It contains all functionality from v3.6.9 beta.
Main changes compared to v3.6 master:
Garbage
- Update of quite some garbage providers
- New representation as table layout.
- Customize styling via trashtoday and trashtomorrow css classes
- Date separator configurable
- Dials now enabled for most devices
- Set the block parameter ``animation`` to ``true`` or ``false`` to enable/disable dial animations.
- Combine data from several devices
- Stationclock: new configuration options
- Graphs: Customize the button icons in custom graphs
- Colorpicker: Support for WW dimmers (Philips Hue for instance)
- Configure Dashticz configuration settings in the url. For instance, to start Dashticz with an alternative configuration script use 'http://dashticz ip:port/?cfg=CONFIG.new.js
- The css class 'timeout' is added to blocks for devices in Domoticz timeout state
- Button, special blocks: Initiate the 'url' parameter as POST request by setting 'newwindow: 4'
- Set config setting 'security_panel_lock' to '2' to activate security panel lock in 'Armed Home' mode as well.
- Graph as moving time chart
- Custom html block
- X10 security motion device
- Scenes will switch always to on
- New Covid-19 server
- PV Output temp device
- Remove scroll bar of the modal security panel (security panel lock)
https://dashticz.readthedocs.io/en/mast ... notes.html
