSelector,
logging =
marker = ZSelector,
local group_1 = dz.groups('Woonkamer Lampen')
local device_1 = dz.devices('Woonkamer_Licht')
local device_2 = dz.devices('Tafel_Lamp')
local Z =
['1_hold'] = { device_1, 'setColor', 0, { 0, 0, 0, 30, 0, 180, 2, 180 } },
-- setColor attributes (r, g, b, br, cw, ww, m, t) -- m:3 is RGB & m:2 WW mode
['2_single'] = { device_2, 'dimTo', 0, 15 },
['2_hold'] = { device_2, 'dimTo', 0, 70 },
- waaren
The dimTo(80) will switch device-1 to On with dimlevel 80. The option silent will only prevent any subsequent script from being triggered.gschmidt wrote: ↑Monday 29 March 2021 20:50 But I was wondering if it is possible to turn off this group:and at the same time silently dimTo(80) device_1?Code: Select all
Would it be possible to change the google Home command from switchOn() to dimTo(30) ?
The dimTo(30) is also an implicit switchOn()
Re: How to control with a Selector Switch (zigbee device) [Solved]
Okay I get it.waaren wrote: ↑Monday 29 March 2021 21:25The dimTo(80) will switch device-1 to On with dimlevel 80. The option silent will only prevent any subsequent script from being triggered.gschmidt wrote: ↑Monday 29 March 2021 20:50 But I was wondering if it is possible to turn off this group:and at the same time silently dimTo(80) device_1?Code: Select all
I can add group_1 (which dims device_1 to 80) also to Google Home (wih Controlicz), so that would be my second option.
The only thing I need to do is rename the Room name in Google or the dz Group Name (they are now equal: "Woonkamer"), which confuses google.
I was trying avoid that but now I have to.
thanx!
[update] already working
